Motor build with vortech
Old May 28, 2005 | 12:07 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
Default Motor build with vortech
Hey guys,
I'm about to build my motor with my vortech and was wondering if you guys could throw in some input...Im goin with the Arias 8.6:1 pistons and pauter rods with RC 550 injectors and all the other little things i need....im tryin to run a decent amount of boost out of the vortech, as of right now, im running 0.8 bar out of it with the 2.87 pulley which is about 11.75 psi....last dynoed was 418 whp on a mustang dynometer....after building the motor, i wanted to run maybe 20 or so psi out of the charger with an upgraded impeller from vortech if it was possible...any suggestions would help....thanks!
ps. check out sig for mods list so far...
Old May 28, 2005 | 12:15 PM
GMADD's Avatar
GMADD
Maybe a 9.0 or 9.3 compression would be better for a supercharger.
just my 2 cents.
In any case I would love to see the results.
Good luck !
Tasso-
Old May 28, 2005 | 12:18 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
i was thinking about higher compression pistons than 8.6:1 too, i only said 8.6 for now cuz thats whats easiest to get since they are in stock....
What hp numbers you guys think it would hit with about 20 or so psi on the charger?
Old May 28, 2005 | 01:28 PM
narkotic's Avatar
narkotic
Get the 10:1 CP pistons if you're gonna do it. ESPECIALLY w/ a centrifugal blower!
Old May 28, 2005 | 01:32 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
ok ill look into that....any idea on a good place to find CP pistons?
Old May 28, 2005 | 02:43 PM
Gman2004's Avatar
Gman2004
Try forgedinternal.com. You won't see those pistons on the site, but email Sharif the owner or give him a call, and he can probably source them for you. He has very competive prices. As far as how much you can boost with a rebuilt blower pm booger. He currently has a built motor with the vortech and just got his blower back from Vortech.
Old May 28, 2005 | 04:16 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
ok thanks.....yeah forgedinternals is where ive been gettin my parts....so far ive gotten the injectors and now im wonderin bout pistons which is what you guys have been helping me with....ill get a hold of booger and see what he says too unless he decides to chime in....
Old May 28, 2005 | 05:27 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Originally Posted by jdm3fiddyZ
Hey guys,
Iany suggestions would help....thanks!
pm me your e-mail,,,i'll send you some spreadsheets that i compliled..i've sent them to others on the forum looking to build their motors..i think it will help answer most of your questions
TODD
Old May 29, 2005 | 08:57 AM
jdm3fiddyZ's Avatar
jdm3fiddyZ
How come the S/C trim blower that comes with the kit is rated at 20 psi, and people say that with the 2.87 pulley that i have which only puts out 11.75 psi (0.8 bar) is overspinning the impeller?
Old May 29, 2005 | 09:05 AM
booger's Avatar
booger
Just because its rated at 20psi , doesnt mean thats what you get . That rating is with out a intercooler , pipeing , throttle body , and plenum . Its rated at the end of the blower .
Old May 30, 2005 | 08:14 AM
jdm3fiddyZ's Avatar
jdm3fiddyZ
so how much useful boost is the S trim capable of? i am running almost 12 psi right now, is that the limit?
Old May 30, 2005 | 08:36 AM
booger's Avatar
booger
By Vortech's site the S-trim has the same spec's as the SC-trim . I got a boost leak and made 12psi yesterday at 6,300rpm with the T-trim . I'll see what I can get in the next week or so
Old May 30, 2005 | 09:52 AM
jdm3fiddyZ's Avatar
jdm3fiddyZ
sounds good booger.....just keep us updated....i wonder what the t-trim is capable of at its peak useful potential?
350Z_Al
Oct 29, 2020 07:44 PM
