Question about Stillen S/C
Old Aug 2, 2005 | 10:05 PM
  #61
solidsnake's Avatar
solidsnake
Good input guys. I guess my only problem is that nasty hood you have to get with the stillen..BLAH!!
Old Aug 3, 2005 | 05:05 AM
  #62
Mean Gene's Avatar
Mean Gene
Thumbs up Maximizer
Wes - The Maximizer's awesome!! I've been using it to adjust my ramp-up rates & rpms as I've increased the jets. I totally agree with ya about needing the squeeze so the ZEX will stay on my G but I'll only use it to get the Vortech into boost & then ramp it down as the boost comes up. The Maximizer will let me fine tune things by pulsing the solenoids so I'll probably change those yearly as a precautionary action against premature wear.
Like Bill ( booger ) says - ya gotta pay to play!!
Old Aug 3, 2005 | 09:01 AM
  #63
sukhi's Avatar
sukhi
Originally Posted by 2003z
Here is a pic of mine.
I have installed both a Stillen and a Vortech, both are straight forward. Tonite, I drove LeMans350z's 422 hp vortech (the one I installed) and this is my comparison. Although he has 80 hp on me, the way the power comes on is totally different. The stillen is like an 'instant-on' boost, and stays level, or perhaps drops off a little bit towards redline. The vortech doesn't give you the low end kick, but you can definitely tell that power is building all the way to redline. I had driven his car before, but not since its tune and not really back to back with mine. Overall, I have to say I like the feel of the stillen better, just because of the low-end kick, and not because its the one that I have.
Nice looking Ride. I'll post some pics of mine in a week or two once my hood gets painted. I don't think the hood is as bad as many make it out to be.
Old Aug 3, 2005 | 09:30 AM
  #64
weslutes's Avatar
weslutes
That was what I was planning on doing with my APS TT's except with my built motor, I can leave a little juice flowing up top too.I plan on starting with a 75 shot then trickle down to a 35 shot once the 13 pounds kick in
I didn't know sylinoids wear out so fast. In that case, I should probably send my Zex box in for some new ones.
Where did you wire in the Maximizer? At the TPS wire?
I wired in a push button between the TPS wire so I can give bursts when I do/don't need it(poor mans Maximizer).
Now all I need to worry about is my 5AT
There are + & - for each SC. Stillen will need n2o up top, while Vortech needs n2o down low. note: how I said NEEDS
Old Aug 3, 2005 | 12:59 PM
  #65
zrdude's Avatar
zrdude
Have you seen the new Stillen hood with the hood scoop? It is actually pretty cool, and would have the added benefit of helping to keep engine bay temps lower...
Old Aug 4, 2005 | 09:21 AM
  #66
COJ_General's Avatar
COJ_General
Im going ahead and thinking about either going with the Vortech or the Stillen Supercharger and I know that the stillen doesn't respond to well with aftermarket headers....but when i talked to some of the guys over at stillen they were unfamilar with anyone with alphawerks headers. Has anyone heard of any issues with that or having a stage 2 or 3 kit produce to much heat for these headers to work with it?
Old Aug 4, 2005 | 09:27 AM
  #67
2003z's Avatar
2003z
Originally Posted by zrdude
Nice ride my man! Very tastefully done. What's the wing? Do you have Stage 2 or 3?
thanks, its the data systems wing. I'm stage 3, bought it used and never ran it stage 2, so I can't compare the two.
Old Aug 4, 2005 | 12:17 PM
  #68
AdamDC's Avatar
AdamDC
The problem with the headers is not increased heat, but a problem of not enough back pressure. Positive displacement SC's (roots, eaton, kenne bell and whipple) need some backpressure.
Old Aug 4, 2005 | 01:55 PM
  #69
gps321's Avatar
gps321
"2003Z" what side skirts are those on your Z?
Old Aug 4, 2005 | 04:07 PM
  #70
2003z's Avatar
2003z
Stillen
Old Aug 4, 2005 | 08:24 PM
  #71
COJ_General
So AdamDC, if I don't end up switching back to stock headers, what sort of problems could i encounter?
Old Aug 5, 2005 | 05:21 AM
  #72
2003z's Avatar
2003z
you might run lean under boost. Its a long complicated reason, but basically, because of valve overlap, the software doesn't recognize full boost, but only sees a pound or so less than what is being produced, and fuels for that accordingly, making it run lean.
Old Aug 5, 2005 | 07:54 AM
  #73
AdamDC's Avatar
AdamDC
what he said
Old Aug 5, 2005 | 09:46 AM
  #74
COJ_General
Is there anyway besides getting back the stock headers to resolve this problem?
Old Aug 5, 2005 | 03:45 PM
  #75
cersoft's Avatar
cersoft
So is stillen saying that this is purely a software problem, ie. if one were to switch to the EmanageUltimate would that ECU see the boost differently ??
Colin
Old Aug 8, 2005 | 11:12 AM
  #76
zparts's Avatar
zparts
Colin
No, what they are saying is that if you keep your stock exhaust manifolds, you wont blow your air/fuel charge out your exhaust during valve overlap.
Old Aug 8, 2005 | 02:44 PM
  #77
cersoft's Avatar
cersoft
Ahh, it is all so clear now .... so why is this not a problem with turbos??
Old Aug 13, 2005 | 02:08 PM
  #78
g356gear's Avatar
g356gear
I wonder about the addition of JWT cams and their effects on the Stillen supercharger performance.
Old Sep 20, 2005 | 04:24 PM
  #79
ztwins's Avatar
ztwins
bump for effects of stillen supercharger with cams...
issyz
Jul 2, 2017 03:04 PM
kyin
Oct 15, 2015 05:54 AM
Alexreyes
Sep 30, 2015 11:30 PM
