Kinetix SSV, pretty much a show piece.
Old Jun 22, 2005 | 11:47 PM
  #41
uplz4588's Avatar
uplz4588
i like mine!
Old Jun 23, 2005 | 02:46 AM
  #42
Rogue350z's Avatar
Rogue350z
!!HR TT!!
Originally Posted by booger
This does not however explain the other recent dyno from lemans350z which has the A/F going off the chart rich, and then even when R4 adjustments were maxed out, they couldnt get it back into the previous A/F range
After a PM with Lemans350Z . He told me [ I believe ] his numbers in the R4 fuel map , were 9's . This is far from maxing out what you can pull fuel out . Mine are in the 7's after 6000rpm . I dont know if his tuner didnt feel comfortable with the R4 program or what . But he for sure can lean it out enough to get it back to where it was.
When I first posted my dynos I asked about the 9s wanting to know if that was normal and could we have gone lower in the R4. Check thread...
I wish that someone would have told me that my 9s are OK and that he can take it even lower. Ed told me has never had to go into the 9s before much less the 7s with the R4. Maybe their are still gains to be made. It does sound like several hours on the dyno. The car goes back on Wednesday while I work.
AlanL do you have time to baby sit the car at the shop? I know you have an interest in the new intake.
Jeremy
Old Jun 23, 2005 | 05:28 AM
  #43
AlanL's Avatar
AlanL
I may be able to go hang out and watch. Where is it going? I have sent you a PM.
Alan:-)
Old Jun 23, 2005 | 08:38 AM
  #44
G3po's Avatar
G3po
Originally Posted by acg
That is wierd compared to what I have been reading on the system, Booger, Randy and dfwg35 all got more power than 330whp before they went to the next level.
Looks like I may have to add a few other items to my list before dynoing
Yeh but were they tuned for 91 , 93 or etc?
You need to puill extra timing to make it safe for crappy Cali 91.
Old Jun 23, 2005 | 08:42 AM
  #45
mcduck's Avatar
mcduck
Originally Posted by Sharif@Forged
There was roughly 3 degrees of additional timing that could be added which would take you to the danger threshold for your setup on 93 octane fuel. Personally, I think we all agreed its a safer tune at 421whp and 15 degrees of total advance. With the extra 3 degrees of timing advance, you would easily be in the 435-445whp range. Timing makes an enormous difference in power output.
I agree (though I was thinking more like 450-455 range)... and the timing I got, IMO, is exactly what I was asking for. I just wanted to verify for everyone else that my car **could** be making even more power. That is, we are not at the limit of my current configuration.
Thought that extra knowledge may help illustrate the difference between someone with only the 3.12" pulley upgrade vs the 3.12" pulley upgrade AND the SSV.
Old Jun 23, 2005 | 08:45 AM
  #46
mcduck's Avatar
mcduck
hmm... mcduck also wondering if he should fill up on 100 octane one day and get a re-tune that could be loaded strictly for the drag strip...
Old Jun 23, 2005 | 12:30 PM
  #47
Rogue350z's Avatar
Rogue350z
!!HR TT!!
I agree 100% with this. The vast majority of the Vortech kits we sell are the "tuner kits", and then we add the return fuel system, larger injectors, and an emanage setup for the ultimate Vortech setup.
Sharif,
Do you think added just the Emanage would make tuning the car easier? Seems like tuners seem to know it alot better the the R4 I am using now. Can I use this setup without upgrading the to the return fuel system and injectors? I am thinking I could add the return fuel system and injectors later this year.
Thanks!
Jeremy
Old Jun 23, 2005 | 12:48 PM
  #48
booger's Avatar
booger
LeMans350
PM me your email, I'll send you a copy of my fuel map and you can show it to your tuner . So then he will be OK with bringing the numbers down and getting that A/F right . You wouldnt be able to use my exact map , but you can get an idea
Old Jun 23, 2005 | 01:48 PM
  #49
Rogue350z's Avatar
Rogue350z
!!HR TT!!
Thanks booger!
Old Jun 23, 2005 | 05:56 PM
  #50
350zDCalb's Avatar
350zDCalb
builtZmotors
Originally Posted by SungNamZ
Some others might want to jump in, but from you graph it looks like your A/F could be improved. It appears that it is in the 12's.
Would G352NV see and increase in numbers if the same A/F curve was moved into the mid 11's starting at about 3500 rpms and continuing to 6500 rpms?
If I may respectfully add a comment Ron:
If I am understanding what you are saying correctly...if his A/F is at 12:1...by richening it to 11:1 or below will indeed increase the safety blanket of the tune but will decrease the power gain, not increase
TODD
Old Jun 23, 2005 | 09:50 PM
  #51
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Possible, but more likely a little bit less. You'll experience some parasitic losses with the SC. With a turbo setup, the power gains with each degree of timing are a bit higher.
Sharif,
Thanks!
Jeremy
Not very easily. The FMU would make tuning with an eManage very challenging. It would be best to stick with the basic Vortech fuel and engine management system, and then upgrade to a return fuel system and eManage setup all at once....whenever you are ready.
Old Jun 23, 2005 | 10:03 PM
  #52
Barzten1's Avatar
Barzten1
Here are my new numbers thanks to a good tune by Ryan at Speed Dreams!
Attached Thumbnails Kinetix SSV, pretty much a show piece.-dyno-05-397whp.jpg
Old Jun 27, 2005 | 05:41 PM
  #53
G352NV's Avatar
G352NV
Ok I talked with Rob at Z car. Seems I, we, were looking at the wrong #'s. The blue is the before and red is after. He said that the reason why my #'s are low is because these are real world #'s. He did 9 pulls within a hour so the motor was good and heat soaked and thats one of the reason why my 3's are low. The timing is set for 91 oct. Cali chit gas! He said if I ran a higher octane he could adjust the timing to make more power. He also said if I wanted just a higher dyno reading he could also help with that,lol. All in all I found out the car is very safe. He said if I wasnt worried about my motor he could make much higher #'s
As for the Kinetix IM he said he dyno'ed a car right before mine with and without it. The car was turbo'ed and made 10hp more with it.
Uriyo_
Sep 8, 2021 08:46 AM
