Technosquare reflash of FI with stock internals
Old Jun 27, 2005 | 07:20 AM
Oleg's Avatar
Oleg
Default Technosquare reflash of FI with stock internals
How many of you guys are revving to 7200 with any kind of forced induction with no changes to the engine? If you do, how have the motors been holding up to the boost+increased rpm?
Old Jun 27, 2005 | 07:58 AM
Badmonkey's Avatar
Badmonkey
I have the TS reflash and I usually shift around 6500-6800. I try not to get to 7000, but I have seen it go that high on occasion. I have not had any problems, so far. I do have the J&S Safeguard, just in case anything tries to act up.
SungNamZ's Avatar
SungNamZ
NO problems!
Old Jun 27, 2005 | 10:39 AM
Oleg's Avatar
Oleg
Badmonkey, I hate to sound like a dolt, but what is J&S safeguard?
Old Jun 27, 2005 | 11:28 AM
Badmonkey's Avatar
Badmonkey
Go here: www.jandssafeguard.com
It explains it much better than I can. Basically, it protects against detonation and I can map my timing, by retarding it as boost is increased.
Old Jun 27, 2005 | 11:51 AM
mrtomcat's Avatar
mrtomcat
also if you have the reflash before getting FI you should be able to tune around that range when installing the kit
Old Jun 27, 2005 | 12:14 PM
nickgundara's Avatar
nickgundara
Interesting topic. My tuner has just installed an APS TT kit with Nismo cams and and HKS F-Con for me. When trying to tune the F-con, he was having problems communicating with the ECU. We figured out that the problem was because my ECU had previously been reflashed by TS. They are getting it reflashed to stock specifications as we speak, but its interesting that TS somehow put a lockdown on the ECU.....probably so no one would steal their technology. Or I may just be way off here, and its a standard problem when reflashing???
Old Jun 27, 2005 | 01:19 PM
mrtomcat's Avatar
mrtomcat
that's kinda scary since I have the l-spec reflash and am about to get my APS kit installed (once it clears customs and makes it over here that is... )
Are there any APS people with technosquare reflashes on here?
Old Jun 27, 2005 | 01:35 PM
tinman's Avatar
tinman
mine shift around 7000-7100.i ran hard for like a month without any problem.i got SFR kit.
Old Jun 27, 2005 | 09:06 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
the msd btm ignition can also do the same thing as j&S
Old Jun 27, 2005 | 09:33 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Note that he does not have the engine management that comes with the APS TT kit (Unichip piggyback). He has the HKS F-Con V-Pro standalone.
Old Jun 27, 2005 | 09:34 PM
Brandon@Forged
It should not be that. The V-Pro completely takes over the ECU's functions to tell the engine what to do.
Old Jun 28, 2005 | 06:29 AM
rabbid's Avatar
rabbid
But it piggy backs the factory ECU
Old Jun 28, 2005 | 06:35 AM
nickgundara
Correct.....the ECU is still in place for normal functions (power windows etc), but we have found that the ECU also helps to control idle. After reflashing the ECU back to stock yesterday, my tuner still had problems adjusting idle. So today TS will reflash the ECU again with idle information so my tuner can complete the job. What a pain! The TS reflash has somehow locked up adjusting certain parts of the ecu.
Old Jun 28, 2005 | 07:15 AM
CESAROTORRES's Avatar
CESAROTORRES
Subscribing
