350z turbonetics kit
Old Jul 27, 2005 | 06:15 PM
  #41
bhk1004's Avatar
bhk1004
I guess ur gonna need a piggy back so that you can fine tune the tuning... the more and more I see of the people with slight problems with the turbonetics... it is making me feel like I should spend the extra money on the APS single turbo since you can always do the fine tuning.... ahhh
Old Jul 27, 2005 | 06:37 PM
  #42
ryan350zpower's Avatar
ryan350zpower
yeah i cant believe my a/f was 12.5 should i be worried when i drive???
Old Jul 27, 2005 | 07:33 PM
  #43
1 2 NV's Avatar
1 2 NV
What gear did they dyno in?
Is that SAE corrected or not?
Old Jul 27, 2005 | 08:51 PM
  #44
Peking's Avatar
Peking
Originally Posted by ryan350zpower
ok guys.... here the deal.... the car put down 375.9 whp with the turbo kit... a few problems...
first off when we dyno'd the air/fuel it was running around 12.5!!! WTF, we called turbonetics and all they could say is that they cant make a mistake because theres only one reflash that they do... ok second thing is that when at idle, the car is misfiring like crazy!! im really worried on what to do.... please anyone help?
"TURBONETICS ST KIT
100-shot NOS ZEX
AEM cold-air intake
BORLA TD exhaust"
So you installed the Turbonetics ST kit, do you still use the N/X? And a cold air intake from AEM
Anyway could be many reasons on why you are reading in the 12's for A/F... Do you have a A/F gauge? I would suggest going over again with the shop on the parts of the fuel upgrades, injectors, plugs, the modding of the fuel pump.
Other than that, if some of us are running rich (well more than 11.5) then it wouldn't be surprising me if some would be running more lean.
Also since all seems to be good for me other than running rich, is why I am considering alternate managment other than a re-flashed ECU.
Old Jul 28, 2005 | 03:03 AM
  #45
ryan350zpower
they dyno'd in third gear.... should i be worried about blowing my engine with that a/f?
Old Jul 28, 2005 | 04:20 AM
  #46
Alberto's Avatar
Alberto
Cranky FI Owner
I would be worried with FI and a 12.5 a/f, enough to where I wouldnt be flooring my car. Cant Turbonetics reflash the ecu for you? Obviously no two cars are alike, so what could be a rich safe tune on one car could be lean on another. Does anybody know if Turbonetics charges for a 2nd flash if your first one doesnt work? I think they should offer everybody at least 1 extra reflash if their base tune makes the car unsafe to drive. If not people are going to have to spend more $$$ on pigyyback ecu's, and that would take away from the value of the kit....
Keep us update as to what your going to do with your a/f's.
Old Jul 28, 2005 | 05:31 AM
  #47
dynamic6er's Avatar
dynamic6er
You have a leak after the MAF. What is your A/F at idle, if you remeber? I would check all the pipes leading in. If not there then check all the injector o-rings, the plenum bolts, and the plenum gaskets. You can try spraying carb cleaner around the plenum to try to locate the leak while the car is running. Spray in one area (ie-around the front of the plenum) and listen for changes in idle. The injectors may be really hard to get to so you may have to take the plenum off and visually check.
Old Jul 28, 2005 | 05:46 PM
  #48
ryan350zpower
what about the misfiring at idle???? why am i having all these problem!!! we also changed the spark plugs to one step colder.... would that be bad or hurt anything???
Old Jul 28, 2005 | 05:50 PM
  #49
projectsherv's Avatar
projectsherv
My car also misfires at idle, I would also like to know how to correct this issue. Btw, I am running stock plugs at the moment.
Old Jul 28, 2005 | 06:06 PM
  #50
ryan350zpower
hows ur a/f?
Old Jul 29, 2005 | 07:10 AM
  #51
one3502nv's Avatar
one3502nv
5th gear is 1-1 ratio on the Z and will give you the most accurate numbers... Some people have dyno'd in 4th due to the fact that the car will do almost well over 130 in 5th
Old Jul 29, 2005 | 04:23 PM
  #52
MIAPLAYA's Avatar
MIAPLAYA
Ryan I pmd you,...
Old Jul 29, 2005 | 10:42 PM
  #53
SirMikel1's Avatar
SirMikel1
ATX uses the dyno dynamics chassis dyno. It's a load dyno so it doens't matter what gear you dyno at. the ratio is usually always 1:1
Old Aug 23, 2005 | 03:53 PM
  #54
DXB350Z's Avatar
DXB350Z
any updates Ryan?
Old Aug 23, 2005 | 07:07 PM
  #55
ryan350zpower
right now, im driving the car all time and its running great... no pinging at all even with that a/f. So, im leaving it for the time be, but im gonna do a return fuel system and richen it up a bit so i can really get on it with that feeling in my stomach saying this could be my last race...lol Other wise, my car is gonna be put in a magazine called RIX very soon... there gonna be shooting me next month i believe...
Old Aug 23, 2005 | 09:43 PM
  #56
Speed Dreams's Avatar
Speed Dreams
Congrats on the future mag exposure of your ride. As for your A/F issue I would look for leaks specialy aft maf. Every flash I have seen from TN or TS on the kit has been rich,between 10.1-10.6,your reflash shouldn't be that lean...
Old Aug 24, 2005 | 08:51 AM
  #57
MIAPLAYA's Avatar
MIAPLAYA
In speaking with Ryan he also had some non-descript (read cheap gas) in the car during the install. He runs only the good stuff now but that could have made the AFRs a little off as well.
Old Aug 24, 2005 | 09:19 PM
  #58
Speed Dreams
I think he has another issue going on other then low grade fuel....
Old Aug 24, 2005 | 10:17 PM
  #59
homiusang's Avatar
homiusang
Subscribing....definitely keep us posted on this
Old Aug 25, 2005 | 08:42 AM
  #60
MIAPLAYA's Avatar
MIAPLAYA
Well thats why I suggested to him that he should get a wideband for his car. I don't trust tail pipe sensors nearly as much as a wideband before the turbo. Furthermore he mentioned that his car is not pinging at all under any load...
