How rich is too rich?
Old Jul 22, 2005 | 02:33 AM
kcobean's Avatar
kcobean
Default How rich is too rich?
Wondering what A/F ratio is considered "detrimental" to an engine? I might need to drive my car for a few days with the A/F in the 9's in certain RPM ranges until a solution can be applied, but I don't want to harm the car. Any input appreciated.
Old Jul 22, 2005 | 08:26 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
i had a similar discussion/ question for my guy here...the consensus (not based off any concrete data) is that below 10:1...getting into the 9's... is territory for cylinder wash
Old Jul 22, 2005 | 08:49 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
oh lord....if that were only true
there is more to "detrimental" than just an AFR
many man many stock cars run AFR's in the 9's
if the motor can't rev, it's too rich
that being said, in the 15 years I ahve been modding cars, from turbo to NA, I have never, not once seen a bore washed cylinder
Old Jul 22, 2005 | 09:01 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
did i say 9...i meant 6:1 hahahaha
Old Jul 22, 2005 | 09:32 AM
kcobean's Avatar
kcobean
So is it safe to assume that for now, I'm ok at 9.0:1 until we can get a solution in place to raise it? I'm not talking about taking it out to the track or anything, just around town type driving. I know that timing is being appropriately adjusted, is there anything else I should be concerned about?
Old Jul 22, 2005 | 10:31 AM
UnderPressure's Avatar
UnderPressure
9.0:1 ?
Um... be sure to change the oil afterwards.
In modern engines it is very difficult to score the cylinder bore itself from too much fuel. The more likely damage will be from fuel contaminating the oil leading to, mostly likey, a rod bearng being destroyed. I have seen this happen before.
Is there no way to adjust the baseline feul pressure on your car? I thought you had AAM's rails and reg installed, or you still rockin' the stock fuel system?
Old Jul 22, 2005 | 10:34 AM
kcobean's Avatar
kcobean
Still using the stock system, minus pump and injectors....
Old Jul 22, 2005 | 11:51 AM
UnderPressure
That explains the problem right there. haha
You could always add Tolulene or Methanol to the fuel to lean things out a bit. Wouldn't hurt in the power output department either.
Hopefully you'll get everything worked out soon, good luck.
Old Jul 22, 2005 | 05:15 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Can you name a few modern cars that run 9's from the factory? And I am not talking about racing muscle cars.
I assume you are refering to gasoline based motors?
My VQ bogs at precisely 9.0:1 A/F ratio...and feels really nasty and sluggish anywhere in the 9's.
Kelly, if you have one or two brief spots of 9:1 A/F, I wouldnt worry about it. The engine sees very little time at WOT, when compared to part throttle operation.
Old Jul 22, 2005 | 06:02 PM
kcobean's Avatar
kcobean
Cool, thanks Sharif. I'll keep out of it until this gets resolved.
Old Jul 22, 2005 | 07:14 PM
joeymia's Avatar
joeymia
Lance Evolutions 8's run in the 9's stock...
Old Jul 22, 2005 | 07:43 PM
xxlbeerZ's Avatar
xxlbeerZ
With MUCH lower compression.
Juztin
Nov 22, 2015 07:03 AM
