running 'cooler' plugs...
Old Jul 27, 2005 | 10:26 AM
matt sherman's Avatar
matt sherman
Default running 'cooler' plugs...
I was reading up on the stillen s/c kit and it says that you have to replace your plugs with 1 step cooler plugs. I'm curious what effect that has? Should this be done regardless what f/i system you with or is it just simply with the stillen kit?
Matt
Old Jul 27, 2005 | 11:57 AM
CpraceZ's Avatar
CpraceZ
Any force induction I do recomend cooler plugs NGK LFR6AIX-11 if you need some I have some in stock just shoot me a PM
Old Jul 27, 2005 | 02:45 PM
matt sherman
I'm still curious why though. What do they provide vs. oem plugs...
Matt
Old Jul 27, 2005 | 05:38 PM
SSR Engineering's Avatar
SSR Engineering
Matt
A “cold” plug transfers heat rapidly from its firing end into the cooling system and is used to avoid core nose heat saturation where combustion-chamber or cylinder-head temperatures are relatively high. A “hot” plug has a slower heat transfer rate and is used to avoid fouling under relatively low chamber or head temperatures. What’s confusing is that a “hotter” (higher performance level) engine requires a colder plug because more power equals higher cylinder temperatures.
Old Jul 27, 2005 | 07:55 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
^^^nicely put^^^
With forced induction, at WOT, your engine is experiencing much more cylinder pressure and heat, which can lead to detonation. A hotter plug can contribute to this, so most people will run a slightly colder plug.
NA cars can run standard temp plugs without any issues.
Old Jul 28, 2005 | 05:54 AM
matt sherman
Thank you.
Matt
apex locator
Jul 23, 2021 02:27 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
