Fuel Pressure Gauge - Send Unit ?
Old Aug 4, 2005 | 11:04 AM
thebigsadler's Avatar
thebigsadler
Default Fuel Pressure Gauge - Send Unit ?
I did a search and came up with 3 results that didn't really help me out too much. I am assuming that I need a brass T, that accepts 5/16" fittings/barbs, that I can run inline on a fuel send line (from the tank to the fuel rail)?
Is there another solution to just getting barb fittings and some hose clamps?
I attached a picture I came across that shows a fuel send unit installed, the Defi send unit is set up similarly, except it is hardwired into the send unit instead of having a clip that clips onto the sender. I am guessing I will just need to take the send unit into the hardware store with me and match up a fitting size to it.
Old Aug 4, 2005 | 11:16 AM
MIAPLAYA's Avatar
MIAPLAYA
Yes the alternative is the AAM fuel pressure block adaptor that bolts onto the factory fuel condensor...heres some pics...
Top right...look for the brass colored cannister
Far right look for the white label on the wires...just forward of that is my sensor screwed into the adaptor
Old Aug 4, 2005 | 11:20 AM
thebigsadler
I am completely lost in those pictures, I can't really tell what you are trying to get me to look at? Sorry... I probably can't get one of these delivered to my house by tomorrow either? Doing the install on saturday...
Old Aug 4, 2005 | 11:25 AM
MIAPLAYA's Avatar
MIAPLAYA
OK well almost all fuel pressure sending units are the same. Sensor is 1/8" NPT. In my case I used the adaptor from AAM to tap for fuel pressure. This is the adaptor
The next two pics show where the adaptor installs (without cutting any fuel lines) The sensor screws into the adaptor and is seemless install wise. AAM can probably overnight one to you if you call them
Attached Thumbnails Fuel Pressure Gauge - Send Unit ?-pic13.jpg   Fuel Pressure Gauge - Send Unit ?-pic16.jpg
Old Aug 4, 2005 | 01:01 PM
thebigsadler
Seems like I missed out on AAM's initially pricing.. I am going to "inspect" that area of the engine bay and see how tough it would be to just do a brass fitting; I'd rather use something much cleaner though.
Old Aug 4, 2005 | 03:11 PM
narkotic's Avatar
narkotic
Your other right Mia....
Old Aug 4, 2005 | 03:55 PM
MIAPLAYA's Avatar
MIAPLAYA
yup i'm a dumb@ss...sorry
Old Aug 4, 2005 | 04:59 PM
thebigsadler
I really wasn't going to post that.. but I knew I wasn't retarded. Haha.
Thanks for the instruction MIA, much appreciated, now all I need is the beer.
Old Aug 4, 2005 | 05:01 PM
MIAPLAYA's Avatar
MIAPLAYA
Absolutely....might I recommend Sierra Nevada Big Foot Ale....or the old tried and true Corona...
Old Aug 4, 2005 | 05:21 PM
thebigsadler
Corona it is my man...
Old Aug 4, 2005 | 05:24 PM
theking's Avatar
theking
I heard left is the new right(I'm an idiot I know) I was just checking the specs on the rotary gurter!
Old Aug 4, 2005 | 05:42 PM
MIAPLAYA's Avatar
MIAPLAYA
It is man....oh and up is the new down....LOL I'd fix it but it would make the subsequent posts pointless....
Old Aug 4, 2005 | 05:48 PM
MIAPLAYA's Avatar
MIAPLAYA
Hey good choice. Let me know if you need any more help on that. Hell if you want how bout taking a few pics while you do it then to save you some typing just use my write up and insert pics and post it....Next thing you know you just helped the next guy....its all about helping out...or at least it should be...
Old Aug 4, 2005 | 06:05 PM
thebigsadler
One step ahead of you my friend.. http://g35driver.com/forums/showthread.php?t=62438
apex locator
Jul 23, 2021 02:27 AM
