APS TT kit vs Turbonetics kit dyno overlayed
Old Aug 22, 2005 | 02:21 AM
  #181
Peking's Avatar
Peking
Alrighty, and thanks guys.
Old Aug 22, 2005 | 07:21 AM
  #182
kcobean's Avatar
kcobean
Originally Posted by Z PHAT Z
I'm a noob at this, so If i'm going to change my O-ring; do i need to do the pressure relase step? TIA.
Are you referring to the o-rings on the injectors? I'm not sure if you would need to for that task since you're on the far side of the pressure regulator at that point, but it couldn't hurt. My take is that any time you're going to 'break the seal' on the fuel system, you should run the pressure release. It only takes a few minutes to do it, and the alternative is, well....not fun.
Old Aug 22, 2005 | 07:42 AM
  #183
Z PHAT Z's Avatar
Z PHAT Z
The O-ring that go at the bottom of the fuel pump to seal it. Im' not too familiar with it, but due to the O-ring expanded and wouldn't fit cause a fuel leak. I'm about to change a new O-ring. Hope I explained clearly
Old Aug 22, 2005 | 07:51 AM
  #184
kcobean's Avatar
kcobean
Yep, you explained clearly. Definitely run the pressure release procedure.
Old Aug 22, 2005 | 10:31 AM
  #185
Peking's Avatar
Peking
kcobean
Did you do the modifications to your Fuel Pump Regulator? Or just clip the clips on the outside of the Walboro Fuel pump so it would fit?
Old Aug 22, 2005 | 10:53 AM
  #186
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by Peking
kcobean
He did them....including the FPR...
Old Aug 22, 2005 | 12:01 PM
  #187
kcobean's Avatar
kcobean
He he...what he said. We chased the "richness ghost" in my car for awhile before calling it quits. I'm making great power and doing it safely, so I'm fine until I can piggyback it and tune.
Old Aug 22, 2005 | 06:27 PM
  #188
Peking's Avatar
Peking
Ok so even with the FPR modifications you are still rich, really rich. I guess I will be calling it quits as well
Old Aug 22, 2005 | 06:51 PM
  #189
MIAPLAYA's Avatar
MIAPLAYA
Well kcobeans car was an enigma for sure. My car was running to rich without the FPR mod but after the AFR was dead on. The Walbro was a last minute introduction to the kit if you remember. Honestly bro check your fuel pressure first. Its fairly quick to do with the right tools and will at least let you know where you are at. If you are at more then 55-58 PSI then you should DEFINITELY do the FPR mod.
Old Aug 22, 2005 | 08:27 PM
  #190
Peking's Avatar
Peking
Wonder how I am going about it though, I don't have the gauge or tools I guess to measure... Can't think of a shop around here that I would trust to check it correctly on top of working with my schedule since I spend alot of time at work.
So I might just do the fuel pump modification at this time anyway this Sunday... Drilling ain't so bad
Old Aug 22, 2005 | 09:29 PM
  #191
Speed Dreams's Avatar
Speed Dreams
Thumbs up
Old Aug 22, 2005 | 09:31 PM
  #192
Speed Dreams
Thumbs up
Old Aug 22, 2005 | 10:55 PM
  #193
NYC_G35C's Avatar
NYC_G35C
[offtopic]
Z PHAT Z, where did you get your install of the single turbo done? i'm a few hours south of you (in the city) but i was curious
Old Aug 23, 2005 | 05:03 AM
  #194
kcobean's Avatar
kcobean
If I may suggest it, AAM makes a fuel pressure adaptor block that fits right onto the fuel pressure regulator and includes a fuel pressure gauge. It's not an "in-cockpit" solution, but it will allow you to check your idle pressure and you can have someone watch your pressure while on the dyno. The adaptor is only like $100 and you can put it on yourself in about 10 minutes. We used it to check my FP and it's a great solution.
Old Aug 23, 2005 | 08:52 AM
  #195
Peking's Avatar
Peking
Would that come with their AAM SPec Return Complete Return Fuel System?
Old Aug 23, 2005 | 09:14 AM
  #196
MIAPLAYA's Avatar
MIAPLAYA
Not sure if it comes with the fuel system but I have the same fuel pressure adaptor and that is where my fuel pressure sensor is tapped. It then runs wires into the car and connects to my fuel pressure gauge... pics:
adaptor:
adaptor installed with sensor. Look far left where there is a white tag around some wires:
gauge:
Old Aug 23, 2005 | 04:12 PM
  #197
Peking's Avatar
Peking
Well I def. will be considering it, along with a fuel pressure gauge then.
Also I sent back my ECU Monday to Technosquare, and talked to Brian before and after. He says I should be closer to 11.5 now, and def. agreed with the FPR modifications were most likely the reason for my richness. So I should be getting it back tomorrow, put her in and see how it goes... Since I haven't done the FPR mod yet, he said it may be erratic when it comes to my A/F.
But I had to send it back, cause my idle was way to low anyway and while driving my car on Saturday it had turned off a couple of times after sending my ECU last week for a re-flash.
Old Aug 23, 2005 | 04:16 PM
  #198
MIAPLAYA's Avatar
MIAPLAYA
Ahh ic...so your idle was set to 750? It should be at 900. Yeah a fuel pressure gauge would be very helpful...
Old Aug 23, 2005 | 04:19 PM
  #199
JimRHIT's Avatar
JimRHIT
Originally Posted by NYC_G35C
[offtopic]
You are a good long ways away from him. He is 20 minutes outside of Buffalo
Old Aug 23, 2005 | 05:13 PM
  #200
Peking's Avatar
Peking
Well below 1K the notches are kinda funny so I estimate. But it is much lower than before (or well after the first flash from Turbonetics).
