APS TT kit vs Turbonetics kit dyno overlayed
Old Aug 23, 2005 | 05:54 PM
  #201
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by Peking
Well below 1K the notches are kinda funny so I estimate. But it is much lower than before (or well after the first flash from Turbonetics).
Well your idle should be at 900. Just barely below the 1 that is....
Old Aug 23, 2005 | 06:07 PM
  #202
Z PHAT Z's Avatar
Z PHAT Z
Mine is just below 1k, but it will sometimes drop down to 750 for a few seconds then back up to 900.
Old Aug 23, 2005 | 07:48 PM
  #203
Peking's Avatar
Peking
Yeah, talked to Brian and he said it would be no problem to raise it again.
Old Aug 23, 2005 | 08:06 PM
  #204
taurran's Avatar
taurran
Mine sits at 900. If I turn on the AC it goes to about 1k
Old Aug 23, 2005 | 08:11 PM
  #205
kcobean's Avatar
kcobean
Ditto
Old Aug 23, 2005 | 09:05 PM
  #206
Speed Dreams's Avatar
Speed Dreams
Well I def. will be considering it, along with a fuel pressure gauge then.
Also I sent back my ECU Monday to Technosquare, and talked to Brian before and after. He says I should be closer to 11.5 now, and def. agreed with the FPR modifications were most likely the reason for my richness. So I should be getting it back tomorrow, put her in and see how it goes... Since I haven't done the FPR mod yet, he said it may be erratic when it comes to my A/F.
But I had to send it back, cause my idle was way to low anyway and while driving my car on Saturday it had turned off a couple of times after sending my ECU last week for a re-flash.
Stay with it,the tweeking can drive you nuts....
Your on the right track and will get there.
Old Aug 23, 2005 | 09:07 PM
  #207
kcobean's Avatar
kcobean
On the same lines, what do you guys think about adding a a plenum spacer to my car to try and lean things out a bit?
Old Aug 23, 2005 | 09:14 PM
  #208
Speed Dreams
Haven't played with spacers but they have had good reviews and are cost effective.
Old Aug 23, 2005 | 09:32 PM
  #209
Z PHAT Z's Avatar
Z PHAT Z
If the plenum spacer and the Crawford plenum work the same way, then you can see that i'm not any leaner. You can see my A/F graph that i'm running rich as well.
Old Aug 23, 2005 | 09:39 PM
  #210
kcobean's Avatar
kcobean
So would we deduce then that with or without the spacer the ECU is using the last map (the RPM only one) to control fuel, and Airflow is basically irrelevant?
Old Aug 24, 2005 | 11:10 AM
  #211
Peking's Avatar
Peking
Yeah so did mine after the Turbonetics flash and before the Technosquare flash. Supposedly it will be back around there again
Yeah, there have def. been moments were I want to give up and take the whole kit off and go back to stock and trade the car in... But I always said whatever I get aftermarket gauges in I will be keeping till the wheels fall off It just sucks cause I can't take the needed time from work to really get involved in finding the kinks.
I was planning on as well to upgrade to the Crawford plenum when I went to get the EU installed and tune'd. Figure it will be more helpful then the OEM one.
Old Aug 24, 2005 | 11:39 AM
  #212
taurran's Avatar
taurran
I'm not sure the effect of the plenum spacer on the AFR, but I'd assume it would lean the mixture out slightly. I plan on eventually dropping in an AAM spacer, but that will be around the new year.
EnjukuRacing
Sep 30, 2015 06:55 AM
