TurboXS Announces the Z UTEC Release
Old Oct 12, 2005 | 09:46 AM
  #141
35ounces's Avatar
35ounces
03 CS Track 6MT
Hmmn. I'm still on the fence between UTEC and EU. At twice the price of the EU are there obvious and significant advantages to going with the UTEC over the EU?
PM me if you have opinions that you do not want to post. Thanks.
A GB would be a great way to promote entry into the market...too bad.
Old Oct 12, 2005 | 09:55 AM
  #142
GregGSC's Avatar
GregGSC
The Utec's that we have used on Sti's and Evo's are great. I am exteamly excited that it will be avalible for the Z, and i hope the tC is in line next. it really is easy to tune with and actually works very well. I don't know much about the EU but at $1000 really isn't to high it will be worth the investment.
Old Oct 12, 2005 | 10:08 AM
  #143
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I think he meant respective
Advantages of a UTEC over an Emanage - off the top of my head:
plug and play installation...no wiring or soldering needed
Ability to adjust maps on the fly via the remote switch, and store multiple maps on the UTEC board itself
no need for even a windows based laptop...does it via Hyperterminal
MUCH easier to program (I find) than the E Manage. IN fact it's much easier to make adjustments on a UTEC than it is on any standalone I've ever used as well.
Old Oct 12, 2005 | 10:16 AM
  #144
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
^^^And the ability to "Set" the timing advance, rather than offset", not mention true knock feedback control for timing. ^^^
Old Oct 12, 2005 | 11:29 AM
  #145
ThetunerFestNJ's Avatar
ThetunerFestNJ
So much for the group buy
Old Oct 12, 2005 | 02:01 PM
  #146
mchapman's Avatar
mchapman
Why wouldnt it be warranted if its from a group by? To make people not want to purchase it from a group buy, so the price doesnt go down making the product look cheaper?
Old Oct 12, 2005 | 02:22 PM
  #147
35ounces's Avatar
35ounces
03 CS Track 6MT
Thanks, thats some very impressive endoresements coming from Adam and Sharif.
I'd like to understand one thing regarding the install, is it truely a plug and play where it simply goes into the ECU slot and there is no wiring and no harnesses to buy like there is with the EU?
One other question also, my ECU has been reflashed by TNetics. I assume I do not need to go back to the base flash before using the UTEC?
Old Oct 12, 2005 | 02:28 PM
  #148
ThetunerFestNJ
Hmmm..Going back to a base flash would not be a bad idea.
Old Oct 12, 2005 | 05:59 PM
  #149
Z1 Performance
Former Sponsor
it is 100% plug and play. Unplug your ecu from the harnesses - harness plugs into the utec, and ecu plugs into the utec....done.
You do not have to go back to your stock map if you don't want to. I assume you have a TN turbo kit? If so, by leaving it alone and plugging a utec in, this will be the map you are modifying. If you choose to get the remote switch, this will be your 0 Map. This means the UTEC is a pass through and is not involved in the operation of the ecu at all. So, if you are tuning, and get too far afield, turn the switch back to zero and you are back to your TN base map.
From there you can have 4 additional maps that can be stored on the utec....higher boost + pump gas - no problem. Race gas map? no problem. It truly is a world class setup that is very logically setup. Add in the TXS Tuner, and now you have a wideband plug and play engine mgmt solution so you can tune/datalog your car using real time wideband
adam
Old Oct 12, 2005 | 06:04 PM
  #150
35ounces's Avatar
35ounces
03 CS Track 6MT
Thanks Adam that was very helpful to me. Yes TN kit. Sounds much easier than wiring in the eManage with diodes etc. and seems to have more flexibility.
Old Oct 12, 2005 | 06:38 PM
  #151
gringott's Avatar
gringott
I have a Power Enterprise TT kit installed, base boost, no reflash. I have been patiently waiting for something like this. I am not a tuner. Will there eventually be some base maps that will be useful for my application? I am especially interested in the ability to have engine management that is "boost aware".
The reflash to up the boost that is the current method for the PE kit is not, IMO, good for someone like me who is in Kentucky, not Cali. If the reflash caused me to run lean, I would be stuck running a dyno, mailing the ecu to cali with the dyno sheet, etc. Not good.
Next question: Who can tune the Z with this in the Kentucky area?
Thank you.
Old Oct 12, 2005 | 06:44 PM
  #152
failsafe306's Avatar
failsafe306
May I have one?
Old Oct 12, 2005 | 07:09 PM
  #153
ThetunerFestNJ
Originally Posted by failsafe306
May I have one?
Actuallt the map Jermain has right now will work on your set up.650cc rc's and APS TT with 12lb actuators..
Old Oct 12, 2005 | 07:33 PM
  #154
failsafe306
That's it, I want one for sure. I hope I can get ahold of one by the time my car's ready for tuning at GRD. You said it'll be this month right?
Old Oct 12, 2005 | 07:36 PM
  #155
ThetunerFestNJ
I think that what Jermaine was shooting for.
Old Oct 12, 2005 | 07:38 PM
  #156
failsafe306
I hope so, cause I don't know how well the Unichip will handle high hp and larger injectors. I don't want to have to reflash my ECU for the 650's if I don't have to.
Old Oct 12, 2005 | 08:43 PM
  #157
aalzuhair's Avatar
aalzuhair
I have a few questions:
1) Can the unit control the speed limiter and rev limiter?
2) What are the biggest size injectors that this unit can support?
3) Can you control idle using this unit?
4) Can this unit read additional sensors in addition to stock sensors?
5) Can this unit compensate the fuel and/or ignition map based on the sensors readings?
Thanks,
Az
Old Oct 13, 2005 | 08:37 AM
  #158
BlackTuner's Avatar
BlackTuner
Hello Guys and maybe Girls,
As of 10/12/05 we have realeased MSRP of $1049 for the Z UTEC. We will be releasing much more information as the days get closer to the release date. We are doing some killer software changes that should make the UTEC top choice.
Now to answer your questions
I have a few answers
[1) Can the unit control the speed limiter and rev limiter?
The UTEC will be able to control rev limit and speed limit. As of right now we are making software changes but if not in the initial release our software update will allow for these addition's. As will all of our UTEC's Upgrades, software is always free! That's right FREE!
[2) What are the biggest size injectors that this unit can support?
We are using 650cc's as of now on Julian/MRC's Vehicle. I have no doubt in my mind that you wouldn't be able to use 1000cc's or larger.
[3) Can you control idle using this unit?
We do have the ability to control idle because we will driving the DBW. This will not be available at initial purchase. Why do you need idle if I may ask? We are runing 650cc's and the car idles so nicely you can't even tell it is modfied.
[4) Can this unit read additional sensors in addition to stock sensors?
Yes, the UTEC combined with the TUNER (AFR) can read EGT and Intake Temp.
[5) Can this unit compensate the fuel and/or ignition map based on the sensors readings?
The current software allows temp compensations for fuel and timing.
Thanks, Jermaine.
Old Oct 13, 2005 | 10:56 AM
  #159
ThetunerFestNJ
As always, Jermaine is on top of his game!! This thing sound like its going to be HUGE!!
Old Oct 13, 2005 | 07:06 PM
  #160
ThetunerFestNJ
Whats the release dat Jermaine?What kind of maps will be in the utec for N/A and for F/I? and what is the cost of the MAP sensor for the F/I one?
