Profec E-01 users.. HELP!!
Old Sep 11, 2005 | 04:54 PM
mazx6's Avatar
mazx6
Default Profec E-01 users.. HELP!!
Profec E-01 users.. HELP!! Alright guys here is my problem, i went to a dyno shoot out the other day, so i put my boost at 6.5 psi. I usally have it @ 5.6 psi. So i went to boost level put it at 6.5. During the dyno pull it said the peak was only at 6.0. I then moved it to 7 psi for the second run. I made 390 RWHP the first run. The second run i made 407rwhp. Again the boost controller said it only peaked at 6.0psi, but the dyno showed the it made more power.
now.. I was very happy about the power, and i put it back down to 5.6psi. BUT now i can't even get that! the most i have pulled is 5.1 and it usally is only going to 4.8 at the most. In the upper right hand screen it says...
AUTO P. Does anyone know what that means?
here are my settings..
Lo: auto
boost:5.6
gain:10
start boost : 2.8
what i have done wrong to where it will not boost where i tell it to? I was fine before the dyno run?
Old Sep 11, 2005 | 05:23 PM
westpak's Avatar
westpak
SFZCC
I think the problem is that when you set it to Auto you can't just switch between new boost settings without relearning the auto setting again, manual mode is probably best for that. I never got auto to work for me so I just use manual.
Old Sep 11, 2005 | 08:31 PM
mazx6's Avatar
mazx6
thanks for the advice. What are your settings as far as gain and start boost?
Old Sep 12, 2005 | 04:50 AM
westpak's Avatar
westpak
SFZCC
Gain is at 10 and start boost is at 5.5 but that is running at 8 psi.
For running stock I would have set at 0, gain at 10 and start boost at 3, with this setting you can find out what your stock boost is and then you can adjust fromt there. The "set" number is a percentage of stock boost so if you stock boost is 5.5 a set of 10 would be about .5 pounds added to the stock boost, the start boost is suggested to be no closer than 2 psi to your target boost or you will overshoot.
Old Sep 12, 2005 | 06:25 AM
mazx6's Avatar
mazx6
thanks again, it seems like you always reply to my post when i have problems... i apperiate it!
Old Sep 13, 2005 | 08:49 AM
mazx6's Avatar
mazx6
hey man i thought i would tell you, I got the AUTO mode to work! I decided to read the manual.. I had to go out and make 6-8 passes in 3ed gear and the AUTO P went off the screen and has now learned my boost and is boosting fine to 5.6psi perfectly. This is a pretty neat feature.
Old Sep 13, 2005 | 11:05 AM
westpak's Avatar
westpak
SFZCC
Great, I guess I will give the Auto feature another shot.
Old Sep 13, 2005 | 02:46 PM
Wholey Smokes's Avatar
Wholey Smokes
Yeah, read the manual. It's not that hard, but make sure you have a long empty road when using the auto learn function. The "Start Boost" feature is kick ***. I was getting frustrated with the E0-1 when I first bought it (Sometimes I think I'm too good to read manuals ) but after I finally spent a couple minutes with the manual it was smooth sailing.
Old Sep 13, 2005 | 02:48 PM
westpak's Avatar
westpak
SFZCC
I have read the manual and tried it on the open highway but even after learning the boost it would spike so I went back to manual mode.
Old Sep 13, 2005 | 03:05 PM
Wholey Smokes
I wonder if the ambient temperature while you were using the auto learn could have played a roll. Probably not but it's an idea. I was getting some boost spikes the first time I used "Auto Learn" but then I tried it again early in the morning and the spikes went away.
Old Sep 13, 2005 | 10:45 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
ive never been able to get the auto mode to work
Old Sep 14, 2005 | 03:54 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Auto mode is bit tricky. It works on some cars, and not on others.
The difference in dyno runs is to be expected, even with stable boost pressure between runs.
Old Oct 15, 2005 | 05:41 AM
nitrous350's Avatar
nitrous350
Question
Dear Westpac
I got little question about e-01
this is my input
1> 0% -> 10gain -> 3 start boost = about 6psi
and this is my manual setting
2> 40% -> 25gain -> 4.5 start boost = about 7.8psi
3> 40% -> 15gain -> 4.5 start boost = about 6.7psi
could you give me a some number if my target boost is 11
cause whene i read Greddy e-01 manual i got lost
1> setting % number is increase/decrease target boost
2> Gain number is faster/slower turbo response....
Old Oct 15, 2005 | 03:28 PM
nitrous350's Avatar
nitrous350
Pls !!!!!!!!!!!!!!
bcoffee20
Nov 19, 2015 06:39 PM
zimbo
Aug 29, 2004 06:08 PM
zimbo
Aug 14, 2004 03:27 PM
zimbo
Jul 30, 2004 02:51 PM
jimster716
May 18, 2003 09:02 PM
