450 whp @ 8.5-9 psi
Old Sep 14, 2005 | 06:19 AM
mcderns's Avatar
mcderns
Default 450 whp @ 8.5-9 psi
I went yesterday and got the car tuned, by Charles who now works at Super Viper Systems (svspower.com), and boost turned up. I am making 452hp and 419tq on 8.5-9psi. The car still needs some minor messing with. Boost is fluctuating in upper rpms, hopefully if I adjust the BOV it will fix it. And it overboosts sometimes. I have to dial in all the settings on the boost controller to get it all right. We had a ***** of a time getting the tune good. We made about 40 dyno passes, and the first 30 of them could have been thrown out the window. There was a loose clamp on the intake pipe by the throttle body, so air was getting out up there. Which is after the MAF which was causing all kinds of problems with a/f and boost. Once we fixed that, it was smooth sailing(except for the figidy boost controller). All in all, the car pulls like hell, and its fuggin fast! I have newfound respect for the car at this power level. A jump from 345 to 450 makes a huge difference. We even heard the tires break loose for a sec in 4th gear on a test run. Anyhow, heres the dyno chart, and thanks Charles!!
Old Sep 14, 2005 | 06:48 AM
Z33Concept's Avatar
Z33Concept
Nice Track Mc..... Good Shyt Charles!!!!!!!!!!!!
Old Sep 14, 2005 | 07:13 AM
turbo-maxima's Avatar
turbo-maxima
fix that boost problem then go back and fix that a/f. Man the boost is making it jump all over the place.
Old Sep 14, 2005 | 07:14 AM
phunk's Avatar
phunk
CJ Motorsports
thanks ron. we will fill in that rich roughness in the sea of too rich when we can get it to hold consistent boost.
Old Sep 14, 2005 | 07:25 AM
VR3's Avatar
VR3
Great numbers for 9psi!
Old Sep 14, 2005 | 07:42 AM
KraftG35's Avatar
KraftG35
Gotta love twin turbo. Nice job Charles and Ron.
Old Sep 14, 2005 | 07:46 AM
002-M-P's Avatar
002-M-P
Nice numbers man. Good luck at SVS Charles, seems like that would be an awesome company to work for.
Old Sep 14, 2005 | 09:42 AM
z33boi's Avatar
z33boi
dont you just love having twins
Old Sep 14, 2005 | 10:48 AM
taurran's Avatar
taurran
Wow that's very impressive. Hard to believe you're getting so much power while running so rich.
Old Sep 14, 2005 | 10:52 AM
phunk's Avatar
phunk
CJ Motorsports
the peak numbers are at about 11.5:1 A/F, which is a pretty typical A/F on a stock engine 350z with twins... not exactly what I would call rich in this situation.
The midrange of the powerband is very rich and jumpy, as the boost was fluctuating too fast for me to get a good tune, so I left it as a safe tune for now.
mcderns's Avatar
mcderns
I know right, and it was 90+ degrees out. I am a happy guy right now!
Old Sep 14, 2005 | 11:06 AM
Landbarger's Avatar
Landbarger
So are we done seeing new stuff for the Z from you, Charles, or does the fact that there's a Nissan 350Z slot on the SVS website mean that there might yet be some tricks coming out? (I hope) And is there a thread about that CJM Intake Manifold listed in your sig and I've missed it, if not I think we need to start one to keep up with progress.
mcderns- looks like a lot of fun, hope you get your tuning issues worked out.
Old Sep 14, 2005 | 11:10 AM
mcderns's Avatar
mcderns
I dont think your done seeing new stuff coming from CJM. And soon enough everything will be all sorted out.
Old Sep 14, 2005 | 11:42 AM
002-M-P's Avatar
002-M-P
I can't wait, I need a fuel system.
Old Sep 14, 2005 | 01:24 PM
Johntuki's Avatar
Johntuki
Very nice numbers. What is the pipe diameter on the Borla TD? Sorry I know I could probably search it but im lazy.
Old Sep 14, 2005 | 01:33 PM
bigbri's Avatar
bigbri
Good #s you have cams....?? Didn't see them in your sig so I'm guessing not....I'm at 470whp at 8lbs of boost so our #'s our about the same....add some cams and pick up and easy 25-35hp... bet your loving your car...mines still getting more work done....
Old Sep 14, 2005 | 02:37 PM
Jaki's Avatar
Jaki
Great numbers! That just proves what a kind of numbers a great tune can give you!
Old Sep 15, 2005 | 07:18 AM
mcderns's Avatar
mcderns
Nope, no cams. I know I would get some good gains, but I am happy where I am at for now. Broke too! Maybe I will toss a plenum on or something, but nothing for a little bit. Maybe winter time.
Old Sep 15, 2005 | 04:18 PM
imtiaz's Avatar
imtiaz
mcderns, is that all on stock block and internals?
Old Sep 16, 2005 | 09:49 AM
mcderns's Avatar
mcderns
Yup. Stock block and internals.
apex locator
Jul 23, 2021 02:27 AM
bcoffee20
Nov 19, 2015 06:39 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
