Block?'s
Old Sep 20, 2005 | 04:28 PM
denchan350gt's Avatar
denchan350gt
Default Block?'s
I plan on getting a ST or TT soon and want to get a built motor thru SGP for peace of mind. Will a built short or long block do or do I have to just replace the pistons and rods to handle 600+rwp? Which should I do short, long or just P&R with a 4k budget for the motor? Thanks
Old Sep 20, 2005 | 05:04 PM
Z BOY's Avatar
Z BOY
are you gonna buy a built engine or build up your existing engine?
Old Sep 20, 2005 | 05:22 PM
z33boi's Avatar
z33boi
to be honest i dont think 4k is enuff to build a built motor to handle 600+ but i could be wrong. but i would say go long!
Old Sep 20, 2005 | 05:29 PM
MIAPLAYA's Avatar
MIAPLAYA
Well considering even a used longblock at a killer price is going to run you $1500-$1700 you are already out of your budget. Forged pistons and rods are going to be about $2000 for both. Now factor in labor and shpping and you are WAY over budget. You could purchase a used short block for $1200-1500 and send it to SGP for the Short block package which I think is $3500. Still total cost will be near $5000 for this...
Old Sep 20, 2005 | 05:43 PM
z33boi's Avatar
z33boi
^ to achieve 600+ he's gonna need cams too dont you think?
Old Sep 20, 2005 | 05:46 PM
MIAPLAYA's Avatar
MIAPLAYA
Yes I would think so but I was trying to keep it as cheap as possible in my estimate. To achieve 600 + you are going to need cams, a carbon clutch, better then average management, bigger injectors then any kit offers, the list goes on..
Old Sep 20, 2005 | 06:18 PM
failsafe306's Avatar
failsafe306
Read my sig....it'll get you 600whp safely, if you add good engine mngm't. And better axles. Oh and you'll need as free flowing exhaust as possible; I'm getting a custom 3" true dual w/ test pipes made.
Old Sep 20, 2005 | 06:29 PM
denchan350gt
I haven't decided yet Matt. SGP has short blocks for $2700 and $3700 after the $1000 core rtn. I'm just trying to figure out is it just better to upgrade my pistons and rods or just get the upgraded short block. Derek
Old Sep 20, 2005 | 06:35 PM
z33boi's Avatar
z33boi
well if its jus 3700 with core charge, you can always send them your old shortblock and get the $1000 back
Old Sep 20, 2005 | 06:39 PM
denchan350gt
Thanks for the info Mia. I was thinking about the short block from SGP for $2700 or the one for $3700. I found a place that would do the install for $1500. How good are eagle rods I always hear of people using Pauter rods. Eagle rods is what this package uses. I'm not looking to go over 600+ yet, just between 500-550, but when I decide to do so I want to make sure that my engine can handle it without pulling it again.
Old Sep 20, 2005 | 06:42 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
i made 603rwhp on completely stock head/cams...ming u the numbers were sae corrected...so probably closer to 540 or so actual...
now with my new 3" exhaust, when it gets done, i will retune and dyno...i am running a higher octane fuel (96)...i expect to hit 630-640rwhp sae corrected...approx 560-570 actual....
so, one can probably get very close to 600 with stock cams and heads...much further over that figure, then one would need some new parts
denchan350gt
That's what I'm planning to do. I just wanted to hear the ideas of those who have ventured down this road already or in the know.
Old Sep 20, 2005 | 06:44 PM
denchan350gt
I don't think Sharif is running cams (I could be wrong) and he is over 600+.
Old Sep 20, 2005 | 06:48 PM
g356gear's Avatar
g356gear
Sharif is running JWT's with headwork I believe.
Old Sep 20, 2005 | 06:55 PM
denchan350gt
Did you build your existing motor or is it a new one (block)? I already know I need bigger injectors, cams and other things. I'm just mainly concerned if my block can handle the extra power if I just add P&R to my existing block or just get one already built with the xtra work done to it. Does any one know if any other company besides APS is coming out with a turbo exhaust for our cars in the near future? Thanks
Old Sep 20, 2005 | 07:16 PM
failsafe306
I had my existing block built. Your original block will be just fine if you add pistons and rods, but you'll need ARP head and main studs as well. Plus little things like bearings and new rear main seal.
Old Sep 20, 2005 | 07:26 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
the main thing holding me back was my injectors were close to being maxed out (550's)... i could raise my fule pressure and probably hit 650rwhp...would be much more effecient with headwork/cams and much lee stress to make the same numbers at a lower boost level
Old Sep 20, 2005 | 08:26 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Good parts and good tuning will get you there. Stock cam is doable, although a cam upgrade is a good idea to keep your power increasing to redline...or as close to it as possible.
Pistons, rods, studs, are the basics.
Old Sep 21, 2005 | 09:00 AM
Landbarger's Avatar
Landbarger
Pretty sure SFR (www.speedforceracing.com) is coming out with a huge new exhaust for turbo'd Zs
Old Sep 21, 2005 | 10:25 AM
Sharif@Forged
Forged Performance
Greddy is coming with an EvoTT with 2.75 true dual piping for the 350Z. Kenji has it on his car now...should be a month or so before it arrives in the states. Probably a very good setup for most people.
