Stillen SC Installed
Old Dec 7, 2005 | 02:07 AM
  #81
WA2GOOD's Avatar
WA2GOOD
Originally Posted by STL Lightning
Couple of things - people have been VERY successful on other vehicles with these eaton roots type blowers getting more HP and lower outlet temps through porting the case. Typical HP increase on a Lightning is 30hp. I don't see why the Stillen setup couldn't benefit from this process.....
So far in the Lightning community, the SNOW kit hasn't shown much success besides letting 91octane guys run some additional timing. I'm interested to see if it has better success on the Z's.
-Mark
That might be interesting.
Old Dec 7, 2005 | 07:59 AM
  #82
vision619's Avatar
vision619
Originally Posted by BlackSpec02
Thanks for the info, great looking engine bay. You will love the TT even more I'm sure, although its sad to see what was the most powerful stillen engine (AFAIK) go. Is the new owner on this board?
I would very much like to get the stage 3 set up, why wouldn't the gold pulley work on an 03?
Actually I sold it to a friend of mine and Mark (my friend / mechanic / engineer) will continue to work on it and improve it and offer the upgrade to the public.
Old Jan 17, 2006 | 04:24 PM
  #83
jmcmorante's Avatar
jmcmorante
just ordered mines stage 3 then going 4 but everyone is flaming me. Grrr Im happy though.
Old Jan 19, 2006 | 11:57 AM
  #84
zparts's Avatar
zparts
I helped a friend install the stage 4 kit (ok, I installed the thing), it came with a new computer, Walbro 255 fuel pump, RC injector and pulley and it is BAD ***!!! JUST DO IT!!!
Old Jan 19, 2006 | 01:58 PM
  #85
sukhi's Avatar
sukhi
Hey,
Whats the increase over stage 3? Will a Walbro 190lph suffice or is it a must to get the 255?
Old Jan 19, 2006 | 02:21 PM
  #86
DamianZ's Avatar
DamianZ
that's right, just do it. Nike
Old Jan 19, 2006 | 02:30 PM
  #87
BlackSpec02's Avatar
BlackSpec02
Is there an "official" stage 4 now? Where did you order "stage 4" as a kit?
Old Jan 20, 2006 | 10:23 AM
  #88
superchargedg's Avatar
superchargedg
Damn Noobs
i just spoke to kenny at stillen the stage 4 is ready for sale,didnt ask price though.
Old Jan 20, 2006 | 10:57 AM
  #89
mlg9770's Avatar
mlg9770
ZEnclosures
I talked to Stillen yesterday and they qouted me $850.00. They said this kit adds 30-35 whp more than the Stage 3 kit.
Old Jan 20, 2006 | 01:24 PM
  #90
BlackSpec02
sweet. I just checked the site and its not up yet but im pretty excited about this stage 4 business!! So its a new tune and fuel system? How much boost? Does the system address the extra heat?
Old Jan 23, 2006 | 08:29 AM
  #91
PalFX's Avatar
PalFX
Hello,
I currently have the Stillen Stage 2 installed but I have the option to upgrade to the Stage 4. Before doing so, I would like to know few things:
1) How easy is it to upgrade from Stage 2 to Stage 4?
2) Can it revert back to Stage 2 easily?
3) Is there a new Stillen FMU / Split Second box that will replace the old one?
From what I understand, there is a new smaller pulley and fuel pump but not sure how the tune is applied (is it a new box/computer or the old one gets tuned, etc.). Lastly, is it going to be a fairly safe upgrade.
Thaks and any help is very welcomed.
Old Jan 23, 2006 | 04:28 PM
  #92
PTOWN's Avatar
PTOWN
I will be buying the stillen in may, my ? is what clutch are you guys using? I would like to get that out of the way. Do you reacamend that I install header and exhaust b4 installing kit?
Old Jan 23, 2006 | 09:45 PM
  #93
BlackSpec02
no headers.... maybe exhaust... def. JWT pop charger.
Old Jan 23, 2006 | 10:04 PM
  #94
g35twinturbo's Avatar
g35twinturbo
im actually wondering if i will go the header or high flow cat route. Since still now offers teh ability to tune for headers and or cats...
Old Jan 23, 2006 | 10:20 PM
  #95
350z_this's Avatar
350z_this
where did you hear that? they tell me that headers actually hurt your hp. what they did with the stage 4 is to compensate the headers with a 9lb pulley rather then an 8 lb pulley.... but it will basically produce the same hp..... headers don't help.... exhaust will though.... i'm getting mine in about a week....
Old Jan 24, 2006 | 05:28 AM
  #96
geezin56's Avatar
geezin56
Originally Posted by PalFX
Hello,
The Stage 4 does come with a new box/computer to control the larger injector. Price to upgrade from Stage 2 is around $800-850 before the install. For those of you considering the Stage 4, thought you might be interested in reading through a post of mine from the 350zmotoring site (see below). Hopefully, the problem is just my kit, but I've not seen anywhere near the level of boost that the Stage 4 is supposed to deliver.
I live in Denver and had a Stillen Stage 2 installed on my 04 Z about a year ago. Among other things the Stage 2 kit includes an intercooler, a 7th injector, and a 6 lbs pulley. I recently (w/i last 2 weeks) upgraded to a Stage 4 kit, which I believe Stillen only released fairly recently. The Stage 4 includes a larger 7th injector (to replace the old one), a new electronic unit to modify timing, and obviously a new pulley, which is supposed to produce around 9 lbs of boost.
The Stage 4 install went fine, but when the car was put on the dyno, it only generated around 6 lbs of boost and the peak HP was down slightly from what it was prior to the install (from 295 to 290)? The shop that did the install is working with Stillen to figure out the issue. The guys at Stillen evidently think that the problem might be that the A/F is running a little rich due to the combination of the larger fuel injector that was installed and the fact that I live at altitude. They are suggesting that we reinstall the original 7th injector (smaller) and electronic unit to see if this helps by cutting back on the fuel. Does this make any sense at all? Specifically, can running too rich result in less boost than what the kit should be generating?
Any thoughts are appreciated.
Old Jan 24, 2006 | 11:07 PM
  #97
WA2GOOD's Avatar
WA2GOOD
.........+1....I have seen this same scenario before......not even close to the "Stillen advertised" hp gains.
Old Jan 28, 2006 | 03:03 PM
  #98
mlg9770's Avatar
mlg9770
ZEnclosures
Our club(350Z Club Of Florida) had a dyno day today in Tampa. Here are the results with the Stillen Stage 3....only other performance mod is Injen's SES exhaust.
I am only producing 6 psi with the 7 psi pulley and running rich. Has anyone else run into this problem and if so did you have to upgrade the pulley to get the 7psi?
thanks mike
311 whp
291 torq
Old Jan 28, 2006 | 07:06 PM
  #99
mlg9770's Avatar
mlg9770
ZEnclosures
dyno results
Old Jan 29, 2006 | 12:18 AM
  #100
Silo's Avatar
Silo
What was your stock whp/trp? And can anyone supply a dyno plot including A/F for a stage 2 on a otherwise unmodified car? It would help to determine how far "off" this fuel curve is compared to the intended fueling.
