Turbonetics ST dyno numbers (03 vs 04?)
Old Sep 29, 2005 | 05:29 PM
taurran's Avatar
taurran
Question Turbonetics ST dyno numbers (03 vs 04?)
Hey folks, lately I've been discussing some things with a few other Turbonetics ST owners, and I'm curious as to what whp/tq numbers everyone is getting with the kit. Specifically, I'm interested in differences in whp #s between 2003 and 2004 models on the stock ECU reflash. Generally, it seems (to me) as if those with 03's have been putting down lower whp #s than those with the 04 ECUs.
We know that folks have generally been seeing results anywhere from 350-385whp with the stock reflash. Please post your results in the following format with the information on your car and dyno conditions. Also, include other mods that might effect your power figures.
Year/make/trim: 2003 350z Track
Build Date: 8/02
Transmission: 6MT
Engine Management: TN Reflash
Cat version: No
Dyno type: Dynojet
Max WHP: 360whp
Max TQ: 353ft/lb
Max Boost: 9psi
Average AFR: 11.5:1
Gas: 93 Octane
Weather conditions: ~95 degrees, ~80% humidity
Other Mods: Fujitusbo Legalis-R exhaust, 19x10 Rays G-games Wolf77 wheels
EDIT: I was just informed that they have mutliple reflashes for the different years/transmission/roadster-nonroadster types. I wasn't aware of this previously.
Old Sep 29, 2005 | 05:38 PM
MIAPLAYA's Avatar
MIAPLAYA
Year/make/trim: 2004 350z Base
Transmission: 6MT
Cat version: No
Dyno type: Dynapack
Max WHP: 371whp
Max TQ: 359ft/lb
Max Boost: 8.5 PSI
Average AFR: 11:1
Gas: 91 Octane
Weather conditions: ~89 degrees, ~??% humidity
Other Mods: Apexi World Sport 2 Exhaust, wheels, suspension stuff
Old Sep 30, 2005 | 05:50 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
I was going to wait to post since I have a small leak in the intake due to my MAF housing being cracked, and slightly warped at the flange. However, I will repost with new results after I get re-dynoed. More info is probably better than less info.
Build Date: ???
Transmission: 6MT
Cat version: No
Dyno type: Mustang AWD
Max WHP: 331whp
Max TQ: 358ft/lb
Max Boost: 9.9psi
Average AFR: 11.5:1
Gas: 93 Octane
Weather conditions: ~65 degrees, low humidity
Other Mods: NISMO exhaust, 19x10.5 Rays GT-7 wheels, JWT Clutch/Flywheel, UR Crank pulley, B&M short shifter, suspension
Comments:
dyno'ed with weight set at 3500 lbs
Old Sep 30, 2005 | 06:18 AM
kcobean's Avatar
kcobean
With A/F in the high 9's / low 10's and 10.5-11.0 PSI of boost:
EDIT: I'm dynoing my car tomorrow. I will be sure to post my dyno graph when I get home. I'm expecting with the weather being nice and cool (down in the 70's) and the humidity down that my numbers will be slightly better.
Year/make/trim: 2004 350z Track
Build Date: 11/03
Transmission: 6MT
Cat version: No
Dyno type: Dynojet
Max WHP: 370whp
Max TQ: 370ft/lb
Max Boost: 11psi
Average AFR: 10.4:1(-ish)
Gas: 93 Octane
Other Mods: Modified GReddy EVO2 exhaust, 19" Axis Milano's
Old Sep 30, 2005 | 08:26 AM
1 2 NV's Avatar
1 2 NV
Year/make/trim: 2003 350z Touring
Build Date: 7/02
Transmission: 6MT
Cat version: No
Dyno type: Dyno Jet
Max WHP: 361whp
Max TQ: 380ft/lb
Max Boost: 8.75psi
Average AFR: 12.1:1(questionable do to location of sensor)
Gas: 93 Octane
Weather conditions: ~90 degrees, high humidity (just rained)
Other Mods: NISMO spoiler(at least 10 extra whp!! )
Old Sep 30, 2005 | 10:29 AM
taurran's Avatar
taurran
Thanks guys. I'd like to get as many responses as possible so we can possibly formulate the similarities beween the kits that are making more and less power. Of course, it might very well just boil down to slight differences between each car, and slight variances in the install of the kit. But, maybe we can possibly find some trends that help us determine how some folks are getting better results than others.
One thing I've noticed just from the above replies is that most are having a difficult time maintaining the advertised 8-8.5psi stock boost levels with the stock wastegate. It seems like MIA is the only one with an aftermarket exhaust that has managed to keep it under max 9psi.
Old Oct 2, 2005 | 05:15 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
bump - There's gotta be a bunch more TNetics ST owners out there.
Old Oct 2, 2005 | 10:22 AM
D350Z10's Avatar
D350Z10
I have to break in my kit, Just WAS INTALLED this past friday.. i finally finished! Will dyno in about a week or two.. right now i am at 8 psi on the profec e-01 and the suckers RUNS and i havn't even given it full power yet!
Old Oct 2, 2005 | 02:29 PM
taurran's Avatar
taurran
That's cool. Eventually I plan on going with EU and a boost controller. I'm very interested in what kind of #s we see on the kit with a good tune.
Old Oct 2, 2005 | 02:54 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
+1 Anxious to see the results. EU or the new UTEC for me. Waiting to see if the UTEC is really that much better/worth it.
Old Oct 2, 2005 | 03:43 PM
kcobean's Avatar
kcobean
Here's my graph from my Dyno yesterday at AAM on their DynoJet. Something is definitely weird with my car. It actually went into limp mode last night coming home from a huge car meet. Scared the **** out of me. I had to pull over and reboot the car. Took it out for a drive tonight and it seems to be running ok....weirdness.....
Anyway, here's the graph. Where the weird dip occurs up near the end of the run, a big puff of black smoke shot out the exhaust. I'm almost wondering if this is where the car is switching maps or something. There is a noticeable hesitation in the car when this happens on the road. And look at that A/F curve. I'm Exxon's best friend with a curve like that! EU / Boost controller, here I come.
Old Oct 2, 2005 | 04:35 PM
Peking's Avatar
Peking
I am not going to post my results from before, I dropped the car off with Sharif@Forged/CPRacing today (just to get a couple of things done) so after they are done this week I will post the results
Old Oct 2, 2005 | 04:45 PM
D350Z10's Avatar
D350Z10
I will keep you guys updated, i am shooting for 405 rwhp and 400 rwtq at 9.5psi! That is what a similar turbonetics Z is running here in Michigan! Same tuner also!!!
Old Oct 2, 2005 | 04:51 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
are you (and he) also running the stock exhaust?
Old Oct 2, 2005 | 04:58 PM
D350Z10's Avatar
D350Z10
We both have the Greddy Evo 2 Exhaust systems. With i believe 2.5 pipe back! Want to upgrade to a 3 in pipe pretty soon.
Old Oct 2, 2005 | 05:04 PM
kcobean's Avatar
kcobean
Do you have any pics of how your exhaust was modded to fit up to the down-pipe?
Also, it's a 2.5 Inch pipe-back, but it's dual pipes, so that's equivalent to a 3" or better all the way back right?
Old Oct 2, 2005 | 05:05 PM
MIAPLAYA's Avatar
MIAPLAYA
That is correct. Dual 2.5" pipes have a larger cross sectional area then a single 3" pipe.
sales@czp
Sep 23, 2019 03:30 PM
35reilly
Sep 28, 2015 07:42 AM
