BOV videos?
Old Oct 3, 2005 | 05:38 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Default BOV videos?
Anyone have videos where I can here the different BOV's on a Vortech kit. Stock/Greddy/HKS etc. Just trying to decide which is best. Thanks!
Old Oct 3, 2005 | 07:51 PM
Gman2004's Avatar
Gman2004
I haved a greddy type s. pm me your email address.
*edit* the type s is on a greddy tt kit not a vortech, but you can get an idea of what it sounds like.
Old Oct 4, 2005 | 05:35 AM
MadBoost's Avatar
MadBoost
Matt,
Don't change it!!! Coming from a BOV and Diverter valve manufacturing background, the vortech is MUCH better than the ones mentioned. Now if you had said Tial, TurboSmart, or Forge, my answer might have changed.
Old Oct 4, 2005 | 05:42 AM
Gman2004's Avatar
Gman2004
Originally Posted by MadBoost
Matt,
Vortech's bypass is better than an HKS? I find that hard to believe...
Old Oct 4, 2005 | 05:56 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Matt,
Really, that's interesting. Tom, are you gonna be able to come over on Sun?
Old Oct 4, 2005 | 06:28 AM
cKy2k's Avatar
cKy2k
i have the greddy type s on my vortech ... and i like the sound more then the vortechs bypass valve .....
Old Oct 4, 2005 | 08:15 AM
Chebosto's Avatar
Chebosto
Does the Type S whistle when you're off the gas? like driving around normally does it vent?
i REALLY enjoy my HKS SSQV... they have these fin options to change the noise.. but i havent had time to install the quieter one... (purple)...
Old Oct 4, 2005 | 09:30 AM
tig488's Avatar
tig488
anybody got clips of the HKS SSQV, i want it but dont know if its worth 300 just to change from my APS to that one.
Old Oct 4, 2005 | 09:36 AM
Juno's Avatar
Juno
Hey, Matt! I can't wait to see your car when it's done! I'm thinking about getting the Vortech now so I can try to keep up with Phil's STi.
Old Oct 4, 2005 | 10:20 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Wanna buy my N20 kit. That should do the trick.
Old Oct 4, 2005 | 11:08 AM
solidsnake's Avatar
solidsnake
i heard one a on supra before racing a mustang cobra. it was a vid on streetfire i think. Man it sounded mean. I wasnt more like whining sound. not the normal ...pssssst!! kinda similiar to a rattle snake rattle. hehe. its hard to explain but im sure someone knows what im talking about.
Old Oct 4, 2005 | 11:13 AM
gringott's Avatar
gringott
My HKS would just do this lame squeak thiggie, not very impressive, but I put on a Seibon VT hood a week ago, and, it seems, the real sound was trapped in the engine compartment. It does this loud Wooooooooosh with squeal that is hard to describe, but everyone who has heard it commented how bad *** it sounds. The good sound was trapped, it is now free.
Zexy's Avatar
Zexy
Turbosmart Megasonic!!
Old Oct 6, 2005 | 07:26 AM
MadBoost's Avatar
MadBoost
I think the Vortech is a MUCH better quality production piece. It doesn't contain plastic parts like the HKS. I don't like the fact that either of the valves adjustment limits travel of the piston. Piston travel is a major aspect of the valve design. I have seen numerous customers with GReddy valves at the point they would simply "crack" open because the adjustment screw was so tight to "hold" boost on the top side. The HKS adjustment is the same. At Forge we actually had interchangeable springs with varying spring heights to adjust for spring travel on each valve. To be different, HKS simply uses the side port of the valve to have pressurized air act at a 90 degree angle to the piston. You can do that with any piston style valve. Take a look at ATP and how they make different ports for each position of the valve. http://www.atpturbo.com/Merchant2/me...egory_Code=BOV
I think the best valve out for design is the APS, for 300-400hp, but they don't promote it or get the credit that it deserves. The thing most people don't account for is port size and volume. While I worked at Forge Motorsport I always looked at using about 1mm od per 10 hp as my own reference chart. Hence, a VW or Audi would work on a 25mm valve up to about 250whp, or a EVO or WRX on a 34mm up to about 340whp or so. My TT camaro had twin Forge 25mm valves at 550whp. The TT Porsche's run twin 25mm valves around the 450hp-550hp levels. Even the Audi S4's ran twin 25mm valves at 300-500hp. I think TIAL has the aftermarkets best valve with the 50mm port size for cars upwards of 400-550 hp as their valve is a very simple and effective diaphragm style, rather than piston. I have talked with Dave at APS about the effects of running dual valves since nobody in the market makes appropriate valves for high hp cars and they had actually done some work with twin 32mm valves on one of their test cars with excellent results. It's not just about getting the air out BUT how quickly it can be done.
To be clear, if I ONLY had the choice between the Vortech or HKS, I would have to choose the Vortech since I have actually pulled both of them apart . If it was a wider choice, the only companies I would look at are Tial, APS, TurboSmart, and ForgeMotorsport depending on the application it was needed for.
Old Oct 6, 2005 | 07:58 AM
Juno's Avatar
Juno
Nah...no good for me, the bottle would always be empty.
Old Oct 6, 2005 | 07:59 AM
Gman2004's Avatar
Gman2004
I was going to go with a Tial BOV, but I was told that it would not work well on my application (two small turbos). I was told the Tial BOV are better for big turbo's like on STI and Supras so I went with the Greddy type S.
Old Oct 6, 2005 | 09:02 AM
002-M-P's Avatar
002-M-P
I really like my HKS SSQV...you can here it in my video I just posted too. Probably won't be up for very long though.
https://my350z.com/forum/forced-induction/146236-video-greddy-tt-final-day-of-the-bridgestones.html
Old Oct 6, 2005 | 09:09 AM
gringott's Avatar
gringott
Low boost is also a factor to consider in your choice, or so I was told.
Old Oct 7, 2005 | 07:14 AM
MadBoost's Avatar
MadBoost
Gman,
It looks like you are around 60 lbs/min. of airflow being used. Its not about the turbo size as much as the volume of air that needs to be moved as to not affect the compressor wheels. If a EVO and STI run a 34mm valve at 300 flywheel hp, or 30 lbs/min airflow,and you are running at 600 flywheel hp on twin turbo, essentially you should be running twin 34mm valves, or two of the Type S (37mm) that you have.
Old Oct 7, 2005 | 07:53 AM
theking's Avatar
theking
Tom, what's your take on the Greddy Type RS? That's what I'm running.
