Oil Temp Gauge Stopped working....???? Help...
Old Oct 11, 2005 | 04:22 PM
bigbri's Avatar
bigbri
Default Oil Temp Gauge Stopped working....???? Help...
I just noticed today that my oil temp gauge is stuck at 140 degrees....There is power to it because the lights come on the gauge but it's reading is stuck....it's a brand new defi gague... you think it's just a bad gague.... what could cause this and can I fix it... thanks for all your help guys...
Old Oct 11, 2005 | 07:23 PM
Gary King's Avatar
Gary King
Try contacting the manufacturer or the company that sold it to you.
Old Oct 11, 2005 | 08:25 PM
bigbri's Avatar
bigbri
It's a brand new defi gauge... I'm taking my car down to get an oil change and have everything checked out to make sure everything is running fine... going to swap it out with a new one....hoping the gauge just went bad...
Old Oct 12, 2005 | 09:52 AM
arizzee's Avatar
arizzee
Is this a Defi-Link gauge? If so, the troubleshooting section states that low values may indicate a bad ground. Try this http://www.defi-shop.com/product/ima...ual05022-h.pdf on pg. 106.
Curious to see what the fix is.
Old Oct 12, 2005 | 10:05 AM
bigbri's Avatar
bigbri
Thanks for the help bro....I'll check it out....
Old Apr 14, 2006 | 01:06 PM
zachcrosen's Avatar
zachcrosen
I gotta dig this up from the grave! The Defi D temp gauge.... this can be used for both water temp and oil tempo correct? Just wanting to make sure as I am going to install a water temp and oil temp gauge in my nav cubby and want to make sure the Defi D is suitable to water and oil!
Old Apr 14, 2006 | 01:24 PM
EnthuZ's Avatar
EnthuZ
I don't see any reason why it can't work for both. I use mine as an oil temp gauge, reading off a bung I added to the OEM oil pan. The gauge is only marked for temp. Not specific as to water or oil.
bigbri, how did you fix your problem?
Old Apr 14, 2006 | 01:36 PM
zachcrosen's Avatar
zachcrosen
Thanks Enthu. Thats what I was thinking. I was thinking temp was temp regardless of what it was taking the temp of. Just wanted to make sure before I buy 2 temp gauges ay $130 a piece!
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
SharX59
Sep 27, 2015 09:23 AM
