Supercharge and blow off valve
Old Oct 16, 2005 | 08:43 PM
dan_csulb's Avatar
dan_csulb
Default Supercharge and blow off valve
I know Turbo uses blow off valve.
Anyone here knows what kind of 350z supercharge works with blow off valve?
Old Oct 16, 2005 | 08:53 PM
z350boy's Avatar
z350boy
Default SUPERCHARGE and BLOW OFF valve
A supercharged engine would not use a blow-off valve. With Supercharging the "blower" works off the engines crankshaft; the engines RPM drives the unit. Turbochargers work off the engines exhaust flow which is used to power the turbos. The blow-off valve is needed for a turbocharger because it helps to regulate the amount of pressure being sent to the unit.
It's not a good race unless they can see your tailights!!
Old Oct 16, 2005 | 08:55 PM
Vamos_Rafael's Avatar
Vamos_Rafael
then there isnt a point to get superchargers...
the point of going boost is to hear the VROOOOOOOOOM *shift* pssssssssssshh
BOV sound is beatiful!
Old Oct 16, 2005 | 09:04 PM
Netko350Z's Avatar
Netko350Z
How does that go again?? SLOWER this time...lol
Old Oct 16, 2005 | 09:21 PM
Vamos_Rafael
ok
lets take baby steps..
engine roar = VROOOOM
*shift* = self explanatory aka shift to the next gear
BOV sex on the beach sound = pssssh
so you add
engine roar + *shift* + BOV sex on the beach sound = hottness?
so
VROOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOooooooooM *shift* psssssssssssssssssssssssssssssssh
Everybodywildou's Avatar
Everybodywildou
Superchargers can have blow off valves too...
Old Oct 16, 2005 | 09:23 PM
krazE's Avatar
krazE
Vortech Supercharger Kit comes with a blow off valve and sounds similar to a turbo kit's
Old Oct 16, 2005 | 09:24 PM
Everybodywildou
Hey and quick question man, I go to school too and I graduate 08 as well... How the hell did you get your car?! lol
Everybodywildou
+1
Old Oct 16, 2005 | 11:12 PM
Badmonkey's Avatar
Badmonkey
The superchargers come with a "bypass" valve. The valve is designed to open up while under vacuum. This sends the compressed air back through the intake. You can vent this to the atmosphere but the sound is not like that of a turbo. The release is long and constant. I recently installed a TurboXS BOV on my car and had it vented to the atmosphere, it was very loud. The sound was like a huge blow dryer at idle, since it was dumping all of the air out. While under boost, the valve would close and quiet down. When you let off the throttle it gave off a long whoosh and then it stayed at the normal loudness at idle. It sounded very crappy, to say the least. So, I routed the discharge to the intake and the sound is now gone, for the most part. I do get a little more boost with the BOV compared to the cheap bypass valve. I was hitting 10.5 psi before, now I see 11.0 psi.
Old Oct 17, 2005 | 06:50 AM
booger's Avatar
booger
The only bad side to this is you are heating up the air more as its sent back through the intake.
Badmonkey...they are starting to pull my motor out today . We still on for the trade ?
Old Oct 17, 2005 | 07:15 AM
cKy2k's Avatar
cKy2k
i have the greddy type s on my vortech and it sounds exaclty like a turbo ... i have a video clip of it ... if anyone knows where i can host it let me know ...
Old Oct 17, 2005 | 07:51 AM
Badmonkey's Avatar
Badmonkey
The air is only going through the bypass while under vacuum. so, the hot compressed air is only going through while under a light load. It honestly sounds like crap with it going to the atmosphere. It is so loud, all the time. When I first started it up like that I thought something had come loose.
We are still on for the trade. I have got to get rid of the rasp.
Old Oct 17, 2005 | 09:17 AM
mel terrana's Avatar
mel terrana
Default Bypass/blow of value
Dan, I have a cs 350Z with a vortech mod, been running it for two years now without any problems. As you notice I live in West Seattle. If you'd like you you can check it out. PM me if you are interested. Nothing beats actually see and hearing it for youself.
Old Oct 17, 2005 | 01:36 PM
COJ_General's Avatar
COJ_General
go to www.putfile.com
Old Oct 17, 2005 | 03:25 PM
prescience's Avatar
prescience
So nosey, what you guys trading
Old Oct 17, 2005 | 07:03 PM
overZealous1's Avatar
overZealous1
ya i ran a bov vented atmoshperic on my ati too. sounded pretty awesome i thought. i had mine set with a bit of preload though. only a couple psi, but you would definately hear it when hammering through the gears!!
ya one reason i did it too was for the reason booger brought up. it would be ok to vent back to the intake from before the intercooler just cruising, but it didn't seem to good to take in a quick puff of hot air from the compressor between shifts when your driving hard.
Old Oct 17, 2005 | 08:15 PM
leemik's Avatar
leemik
I'm using a TiAL BOV on my ati.. sounds just like a TiAL BOV would on a turbo car if you are running quickly through the gears.... but like badmonkey says, there is a little extra hssssssssssssssss when the valve stays open unlike a turbo car... and because of the placement of my BOV, it stalls the car occasionally..
--mike
Old Oct 17, 2005 | 09:23 PM
Z PHAT Z's Avatar
Z PHAT Z
