How much HP will the vortech 3.33 pulley produce?
Old Oct 30, 2005 | 09:57 AM
Mr_pharmD's Avatar
Mr_pharmD
Default How much HP will the vortech 3.33 pulley produce?
Hi, I'm in the middle of purchasing the vortech sc for my AT g35 and I was wondering how much hp I might produce once tuned.
I believe stock auto g35 makes somewhere around 330hp at 8psi BUT, my motor isnt completely stock and I am afraid I'll lose a lot of back pressure and probably won't see the whole 8psi.
As of now, the mods are: Alphawerks headers, Kinetix plenium/ HF cat, y pipe, and stock exhaust. Because of these extra free flowing mods, what psi do u think I would see and how much hp with just the 3.33 pulley?
I am looking from around 370-380hp so will I see this or should I just get a smaller pulley (3.12)?
Also, my car has stock internals so what is the MAX amount of hp I should stay in if I want to keep my motor healthy for a long time?
Old Oct 30, 2005 | 10:12 AM
booger's Avatar
booger
Still dont know why people think a free flowing exhaust is going to hurt them . It will do nothing but help . You may not make as much boost , but you will make more power . On the 3.33 pulley you can make anywhere from 320whp to 380whp depending what dyno you are on and the operator running it
Old Oct 30, 2005 | 11:01 AM
prescience's Avatar
prescience
The faster you get air through the motor and out the back, the more power you make.
Old Oct 30, 2005 | 12:12 PM
Brando's Avatar
Brando
Cool
Well.....I know that 400 is very possible.
Sometimes....it is just how the combination of mods works on a particular car.
CPR was telling me before thay started to tune, not to be disapointed if my car made lower numbers....they later changed their mind.
I DON't have true duals.....a plenum(do have a spacer).....headers...or the 3.12 pulley....but it all just worked together.
Old Oct 30, 2005 | 01:20 PM
zachcrosen's Avatar
zachcrosen
With the 3.33 pulley, I was seeing about 325RWHP @ about 5.0-5.7 psi or so with the Kinetix manifold, test pipes, headers and Injen exhaust. Afterwards, I had the 3.12 pulley installed at CPR and dynoed at 367RWHP with 7.5-9.1 psi with headers, OEM cats, Kinetix manifold and the Injen exhaust.
As said already, when you breathe better, you will run lower boost but better numbers. Its like you will be running more HP per psi of boost. Almost like better efficiency.
FYI, I also have the 5AT but mine is a Z.
Old Oct 30, 2005 | 02:31 PM
Barzten1's Avatar
Barzten1
I should know this but I'm confused on it. What pully comes with the kit and what are the increments of upgrades and how do they affect the warrenty for the blower? Thanks
Old Oct 30, 2005 | 02:34 PM
prescience's Avatar
prescience
3.33 stock - 93.5" belt
3.12 - 93" belt
2.87 - 93" belt
Pretty sure any pulley other than stock will invalidate the warranty
Edited - see below
Old Oct 30, 2005 | 02:38 PM
Brando's Avatar
Brando
Originally Posted by prescience
3.33 stock -
3.12 -
2.87 -
Changing from stock 3.33...lowers Vortech factory warranty from 3yr to 1 yr.
Old Oct 30, 2005 | 06:02 PM
Mr_pharmD's Avatar
Mr_pharmD
ouach.. from 3 to 1yr? So if I had the 3.33 pulley for a yr and then changed it to 3.12, will I still have 1 yr after I changed the pulley or would it be from the time I purchase the kit (therefore, no more warrenty)?
My main concern is if I can run the 3.12 pulley with stock injectors, fmu, and ss box safety or will it be best to run the 3.33.
Old Oct 31, 2005 | 02:05 AM
zachcrosen's Avatar
zachcrosen
I am running the 3.12 pulley wth the stock injectors, fmu and ss box and no problems. I have had the 3.12 for about 2 months.
Old Oct 31, 2005 | 04:29 AM
jpc350z's Avatar
jpc350z
"My main concern is if I can run the 3.12 pulley with stock injectors, fmu, and ss box safety or will it be best to run the 3.33."
If safety is the main concern the 3.33 with stock internals and Vortech stock hardware is the safest..When going smaller pulleys unless you measure injector duty time and are well below about 80% than you remain safe..The problem is having the capability to measure duty cycle..A number of cars with even smaller pulleys and stock everything seem to be doing O.K. but in the long run or some random event may cause problems..
Old Oct 31, 2005 | 06:13 AM
Mr_pharmD's Avatar
Mr_pharmD
For those running the 3.12 pulleys with stock injectors and fuel managment from the vortech, what kind of duty cycle are u seeing?
If something does go wrong while running the fmu, will the fuel pressure gauge be a good way to determine this?
Old Oct 31, 2005 | 06:34 AM
CpraceZ's Avatar
CpraceZ
We have had two cars make over 390whp with the 3.33 it just depends on the mod combination on the car.
Old Oct 31, 2005 | 07:25 AM
neffster's Avatar
neffster
...and how conservative the tune is above 5000 rpms. Those seeing high 10's in the A/F are getting slightly lower results than those in the mid 11's. (stinkin' g8tor20... LOL)
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
