Jerking w/ Vortech
Old Nov 1, 2005 | 06:08 AM
amai21's Avatar
amai21
Default Jerking w/ Vortech
Lately I have notice that there is jerking while I am driving without even getting on the accelerator. When it happens I get on it and it stops. Also, I notice that there is quick fluctuation in the rpms. It happens mostly in 3rd, 5th, 6th gears. Any suggestions on what the problem could be? Thank you.
Old Nov 1, 2005 | 06:58 AM
CpraceZ's Avatar
CpraceZ
you don't happen do know what the A/Fs are when that happens do you?
Old Nov 1, 2005 | 07:18 AM
amai21's Avatar
amai21
That is one thing that I am missing, a wideband O2 gauge. Though, when the car was dynoed it was pretty much in the normal range. Also, the jerking happens when I am not even boosting. I can have my foot on the accelerator at a steady speed.
Old Nov 1, 2005 | 08:10 AM
mcduck's Avatar
mcduck
could be something simple... have you tried cleaning the MAF? I've had a similar problem on my VW and cleaning the MAF makes it go away.
Old Nov 1, 2005 | 02:38 PM
gersteinp's Avatar
gersteinp
Was your SS box connected to the ECU harness via snap connectors or was it soldered? Be sure that every connection is tight and, if not soldered, you may want to do this.
I'm pretty sure your engine has already thrown codes so you may want to go down to your local AutoZone and have them connect their code reader for free. This will tell you what's really going on.
Old Nov 1, 2005 | 04:39 PM
amai21's Avatar
amai21
Check engine light never came on though. Would those be different type of codes that do not affect the check engine light?
Old Nov 2, 2005 | 05:42 AM
JonathanG35's Avatar
JonathanG35
what clutch do you have?
Old Nov 2, 2005 | 06:04 AM
CpraceZ's Avatar
CpraceZ
Do you have a custom tune and has it done it ever sense you have installed the vortech?
Old Nov 2, 2005 | 06:16 AM
350Zenophile's Avatar
350Zenophile
belt slipping?
Old Nov 2, 2005 | 07:06 AM
ryan350z's Avatar
ryan350z
Check your intercooling piping, I had one pop off and on the interstate I had the same thing happen to me. Would run but sputter when under load.
Ryan
Old Nov 2, 2005 | 07:30 AM
amai21's Avatar
amai21
JonathanG35 : I have the stock clutch, but I rarely get really hard on it.
Cprace2: I did have it custom tuned.
350Zenophile: I checked the belt and play in it seems proper enough. I doubt there is any slippage.
ryan350Z- I will check on the piping today.
EVERYBODY: Thank you for your prompt reponses!!! I hope this issue can be solved soon. Also are there any tips on cleaning the MAF? Thank you.
Old Nov 2, 2005 | 07:34 AM
amai21's Avatar
amai21
I forgot to mention that after changing the battery the car seem to run fine for awhile. Sputtering did eventually come back. Seems as if after ECU was resetted the car ran fine. I hope that can help better explain situation.
Old Nov 2, 2005 | 11:38 AM
Barzten1's Avatar
Barzten1
Is it always in the same rpm range? It may be the tune. Might be too rich in that area
Old Nov 2, 2005 | 11:57 AM
amai21's Avatar
amai21
It happens in different ranges. Also this start happening 1 yr after the tuning. Till now it was running great.
Old Nov 2, 2005 | 12:04 PM
booger's Avatar
booger
Did you happen to adjust your BOV ? Also check your vacuum hoses for cracks
Old Nov 2, 2005 | 12:51 PM
CpraceZ's Avatar
CpraceZ
Any big changes in weather or did you happen to move, also I agree with booger check both or those out. What I think is weird you said it stopped doing it after you reset the ECU? Try resetting it again and see if it stops for a little bit if it does it sounds like something in the ECU, but no codes right?
Old Nov 2, 2005 | 01:20 PM
amai21's Avatar
amai21
Yeah, check engine light has not came on yet. I never messed with the bov. I am going to read it to see if there are any hidden ones.
Dreamsmith
Jan 29, 2008 10:07 AM
drifter23
Dec 9, 2006 08:23 PM
617G
Oct 20, 2006 11:36 AM
617G
Oct 2, 2006 07:07 AM
zimbo
Sep 8, 2004 03:58 PM
