VQ32de
Old Nov 7, 2005 | 04:51 AM
  #161
tilleys99's Avatar
tilleys99
Originally Posted by doug
i don't mean to stick my nose in again.. lol..
but if anyone knows a little more about the VQ motor than tilley its Matt (MardiGrasMax)
the only reason VQ motors got past 400 whp is because Matt did extensive research and tuning to get there. All the high powered Turbomaxima's are there because they listened to Matt. If you have any VQ questions matt can answer it.
The only other person i know as knowledgable about VQ's other than Matt.. is another Matt (SR20DEN on the maxima forums) and when i say know the VQ.. they know it bolt for bolt and know exactly what will happen with the motor.
There is only a few of us.....
Old Nov 7, 2005 | 07:29 AM
  #162
deezo's Avatar
deezo
Originally Posted by BriGuyMax
He never said "I want to sell you something". But that's not the point anyway.
I don't recall ever calling you "names". I did say your posts are ignorant, but I didn't call you any names. Furthermore you act like you're above this supposed "name calling" when in your NEXT post...you start name calling.
And finally...if you really don't care..and this thread is a waste of your time then....
WHY DO YOU KEEP POSTING IN IT?
Long time no see................
Old Nov 7, 2005 | 08:49 AM
  #163
tilleys99's Avatar
tilleys99
Heres a good link for some upgraded rods for the VQ30det crank http://www.atomicspeedware.com/pautnissan.htm
Old Nov 7, 2005 | 11:53 AM
  #164
IceY2K1Max's Avatar
IceY2K1Max
You might look into these also Tilley...
http://performancenissanparts.com/ca...c18335cdfb5f6e
Old Nov 7, 2005 | 01:11 PM
  #165
tilleys99's Avatar
tilleys99
Im confused on why it say VQ35det crank????
Old Nov 7, 2005 | 01:43 PM
  #166
RockfordMAX's Avatar
RockfordMAX
Don't know if we'll be heading to Byron again this year..but myself, Nealoc187, I30tMikeD, and a bunch of Z and G35 guys are going to US 41 next Sunday...
Wow I think i might need to reschedule some stuff and head out there... mind shooting me some more info?
Old Nov 7, 2005 | 01:55 PM
  #167
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
PM sent
Old Nov 7, 2005 | 02:50 PM
  #168
IceY2K1Max's Avatar
IceY2K1Max
Both the VQ35 and DET use 50mm journals, IIRC.
Old Nov 7, 2005 | 03:01 PM
  #169
max2000jp's Avatar
max2000jp
I know what a max can do...I've had 2 97 5-speeds...
Maxima's are slow.....
Brian are you going for sure? Neal told me about going to US41. If I go, can I borrow ur ET streets?
Old Nov 7, 2005 | 03:41 PM
  #170
tilleys99's Avatar
tilleys99
Not according too my visual parts comparison.
Old Nov 7, 2005 | 03:52 PM
  #171
theking's Avatar
theking
Vq35 uses a 48mm big end journal, IIRC. That's why this is such a good option. Pretty weird size which limits available bearings(only used on a 4G63 and SR20det that I know of). Where the 50mm is used in many more applications.
Old Nov 8, 2005 | 04:00 AM
  #172
deezo's Avatar
deezo
Originally Posted by kaos1
im thinkin bout buyin an accord so i can waste money on making a sedan fast just to impress ppl with s2000's
Please. You bought a car and wasted your money.
Old Nov 8, 2005 | 06:50 AM
  #173
etx's Avatar
etx
This thread is retarted. My 1986 300zx has a VG30E which is the predecessor of the VQ. They are very very similar motors. Maximas are cool, they barrowed a lot of technology from the Z33 like the suspention for example.
Old Nov 8, 2005 | 07:26 AM
  #174
theking's Avatar
theking
We are talking about a VQ30det. Not a VG. Who's retarted(especially in reguards to spelling) now. JK. Just having a little fun, not bashing you.
Old Nov 8, 2005 | 07:46 AM
  #175
tilleys99's Avatar
tilleys99
vq30de (dual overhead cam 24v V6 alum block/heads with chain driven timing)
vg30e (single overhead cam cast block with belt driven timing)
Far from similar.
Old Nov 8, 2005 | 08:39 AM
  #176
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
The VG and VQ series motors are very DIFFERENT. Hell..the VQ shares more in common with the VK (V8) than it does the VG.
Old Nov 8, 2005 | 12:10 PM
  #177
Larrio's Avatar
Larrio
I believe the main point of the thread was to point at a different setup for the VQ engine, regardless of what type of car it is/was in.
One of the main gripes when the 350z first came out on Best Motoring by japanese professional drivers was that the engine did not have the characteristic high-rev ability seen in most sports cars (I believe the porsche GT3, skyline, s2000, NSX and others all rev past 7500 rpm)
Many others entering high boost or horsepower applications have gone the route of reducing displacement in order to have a safer and higher rev capability. Such is the case with 1) Jim Goughery's 350Z, 2) Top Secret VQ32 350Z, 3) JGTC, and 4) Dallara Lemans Prototype VQ30DETT - i don't think many know of this, although I think they ended up increasing displacement later on
http://www.mulsannescorner.com/dallaralmp11.html
And yes, the fact is that most will not opt for this nor a 8000 rpm rev limit since a simple ECU reflash will compensate up to 7100 rpm. Most people would not opt for cams, rods, or pistons either but that doesn't mean no one should make it or put it in their engines. A higher rev limit also is important on a road course, allowing you to maintain a specific powerband given the gear ratios of the transmission during turns and technical sections.
Old Nov 8, 2005 | 12:20 PM
  #178
hypeiv's Avatar
hypeiv
VQ35de block and pistons
VQ30de crank and rods (soon too be VQ30det due too bigger rod mains and stronger crank/rods)
JWT vq35 cams
VK45de titanium valves
ported heads
ARP head bolts
I R confused... so you can rev your engine to 7500 and 8000 with that set up? How much boost are you running and what kind of numbers and/or times are you laying down. This seems like an interesting direction for VQ35 engine build ups.
Old Nov 8, 2005 | 01:54 PM
  #179
Resolute's Avatar
Resolute
The JGTC engines are not high-revving, neither is the VQ in that prototype you posted. I haven't seen anything to prove that TopSecret uses a 3.2L in its project car except from a SuperStreet article, and I don't think they have any idea what they're talking about. I had no idea Jim Goughery altered discplacement. The only example of a high revving VQ, that I know about, is the old formula nissan engines that topped out just over 10,000rpm. They were a modified VQ with 3.0 Liters.
Swapping out the DET crank for stronger rods and shorter stroke, with less compression might be a good, cheap way to build the motor for boost, but for revs, the rod/stroke ratio is about the last thing to consider for building for high revs. I think the biggest advantage to this, besides the low compression, is ditching the CVTCC system. This doesn't require changing the crank obviously, but putting the VQ30 cover on and using pins allows a low compression 3.2L that can now be tuned using a JWT ECU. This is the best part of the package IMO. No more piggybacks or expensive stand-alones, and JWT has dyno pulled just about every cam and boost level for the optimum- and safest- tune. This together is pretty enticing..and of course with Z33 cams and the better breathing head of the VQ35, I would be impressed to see what's ultimately possible in a Z with this configuration.
Will
Old Nov 8, 2005 | 02:50 PM
  #180
Larrio's Avatar
Larrio
I believe the JGTC VQ30DETT revs up to 8000 rpm, with a 12:1 compression ratio. I'll have to look up my sport compact car issue again.
However my conception of high-revving may not be the same as yours since you mention 10,000 rpm on the old formula nissan engine. As for the Top Secret car, well its hard to find hard information on that. The super street article just mention that its a destroked vq35 with a VQ30 crankshaft
Jim Goughery didn't actually alter displacement. He opted for a VQ30 instead and used a modified maxima manifold for a little bit also. He sent pics to a friend once that requested it from him on another forum.
