Call Me Crazy!!!!!!!
Old Nov 25, 2005 | 02:49 PM
  #141
Immortal's Avatar
Immortal
Originally Posted by hypeiv
And when the supra comes back in a few years as a 300hp NA 30k car people will be saying the same thing.. "why didn't toyota make it turbo?!?!?"
long shot.. really long shot, toyota declared that it had no intension of bringing back the supra
Old Nov 27, 2005 | 12:29 PM
  #142
NISMOFO's Avatar
NISMOFO
Crazy is the right word. I want to see videos!!! For me, 9.5psi just sounds so d@mn safe now.
Old Nov 27, 2005 | 12:56 PM
  #143
bigbri's Avatar
bigbri
I'll have some vids up soon bro.....and at 9.5lbs of boost your fine...
Old Nov 27, 2005 | 10:23 PM
  #144
redline350ZZ's Avatar
redline350ZZ
So ur saying the BFG DR 275-35-18 can hold all that power????? hehe if so my Z will be getting a set soon....
Old Nov 28, 2005 | 08:04 AM
  #145
bigbri's Avatar
bigbri
They can they are badd *** tires....
Old Nov 28, 2005 | 09:50 AM
  #146
k3silk's Avatar
k3silk
make sure you get those vids up people are dying to see those vids.
Old Nov 28, 2005 | 09:53 AM
  #147
bigbri's Avatar
bigbri
I will as soon as i make some...
Old Nov 28, 2005 | 03:37 PM
  #148
Jergens's Avatar
Jergens
Anyone know if BFG DRs come in 295x35x18
Dude, I wish I lived out there. This sounds so epic. Good luck Wens.
Ah hah, never mind. Looked it up on site. 295x35x18.... hmmm I might need a second set of wheel and tire.
~Josh
Old Nov 28, 2005 | 04:21 PM
  #149
calimarc's Avatar
calimarc
~Josh
Will 295/35/18 fit on our Z's?
Old Nov 28, 2005 | 04:26 PM
  #150
Zivman's Avatar
Zivman
I run that on a 10.5 wheel
So yes, they will fit
Old Nov 28, 2005 | 04:39 PM
  #151
failsafe306's Avatar
failsafe306
I know this isn't the wheel/tire forum, and it's not even my thread, but does anyone know if 335/35/18's on an 11 or 12 in rim would fit a Z with cut or rolled fenders, assuming you got a pretty high offset? I think 335 DR's would solve most of our traction problems off the line assuming you had some bullet-proof axles.
Old Nov 28, 2005 | 04:48 PM
  #152
Zivman's Avatar
Zivman
heard of a 305 fitting back there, but a 335?? I don't think you could fit that without tubbing or a widebody fender
Old Nov 28, 2005 | 09:45 PM
  #153
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I've measured and I believe someone on here has done it on a stock body Z....It's possible...but it's REALLY a squeeze.
I also run the 295/35-18 BFG DRs without any rubbing issues at all on an 105 inch wheel...plenty of room for them.
Old Nov 29, 2005 | 06:12 AM
  #154
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I am running the same tire on a TE37 22offset 10.5 rear. If your car is very low, they will rub. I rolled my fendors and raised the rear about 1/4 inch and now they dont rub at all.
Old Nov 29, 2005 | 11:21 AM
  #155
bigbri's Avatar
bigbri
I need to roll my fenders....where should I go to do this?
Old Nov 29, 2005 | 11:50 AM
  #156
roncfpz's Avatar
roncfpz
I would take it to a good body shop that has the proper tools. If not done correct, you could damage the paint on the fenders. You might also consider cutting the fenders if you want maximum clearance. Just be sure they apply some coating to the cuts to prevent rust. I had mine cut by the local perf. shop and they did a fine job.
Good luck!
Ron
Old Nov 29, 2005 | 11:53 AM
  #157
Sharif@Forged
Forged Performance
Call around to some body shops...see if they have the hub mounted tool for fender rolling.
I actually did mine myself...and I hate body work. Will and I bought a small baseball bat. Cut off the short end, and spent about one hour gradually rolling the bat under the fender...wedging it between the tire and the fender. It actually worked really well. There is little chance of denting the fender, or chipping paint, if you use a wooden bat.
Old Nov 29, 2005 | 12:53 PM
  #158
Gman2004's Avatar
Gman2004
I think tirediscount will rent you a fender roller that mounts on lugs. I could have sworn I read that on this site somewhere.
Old Nov 29, 2005 | 02:10 PM
  #159
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
http://www.rollyourfender.com
I used that fender rolling tool with a heat gun...worked fantastic. You rent it from them so it only costs you $50 and your time.
burglapfd
Dec 6, 2020 01:04 PM
Depravity
Oct 1, 2015 04:49 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
