Supercharger opinion
Old Nov 12, 2005 | 09:59 PM
Daytona350Texas's Avatar
Daytona350Texas
Default Supercharger opinion
Ok thats it I have my mind set on either SC or turbo... just cause of gains and sounds of both. Question is
I need something I can turn boost down to keep gas milage, and something that isnt too damaging to engine, cause i really could use the warranty to stay good for a while...
Also is it worth the 5-10k rather then taking that and putting it straight into mods such as cams, pullys, headers, exhaust, etc.... whatever else i can get for 5-10k
Also clutch/flywheel, will i need to upgrade since the considerable launches ill have to do etc?
Old Nov 13, 2005 | 07:19 AM
baileyrx's Avatar
baileyrx
go with a turbo/supercharger. quicker & less invasive
generally speaking:
supercharger= less expensive, louder, less power
turbocharger=more expensive,much quieter, more power
now, you could tune down a turbo & make it safer.. but power is very addicting.
mph wise, no big difference unlees you get on the boost alot(like most of us)
don't do it unless you're not concerned about gas milage
Old Nov 13, 2005 | 07:51 AM
g8tor20's Avatar
g8tor20
Ain't that the truth!
Old Nov 13, 2005 | 08:49 AM
BLN350Z's Avatar
BLN350Z
Seems like you already have gotten some good advice. I have the Stillen Stage III and I love the sound it makes and I am not all that worried about hurting the motor with this setup. As long as I keep my foot out of the gas, I get 25 to 26 mpg. You can change the boost by simply changing the pully, but don't expect to be able to tune on it much. You can also have a "higher boost pully" manufactured for you if you feel the need for more boost, but be aware of the extra heat it produces on this type of S/C. I am getting my 8.3lb pully from a friend I met here on my350Z.com.
Old Nov 13, 2005 | 09:07 AM
concuthatbu's Avatar
concuthatbu
Z doesn't get 25 or 26 mpg.......it should be around 22 mpg
Old Nov 13, 2005 | 09:31 AM
JETPILOT's Avatar
JETPILOT
My car gets 32 mpg on the highway with the turbonetics kit no cat @ 70mph on cruise control.
Respect
JET
Old Nov 13, 2005 | 10:45 AM
homiusang's Avatar
homiusang
Once you're F/I'd, you are pretty much kiss good-bye to your warranty, don't even worry about it.
As for as gas mileage goes, if you stay off boost, say cruising on freeway around 75-80 mph, turbo'd will give you similar gas mileage as you were N/A.
And you clutch will go sooner or later after the extra power/torque you gained. So an upgrade is needed.
Old Nov 13, 2005 | 10:48 AM
hypeiv's Avatar
hypeiv
Respect
JET
doesn't the tnetics kit change the injectors? if you change your injectors the MPG computer thats on your car won't work correctly anymore fyi.
Old Nov 13, 2005 | 10:52 AM
kash's Avatar
kash
Respect
JET
maybe you added a tornado fuel saver in the process also
Old Nov 13, 2005 | 10:55 AM
onyx350z's Avatar
onyx350z
I went with all bolt-ons except the cams and headers - even got the 3.9 350EVO gears - now I wish I would've spent the $ on FI - most likely turbo for the sound. Not to say the Z wasn't a different car to drive after the mods, but like someone said HP is addicting and now I need more. I can't see spending $1100 for cams + install $650 + headers $400-$600 = $2150 - $2350 when I can put that in a SC or turbo and get 70 - ??? more HP. If I add up all the $ I spent I could've went with a FI set up and been more satisfied, my suggestion would be to find some Z-G owners in your area with NA mods and FI and go for a ride in their cars before you spend your $. I wish I would've considered the $ and the performance in the end and saw the difference.
Old Nov 13, 2005 | 11:08 AM
BLN350Z's Avatar
BLN350Z
concuthatbu,
Once again, I am NOT into arguing! My car gets 25-26mpg on the hwy if I just cruise about 75-80mph. Sorry if you are offended that my car gets better gas mileage than yours.
Old Nov 13, 2005 | 11:19 AM
hypeiv's Avatar
hypeiv
+1
I was about to bite the bullet and order exhaust, final drive, headers, intake, plenum, rims/tires. I was looking at $5-6k installed, then I saw the Tnetics kit was only $4300... after install and tune it will be more than my previous plan but it really got my thinking about what I should save up for. Right now I have enough saved up for the kit + install but I want to have some extra saved incase I have to rebuild the motor if something breaks. And I spent money for an extended warranty so I should try to get the most out of that before I take the next step.
Old Nov 13, 2005 | 01:45 PM
concuthatbu
concuthatbu,
Look at your original post, did you say you get that on highway?
I dont care if you get 50 mpg.
Fact is fact.....
you give out b.s number, people knows who the liar is
Old Nov 13, 2005 | 03:39 PM
Daytona350Texas
Thanks guys for all the information, yes the sound of a turbocharger is more addicting then anything else ive ever experienced and the whine of a sc is also very sexy while sitting WOT hitting the streets. I love working on cars and have been addicted since the age of about 11. I know alot about N/A so dont get me wrong my studying N/A vs SC/turbo is very extensive, but ive realized hearing personal reviews basically has always helped me decide the right choice, or at least is more convincing. Cause an ad always sounds good, but someones true word always sounds better.
Alright with all that information, couple more questions.
Id rather have a turbo (sound and hp gain) whats safest to last the 5-6 years im expected to keep this car, whats easiest maintenance (meaning dont have to take it to the tuners everytime to do every little thing) and whats best gains while getting high quality out of a *cheap* and i dont mean cheapest i mean most affordable to a 19yr old full time student.
Thanks in advance!!! Will
Old Nov 13, 2005 | 04:01 PM
BLN350Z's Avatar
BLN350Z
The number is hwy and I have absolutly no reason to lie about gas mileage. Get a grip!
Old Nov 13, 2005 | 08:01 PM
hypeiv's Avatar
hypeiv
yea its funny he is calling out your 26mpg (which is what i get on the highway too) and not the guy claiming 32mpg on his turbo Z... Though I am sure he is going off the computer which completely wrong when you change your fuel injectors so I am sure his computer says 32mpg but he really gets much less than that.
Old Nov 13, 2005 | 08:26 PM
Havok_RLS2's Avatar
Havok_RLS2
Dude. Your just wrong. I have an 05 that get better than 27mpg Highway cruzin at 70-80mph. My round trip to work and back is 117 miles daily. Try the reset button once in a while.
Old Nov 13, 2005 | 08:30 PM
concuthatbu
LOL...22 MPG local....
Old Nov 13, 2005 | 08:31 PM
Havok_RLS2's Avatar
Havok_RLS2
Fact is fact.....
concuthatbu
Old Nov 13, 2005 | 08:33 PM
Havok_RLS2's Avatar
Havok_RLS2
I get 22mpg playing stoplight tag. And What?
