Max Turbonetics Power w 380 injectors/piggyback
Old Nov 16, 2005 | 11:38 PM
JETPILOT's Avatar
JETPILOT
Default Max Turbonetics Power w 380 injectors/piggyback
How much additional horespower is available to me with my Turbonetics setup just by adding a piggyback and tunning without a return fuel system or bigger injectors? Could I get a true 385-90 rwhp? I'm @ 366 now. I'm looking for another 25.
Which piggyback is right for what I want to do.
Would I need to reflash my computer back to stock from the TN reflash before tunning?
Sharif? You listening?
Respect
JET
Old Nov 17, 2005 | 05:47 AM
CpraceZ's Avatar
CpraceZ
I don't see any reason you could not get near 400hp, the vortech kits are using a piggy back system, stock injectors, and no return style fuel system making 400hp with the smaller pulley. I would suggest Emanage Ultimate or the new Utech system coming out here shortly.
Old Nov 17, 2005 | 06:04 AM
mojo powered's Avatar
mojo powered
or even a 3" straight through exhaust!!
If I remember right, you're still on the stock exhaust? I'd think you could gain quite a bit with a JIC style straight thru single 3". I don't know about 25whp but I'd think at least 10-15whp is available without tuning, even more with piggyback tuning.
Old Nov 17, 2005 | 07:06 AM
Peking's Avatar
Peking
Very possible, and like Sharif has said before... Pushing to close to 400 WHP without bigger injectors and fuel return is not a good idea.
Any what is all with the JIC, no love for the Tanabe
Old Nov 17, 2005 | 08:50 AM
MIAPLAYA's Avatar
MIAPLAYA
Yeah a 3" exhaust is going to net you some nice gains in the low end as well. I think Z phat Z posted a dyno graph where he picked up like 15-25 RWHP in the low end just by going from stock to modified Borla with the Turbonetics kit. WIth a piggyback you should be more the fine to 9 PSI and about 400. My car made 390 at 9 PSI with just bumping the boost.
Old Nov 17, 2005 | 09:39 AM
JETPILOT's Avatar
JETPILOT
My A/F drops below 10.0 after 4200 rpm and doesn't rise to 10.0 until 6300 rpm.
I could just add some boost via a boost valve to get a better A/F ratio without further tunning via piggyback. Correct?
Respect
JET
Old Nov 17, 2005 | 09:59 AM
MIAPLAYA's Avatar
MIAPLAYA
Respect
JET
Yes you could. I would get an exhaust on the car first....you may lean it out a little...
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
samansharif
Sep 25, 2015 12:31 PM
