Turbonetics+ 3.9 gears+ Titlon Flywheel
Old Nov 21, 2005 | 05:01 PM
redline350ZZ's Avatar
redline350ZZ
yup....im sure that my set-up is great and Im not changing any parts in my sig...except the kinetix plenum......Im having a hard time to get a great seal....I can hear the slightest leak but its not affecting my vaccume..I want a SSV
Old Nov 21, 2005 | 05:03 PM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by redline350ZZ
Im now driving normal again because I feel more confident about the saftey.....the highest Ive seen so far is 850...after a 2nd and 3rd gear boost run......
The gauge fluctuates between 500 and 700 normally......depending on driving style
Sounds good... get us some dyno numbers dammit
Old Nov 21, 2005 | 05:25 PM
MIAPLAYA's Avatar
MIAPLAYA
Have you considered going back to stock with a plenum spacer yet? The Motordyne spacer seems to have improved my midrange power quite a bit. I won't know for sure until I get back on the dyno but it certainly pulls a bit better in the midrange now.
Old Nov 21, 2005 | 05:33 PM
redline350ZZ
Honestly I dont like the way the stock Z Plenum is designed...seems so inefficent........I like the SSV because of style, less parts, lighter and the direct flow....
Im all about getting rid of extra crap....
Old Nov 21, 2005 | 05:35 PM
MIAPLAYA's Avatar
MIAPLAYA
I hear you...well if you are getting leaks you could always go back to stock in the mean time...
Old Nov 22, 2005 | 09:43 AM
onyx350z's Avatar
onyx350z
Just curious, how do you hook up with the turbo and 3.9 final drive gears? I have the 3.9 gears and want to go with the Turbonetics kit and the opinions I've gotten is the car will not hook up at all until 3rd gear??? I'm not tracking the car, its a daily driver. Are you happy with the way it is or would you go with the 3.5 or 3.3 gears if you had the chance?
Old Nov 22, 2005 | 12:25 PM
redline350ZZ
I dont...hehe...unless u plan to drive around in D/Radials its probably not a good idea..... but im sure it would be like driving a 500WHP car...having the same traction issues....
Old Nov 22, 2005 | 12:48 PM
tekk's Avatar
tekk
For a street driven daily driver, would 3.3 gears be a good idea? If I'm correct there would effectively be less torque available from low speed but the car would have a higher top speed. Is this right? If so, what would the old/new top speeds be?
Also, what impact, if any, would the FD change have on vdc/traction control and the speedometer (assuming stock wheels, etc)?
Old Nov 22, 2005 | 01:36 PM
sentry65's Avatar
sentry65
the burninator
3.3 gears will help in allowing you to use the torque that a turbo or TT will put out. It won't give you as much punch in 4th thru 6th gear, but will help with 1st thru 3rd gear.
Better mpg, each gear will last longer before shifting etc.
Old Nov 22, 2005 | 02:58 PM
onyx350z's Avatar
onyx350z
So by the sound if it I should get rid of my 3.9 gears when I go with a ST kit. Anyone else use the 3.9 gears with a FI set up?
Old Nov 22, 2005 | 03:39 PM
redline350ZZ
Someone posted that there Cruise control was messed up with the lower gears......
what I would do is find someone close to you that wouldnt mind trading gears...install your kit and see what u like better...the pumpking can be changed out fairly easy......that way you can decide for yourself.....
that was my original plan but I decide to keep the 3.917...for now that is...
also figure out what kind of racing if any you like to do.......my car is probably very dangerous for circuit tracks.....Sentry can probably elaborate
Old Nov 23, 2005 | 05:56 PM
Z BOY's Avatar
Z BOY
are you saying you're having lots of trouble getting the power to the ground/ spinning a lot with the 3.9?
Old Nov 23, 2005 | 07:15 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
redline sounds good that everything is working out for you, cant wait to see how all this performs on the 35th anniv.
Old Nov 23, 2005 | 08:09 PM
redline350ZZ
Oh no I drive fine.......if I get up on it like a mad man then I have some wheel spin......but thats what my BFG Drag Radials are gonna be for...hehe...of course I can get away with those tires.....since I live so close to work......
Tires will probably be ordered in a couple of months....
Yes 1st gear is very short.....and my flywheel is very light...but hey I bet I reach boost faster than most...hehe....I just gotta well shift sooner.....so I guess from a dead stop with minimal practice I will suck(untill BFG's)...but anything above 60MPH you better watch out...
Hell im gonna try some 2nd gear launches when ever the rain stops and I can make it to the track.....
Old Nov 24, 2005 | 09:07 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
yea i am hoping the 3.9 will help me get to the rev-up powerband much quicker... and help make up for my lack of tq.
Dr.Paulyy
Jul 29, 2019 07:45 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
