Vortech inlet impeller question
Old Feb 24, 2006 | 04:25 PM
  #41
zachcrosen's Avatar
zachcrosen
Does the front bumper have to come off?
Old Feb 25, 2006 | 06:30 PM
  #42
kevinapex's Avatar
kevinapex
Nice Lou! Looks great man!!
Old Feb 25, 2006 | 06:37 PM
  #43
booger's Avatar
booger
Good job u guys . I wish I could do it with the AT5 G35
Lou...did you read my post....Mike at Sublime Speed said no go on the MAF pipe unless u wanna pay for full price for fabrication ...around $200
Old Feb 26, 2006 | 12:30 PM
  #44
LOU's Avatar
LOU
Yes
Old Feb 26, 2006 | 12:32 PM
  #45
LOU's Avatar
LOU
I wouldn't mind paying the full cost if I can see pics and know that it fits on a 350Z.
Old Feb 26, 2006 | 02:22 PM
  #46
teh215's Avatar
teh215
If this replaces the combo-piece that Vortech uses, I know that I would be interested in getting this made.
Old Feb 26, 2006 | 02:31 PM
  #47
LOU's Avatar
LOU
It does and it is 3".
Old Feb 26, 2006 | 02:40 PM
  #48
booger's Avatar
booger
He never did make one like I asked him to . He has a chit load of cars in his shop and said he hadnt found the time . I had left my 3 pieces of the MAF pipe for him to copy to make the single piece MAF . If one of you guys want it made for your self , I will take my MAF pipes back to him so he can copy them into a single .
Sublime
4350 So. 90 st.
Omaha Ne. 68127
402-597-9308
Ask for Mike the owner
Old Feb 26, 2006 | 03:10 PM
  #49
teh215's Avatar
teh215
Sublime
4350 So. 90 st.
Omaha Ne. 68127
402-597-9308
I know I'd like it....
Old Feb 26, 2006 | 03:13 PM
  #50
booger's Avatar
booger
If you call him and you want it made . PM me and I'll take my pipes back up there for him to copy....Bill
Old Mar 5, 2006 | 05:58 AM
  #51
zachcrosen's Avatar
zachcrosen
Did you guys have to cut any off of the length of the 90 degree pipe? The pipe I got from Turbohoses is 10" from the center of the bend to the end of the pipe. Should it be more like 6" or less? From what I am seeing on my car, there will be too much pipe which will cause the filter to hit the vertical metal piece just below the hood latch. I think I will have to cut 4" minimum off both ends of the pipe.
How much did you have to cutt off the pipe to make it work Lou and Kevin?
Old Mar 5, 2006 | 12:21 PM
  #52
LOU's Avatar
LOU
I didn't have to cut anything off of the pipe. It is 12" total. 6" to the bend. I guess the mild steel is a different cut than the stainless steel.
Old Mar 5, 2006 | 01:27 PM
  #53
dlt1cy's Avatar
dlt1cy
would a shorter (say 3" to bend) work if you cut the silicone tube a little longer? or is the filter the problem?
Old Mar 5, 2006 | 01:34 PM
  #54
acg's Avatar
acg
Bill, could you possibly take a pic of the pipe as I may have my builder make one, or if possible could I pay your guy to make another one for me.
Old Mar 5, 2006 | 01:44 PM
  #55
LOU's Avatar
LOU
No. The pipe has to be long enough to come through the square hole and be able to tighten a hose clamp. It is already a PITA. 3" would put you directly underneath the square hole with no way to get a hose clamp on.
Old Mar 5, 2006 | 03:00 PM
  #56
zachcrosen's Avatar
zachcrosen
Yeah, the mild steel pipe is 20" in total length. I cut one end to about 8" (to the blower) and I cut the other to about 6" (filter end). I also had to cut the piece of silicon hose to about 5". Not to mentiojn, I had to Dremel the **** out of the plastic, as you showed Lou. I am still a little worried about getting to the filter. I am not sure if I can get to it or not without removing the bumper!
Did anyone experience a slight bending inward of the silicon hose due to the wierd angle of the hard pipe entering the tube? In one place, the silicon tube actually is dented inward about 1/4-1/2". I dont think this should be an issue as air should still be sucked in at the same rate as before. What is the purpose of the breather hose? I thought that was ONLY on the G35 but mine had it. I didnt order the filter because I didnt think I was suppose to have the breather line. Should I wait to get the filter before driving the car?
Thanks guys for all the help on finally resolving this issue!
Old Mar 5, 2006 | 05:49 PM
  #57
LOU's Avatar
LOU
I have the same dent in the silicon hose you are talking about. It is caused by the angle. My breather hose is just hanging right now. As far as I know, it is okay to drive with it hanging. I have had no issues.
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
