Vortech inlet impeller question
Old Nov 29, 2005 | 07:40 PM
freezeg35's Avatar
freezeg35
Default Vortech inlet impeller question
So i got the 90 degree 3.5inch i.d. intercooler hose. It is a 3 ply hose, but its not super firm, i can squeeze and squish it. My question is when i put it on in place of the air filter should i be concerned about it getting sucked in? Anyone know how much vaccuum at peak redline is being drawn at the impeller. Im guessing it cant be too much, as that k&n filter on it is pretty squishy. TIA
Old Nov 30, 2005 | 04:34 AM
kevinapex's Avatar
kevinapex
I used silicone 3.5" it's real soft, It would never be able to loose its structure under boost I think you will be fine.
I got sick about how the stock Voctech filter is mounted so I did this with 3.5" silicone, 90 deg. sweep in stainless and new K&N filter.. look at picts!!
Attached Thumbnails Vortech inlet impeller question-nissan-picts.-055.jpg   Vortech inlet impeller question-nissan-picts.-056.jpg   Vortech inlet impeller question-nissan-picts.-057.jpg   Vortech inlet impeller question-nissan-picts.-058.jpg   Vortech inlet impeller question-nissan-picts.-059.jpg
Old Nov 30, 2005 | 04:39 AM
booger's Avatar
booger
Nice Kevin...I used a flexable hose that has wire in it so it doesnt lose its shape when you bend it . With the G35 AT5 , you cant go thru the radiator support . Had to go straight down and in front of the wheel well
Old Nov 30, 2005 | 06:46 PM
ss350's Avatar
ss350
dam kevin that looks nice. Where did you find the silicone hose and 90 degree sweep in stainless?
Old Dec 1, 2005 | 05:37 AM
jpc350z's Avatar
jpc350z
Kevin , after relooking at my front end and the location of the your filter , do you have to remove the bumper to get to the filter? What did you have to modify to relocate to it's position..thanks
Old Dec 1, 2005 | 04:55 PM
kevinapex's Avatar
kevinapex
www.turbohoses.com Talk to Hover good guy, Tell him kevin sent you, he's sharp.
The ss pipe and silicone 3.5" is $$$$$.
I had to Dremel out some plastic so the sweep would fit beter, no big deal.
I can get my hand in to the right of hood latch to get filter out, one handed job!
Old Dec 1, 2005 | 05:02 PM
kevinapex's Avatar
kevinapex
I bet it doesn't make much difference, but I like the idea of having the filter in front of the radiator, for cooler air intake temps.
Old Dec 2, 2005 | 03:10 PM
ss350's Avatar
ss350
thanx for the info Kevin!
Old Dec 5, 2005 | 01:22 PM
teh215's Avatar
teh215
What did you do with the PCV hose? Just put a filter on the end of it?
Old Dec 5, 2005 | 01:28 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Nice, where did you get the piping?
Old Dec 5, 2005 | 01:42 PM
teh215's Avatar
teh215
I just picked up the last 90 that turbohoses had in stock...
Old Dec 5, 2005 | 01:56 PM
booger's Avatar
booger
Thats what I did . I dont get any blow by . But if you did want to hook it up to the intake , I would put a catch can inline
Old Dec 5, 2005 | 02:00 PM
teh215's Avatar
teh215
What can are you using?
Old Dec 5, 2005 | 02:36 PM
booger's Avatar
booger
Im not...I just vent .
Old Dec 10, 2005 | 06:55 PM
kevinapex's Avatar
kevinapex
When I ordered the new demension K&N filter I got a vent filter for the PCV vent.
http://www.martelbrothers.com/pages.php?pageid=20
Old Dec 11, 2005 | 03:02 PM
teh215's Avatar
teh215
What was the part number of the intake filter? I picked up a K&N RU-1785.
Old Dec 11, 2005 | 03:16 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
what's the part# for the piping and the coupler?
Old Dec 11, 2005 | 03:23 PM
teh215's Avatar
teh215
Unless Kevin comes back with specifics, I will be post a DIY in the next few days.
Old Dec 11, 2005 | 03:27 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
thanks
Old Dec 11, 2005 | 05:45 PM
kevinapex's Avatar
kevinapex
OK....Intake filter K&N part# is a X-stream KNF RX-4140 $ 46.75 from AJ USA.com.
Vent filter KNF 62-1020 $ 15.74
All you will need from TurboHoses is the 3.5" od 90deg. stainless Item code pbss31290-312. $ 85.00
And like 12" of 3.5" silcone hose.. item code s3121r $ 68.00
Talk to Hover at TurboHose he will set you up.
