Turbonetics Detonating on 93 Octane
Old Dec 1, 2005 | 05:48 PM
  #61
onyx350z's Avatar
onyx350z
Thanks for the info.
Old Dec 1, 2005 | 05:56 PM
  #62
MIAPLAYA's Avatar
MIAPLAYA
No worries
Old Dec 1, 2005 | 06:14 PM
  #63
Git-R-Done's Avatar
Git-R-Done
Originally Posted by nissansource
There is all sorts of detenation from small to big. I dont need to get in a pissing contest with you.... By the way who needs devry??? home grown buddy.... And run a succesfull business in the performance industry
Any detonation,small or big is not good for your motor,do you not agree?
Old Dec 1, 2005 | 06:25 PM
  #64
JETPILOT's Avatar
JETPILOT
Why don't you PM him instead of dragging this out on my post.
Respect
JET
Old Dec 2, 2005 | 05:00 AM
  #65
nissansource's Avatar
nissansource
so hows the car comming along jet?
Old Dec 3, 2005 | 06:24 AM
  #66
CpraceZ's Avatar
CpraceZ
I would say get it on a dyno with some 93 in it just to be safe, your car was way rich on the dyno it would be hard to believe that exhaust could cause it to do that. We have had Turboed hondas with full exhaust that we have dropped when taking it to the track and not even seen that drastic of a difference in a/fs. I could have be bad gas also I would run the tank close to empty and put a fresh batch of 93 in it and get it on the dyno. The sound could be an exhaust leak also make sure you check and make sure thats not the sound you are hearing.
Old Dec 3, 2005 | 06:54 AM
  #67
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Hey Jet, please...as quickly as possible...get yourself a wideband AF gauge and a boost gauge. I agree, that its highly unlikely you went from sub 10's AF all the way to 12.0:1 and the danger zone.
Every FI owner should consider a boost gauge and wideband AF gauge as manditory equipment. I know you are planning to install them eventually...hopefully sooner rather than later.
Old Dec 3, 2005 | 07:28 AM
  #68
Git-R-Done's Avatar
Git-R-Done
You know Really Rich A/F ratios can have just as adverse affect on the motor as really lean A/F's. It could be PRE-detonation also from a hot spot in the motor, I mean we are talking a high compression motor with F/I on top of it..
Old Dec 3, 2005 | 08:09 AM
  #69
Sharif@Forged
Forged Performance
Not exactly. Rich AF ratios are not advisable, but they rarely damage the motor. When your motor starts running at less than 9.5:1 or so, you will get a misfire or stutter...but not detonation.
Overly lean AF ratios can so some major damage to engine very quickly. And I am not refering to 12.2:1 lean for a moment...
Old Dec 4, 2005 | 12:14 AM
  #70
JETPILOT's Avatar
JETPILOT
Well it's definetly detonation. I put 93 back in, and it was detonating again. I guess the colder temps plus the new exhaust is causing a rise in boost in addition to the increased air volume from the denser air, and more efficient exhaust. I put more 100 octane in, and the detonation went away again. Sorry guys this is definetly detonation and the only changes were as mentioned cooler temps, and new exhaust. I will have it on the dyno tomorrow and I will install my boost guage to get some hard numbers for you.
UTEC and electronic boost controller here I come.
Respect
JET
Old Dec 4, 2005 | 04:57 AM
  #71
35ounces's Avatar
35ounces
03 CS Track 6MT
Do yourself a favor and get gauges first. How do even know what boost your hitting?
Old Dec 4, 2005 | 06:06 AM
  #72
BoOsTedz33TT's Avatar
BoOsTedz33TT
turn your boost down, about 2-3 pounds with the 93 in it, until you can get your wideband and UTEC
Old Dec 4, 2005 | 08:38 AM
  #73
nissansource
ive been driving mine for a day now. I thought i heard Detonation once but not too sure inside its loud b/c of my feathering. Im still waiting for my DEFI boost gauge and inovative to put in and ill know for sure whats going on. other then that change your plugs i havnt done that yet with the set of NGKs i just got from sparkplugsource on ebay
Old Dec 4, 2005 | 04:11 PM
  #74
JETPILOT's Avatar
JETPILOT
Here is the deal... I installed my boost guage, and at 62F I am hitting dead on 11.5PSI. Sooooo warning to anyone thinking of an open exhaust with the stock TN tune.....WATCH OUT. I put it on the dyno today, and my A/F @ 6200 RPM was 12.39. At 42F the other night when I got the detonation for the first time just after adding the new exhasut I'm sure my A/F was well above 12.39. Tomorrow I will install my mechanical boost controller and lower the boost back to 8PSI.
Respect
JET
Old Dec 4, 2005 | 05:11 PM
  #75
Peking's Avatar
Peking
Originally Posted by JETPILOT
Here is the deal... I installed my boost guage, and at 66F I am hitting dead on 10PSI. Sooooo warning to anyone thinking of an open exhaust with the stock TN tune.....WATCH OUT. I put it on the dyno today, and my A/F @ 6200 RPM was 12.39. At 42F the other night when I got the detonation for the first time just after adding the new exhasut I'm sure my A/F was well above 12.39. Tomorrow I will install my mechanical boost controller and lower the boost back to 8PSI.
Respect
JET
JET I turned down my standered boost controller as much as it would let me, still over 9psi.
Sorry if I missed where you might have said this if you have, what spring do you have in the wastegate? Cause if it is the provided one (9lbs) then you should remove that one and change it with the 7lb one. Until you can make the needed upgrades for more boost.
Old Dec 4, 2005 | 05:16 PM
  #76
Z BOY's Avatar
Z BOY
never mind. i responded to wrong thread.
Old Dec 4, 2005 | 05:53 PM
  #77
kcobean's Avatar
kcobean
Respect
JET
Boy does THIS sound familiar.....see this thread for my horror story:
https://my350z.com/forum/forced-induction/157278-uncontrollable-boost-mystery-of-the-ages.html
  #78
JETPILOT's Avatar
JETPILOT
Can someon please tell me how an exhaust will allow the TN kit to boost 11.5PSI. Damn !!!!
Respect
JET
Old Dec 4, 2005 | 05:59 PM
  #79
westpak's Avatar
westpak
SFZCC
Respect
JET
Because there is no boost controller to control the boost, the wastegates are only controlled by the spring and it is not an exhaust on/off type thing like a selonoid, the kit was probably designed with stock exhaust so when you open up the exhaust it allows the turbos to spool easier and therefore spike and spring is just not strong enough to control it. Just as an example with my 300ZX when I removed the cats and installed a bigger exhaust the boost went from 9 to around 11 psi without doing anything else.
Old Dec 4, 2005 | 06:01 PM
  #80
kcobean's Avatar
kcobean
Respect
JET
I would love to know that myself. There are a few of us having this issue. Pretty damn frustrating.
