Turbonetics Detonating on 93 Octane
Old Dec 6, 2005 | 11:30 AM
  #141
JETPILOT's Avatar
JETPILOT
Thanks to you Mia.... There is alot yo udo behind the scene working as a liason between the consumer on these boards and Turbonetics. It is much appreciated.
This board is a valuable tool in huge part because you make it so.
Respect (To Mia and TN. This respect is well earned !!!)
JET
Old Dec 6, 2005 | 11:32 AM
  #142
MIAPLAYA's Avatar
MIAPLAYA
JET
Thank you very much for the kind words...I'm always down to help...Hopefully the Turbonetics Owners Club page I've been working on will be up soon and it will help some more.
Old Dec 6, 2005 | 03:08 PM
  #143
Peking's Avatar
Peking
Yes and then I can post up all the naked pictures of myself that I have been saving for the right time
Old Dec 6, 2005 | 03:09 PM
  #144
MIAPLAYA's Avatar
MIAPLAYA
Wow....um....yeah
Old Dec 7, 2005 | 05:21 PM
  #145
JETPILOT's Avatar
JETPILOT
I have decided to install a 48mm Turbosmart wastegate replacing the 38mm Evolution that is included in the TN kit. I'm going to try to orient it in a way so the exhaust gas doesn't have to make a 90 degree turn to exit the up pipe to the dump tube. This reduces exhaust gas velocity tremendously.
I ordered the wastegate today, and I will have it installed next week. I will post my results.
Respect
JET
Old Dec 7, 2005 | 05:24 PM
  #146
35ounces's Avatar
35ounces
03 CS Track 6MT
Nice! I was looking at that one also and wondering if it will fit. I assume you are going to do some fabrication to make it work.
I'll be anxious to see your results.
I commend you for forging the trail. Good luck with it.
Old Dec 7, 2005 | 05:33 PM
  #147
JETPILOT's Avatar
JETPILOT
I am going to see if I can get an up pipe from TN without the wg hole or mount and I will figure some way to mount the new TurboSmart wg. I have no option here but to forge ahead and explore new territory.
I'm sure at this point that the new wg will be the solution.
Respect
JET
  #148
kcobean's Avatar
kcobean
JET, we're on the right path. Flipping the wastegate over and venting to atmosphere didn't help.....I was still able to pull 10.5 PSI in 3rd gear. Oh, and the car was VERY LOUD!!!!
Old Dec 7, 2005 | 05:37 PM
  #149
MIAPLAYA's Avatar
MIAPLAYA
Wow thats certainly a bigger gate. I was going to say a Tial 38 isn't much bigger then the Evolution (2MM) and might not have helped much. I'm gonna see if I can get another wastegate or another feed pipe from Turbonetics and weld two flanges on to make the return tube still functional for both gates (maybe two dump tubes) and send it to one of you to test.
Edit: Or figure out a way for the Newgen gate to fit..
Old Dec 7, 2005 | 05:48 PM
  #150
tig488's Avatar
tig488
ah, you are safe, im hitting 15-17psi everyday, no problems yet!!!
i keed, i keed! actually i do hit that but dont encourage it. im just hoping my motor survives until my new actuator gets here.
good luck getting it sorted out.
Old Dec 7, 2005 | 06:04 PM
  #151
kcobean's Avatar
kcobean
HA...due to some vacuum mis-routing during my testing of the atmospheric WG dump tonight, I hit 20.1 PSI. Car still runs!!!
Old Dec 8, 2005 | 09:46 AM
  #152
MIAPLAYA's Avatar
MIAPLAYA
So heres a weird update. Turbonetics has been TRYING to cause an overboost via opening up the exhaust tract to see what the deal is. There is an 05 test car in the shop, with the stock exhaust 8 PSI. They completely removed the exhaust and still get 8 PSI. If the reduction in backpressure is the cause wouldn't dropping the exhaust cause this?
Old Dec 8, 2005 | 09:48 AM
  #153
Alberto's Avatar
Alberto
Cranky FI Owner
^^yes
Old Dec 8, 2005 | 09:59 AM
  #154
35ounces's Avatar
35ounces
03 CS Track 6MT
Send Kelly's car to TNetics.
Old Dec 8, 2005 | 10:54 AM
  #155
MIAPLAYA's Avatar
MIAPLAYA
That wouldbe great as far as I'm concerned.
Old Dec 8, 2005 | 10:57 AM
  #156
MIAPLAYA's Avatar
MIAPLAYA
Actually heres an idea. Jetpilot, kcobean, or 35ounces could one of you unbolt the exhaust completely and take it around the block. See what boost you make.
Old Dec 8, 2005 | 11:05 AM
  #157
35ounces's Avatar
35ounces
03 CS Track 6MT
Unfortunately, its supposed to snow here all day tomorrow so it might be a bit before I could get to that
Old Dec 8, 2005 | 11:06 AM
  #158
MIAPLAYA's Avatar
MIAPLAYA
No worries...maybe kelly or Jetpilot (dont know your name sorry) can do it
Rob.
Old Dec 8, 2005 | 11:27 AM
  #159
kcobean's Avatar
kcobean
I might be able to do that. Worst case scenario, I could do that when I'm swapping the stock exhaust back on.
Old Dec 8, 2005 | 11:39 AM
  #160
MIAPLAYA's Avatar
MIAPLAYA
Jet....I know you're out there...can you try this for us?
