How much power is your JWT clutch holding?
Old Dec 9, 2005 | 02:01 AM
XBS's Avatar
XBS
Veteran
Default How much power is your JWT clutch holding?
I currently have a JWT clutch and flywheel and am going turbo with a built motor. anyways i want to know if i have to swap out the clutch since the motor is coming out anyways. Basically i will be around 500whp mostly drivin in the 400 range and 540 from time to time anyways and input is appreciated thanks!
Old Dec 9, 2005 | 07:34 AM
mcderns's Avatar
mcderns
I have about 8000 miles on my jwt clutch and flywheel. About 5000 of those miles were at 350hp, and 3000 miles at around 450hp. It seems to be holding up ok.
Old Dec 9, 2005 | 07:50 AM
marluci7's Avatar
marluci7
I had 636rwhp and 10,000 miles on my clutch...
Old Dec 9, 2005 | 08:26 AM
barthelb's Avatar
barthelb
Master
Do you know which one you have because JWT makes one that can hold 700 or more i think. I've had mine for 22000miles at 440 or higher. It spun on me once when i raced my friends M5 after that it has never slipped.
Old Dec 9, 2005 | 01:01 PM
baptist's Avatar
baptist
Hows the pedal feel on that combo, heavy?
Old Dec 9, 2005 | 02:57 PM
XBS's Avatar
XBS
Veteran
it is harder than stock but you get used to it. I got it from performance nissan so which ever one they stock is the one i got how do i know which one i have, i can check when the motor is out...
Old Dec 10, 2005 | 12:24 AM
baptist's Avatar
baptist
Ive got one sitting in my house waiting to go on the car, but as the weather is so bad in the UK, im not getting chance to really get the other one to slip. That being said, the stock clutch only slips every once in a while, might as well get my money out of it!
Old Jul 14, 2006 | 02:06 PM
synth19's Avatar
synth19
yes, which ones do you guys have?
Old Jul 14, 2006 | 04:24 PM
WA2GOOD's Avatar
WA2GOOD
Your clutch wiil be fine.............
Old Jul 14, 2006 | 04:50 PM
synth19's Avatar
synth19
WA2GOOD, how much torque can it accomodate? Can't seem to find the exact number anywhere....
Old Jul 14, 2006 | 05:03 PM
phunk's Avatar
phunk
CJ Motorsports
I ran the JWT clutch with 467rwhp and abused it really really bad, never had a problem with it slipping. The only time I was able to make it slip was when I checked to see if it could hold for a 2nd gear burnout from a complete stop on regular dry pavement with 295 drag radials. Not many clutches would hold that tho.
Old Jul 14, 2006 | 05:42 PM
WA2GOOD's Avatar
WA2GOOD
Not sure of the exact tq. number (can find out for you) that the clutch will hold, but I have pushed the limits on several JWT clutch equipped cars ranging from 400-625+ whp, never any issues. We did have one issue on our 800+ whp "monters G" with this clutch, we burned it up on the dyno... , but pretty sure that would have happened with most any clutch.
Old Jul 14, 2006 | 06:21 PM
Trav4011's Avatar
Trav4011
I've got a 1500kg pressure plate and ceramic disc from JWT that I will be testing in our drag car.. We plan to put around 850hp to the pavement.. and 27x10" slicks..
Travis
Old Jul 14, 2006 | 09:14 PM
lex350's Avatar
lex350
This is great news. I'm running a JWT clutch and was worried that I might have to change it out.
Old Jul 14, 2006 | 09:48 PM
synth19's Avatar
synth19
thnx for the post ppl... I will be going with this.
Old Jul 15, 2006 | 02:18 AM
BrokeZ's Avatar
BrokeZ
are you guys talking about the heavy duty version? i thought they made 2 different ones for the z...
Old Jul 15, 2006 | 09:39 AM
mraturbo's Avatar
mraturbo
We have been working with JWT on some new clutch UNITs to hold over 700WHP...Both single and dual
Will get details to you soon.
We have 3 of them for our High WHP cars...Pretty cool.
NOTE:
It is very difficult to find a clutch that is streetable that can hold 700WHP.
M
Old Jul 15, 2006 | 10:29 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
NOTE:
M
The ATS triple disc will hold 700whp EASY and it's VERY streetable. IT's also VERY expensive.
As for me, my JWT is holding great with 10K+ miles on it at well over 400rwhp.
Old Jul 15, 2006 | 10:35 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
ATS setup is the most streetable of the heavy duty clutch/flywheel packages.
We have installed numerous JWT clutches, and pedal pressure is near stock...maybe just a tad stiffer. Clutch feel will also depend on the condition of your clutch fluid, and any potential air in the system. Some pedals will feel harder than others.
With standard off the shelf JWT clutch, I usually recommend them for mild FI builds only. If you road race, you can probably get pretty good life out of them. Aggressive slipping and drag racing will tear them up much faster.
Old Jul 15, 2006 | 05:12 PM
mraturbo's Avatar
mraturbo
I agree. How much is my price for the ATS Sharif? PM please...We put one on Eagle's and it was over $2k! Ouch...
M
