SFR twin plenum intake manifold
Old Dec 17, 2005 | 04:41 PM
  #81
Ep3's Avatar
Ep3
i'd like to see you guys fit an intake and TB ontop of a plenum.. wtf kind of hood would be required to run that?
Old Dec 17, 2005 | 04:49 PM
  #82
Jun's Avatar
Jun
subscribing.
Old Dec 18, 2005 | 09:13 AM
  #83
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
About the flow of the intake manifold.....we are not finished with it yet.This is just a prototype.The entry is being revised as we speak and then off to the flowbench and hopefully onto my car for dyno testing very soon.I will post some revised pictures this week.
Running twin TB's would be easy.We actually sketched up another intake with twin TB's coming in from the front of the motor.This by far would look the best and have excellent flow but the big problem would be throttle response and the lack of it because of two big throttlebodys.However this might be the way to go to make over a thousand horsepower and still keep the fly-by wire set-up.
Tim
Old Dec 18, 2005 | 03:45 PM
  #84
mistaboosta's Avatar
mistaboosta
actually you dont need a twin throttle setup for 1000+ hp. This is the 350z that runs 6.4 second 1/4 miles which i think is the record for 350z. The car is made by Performance Motorsports and reinforced by twin Innovative turbos with titanium wheels in both sides of the turbo (exactly the best place titanium is needed) letting it to spool faster. The people that went to SEMA prolly has seen this IRL. Enjoy!
ps: Performance motorsports claim the car to be around 1200 hp.
Old Dec 18, 2005 | 04:13 PM
  #85
MI 35th's Avatar
MI 35th
OGPremierMafia
thats tight
Old Dec 18, 2005 | 04:23 PM
  #86
MIAPLAYA's Avatar
MIAPLAYA
Actually last I heard those were Borg Warner turbos not Innovative but they might have switched again. Titanium is good but I would worry about the stress on the blades at least on the turbine side. Most big turbos like that use full Inconel turbine housings and wheels.
Old Dec 18, 2005 | 04:27 PM
  #87
mistaboosta
Borg Warner is the builder of the turbo kit but Innovative are the turbos.
I think titanium is strong enough for this application as it is also used in Mitsu TME turbos used in the mitsu's WRC car.
edit: as it is used in both EVO TME turbos and Mitsu WRC Car's turbo.
Old Dec 18, 2005 | 04:29 PM
  #88
MIAPLAYA's Avatar
MIAPLAYA
Hmm interesting...thats got to be one expensive turbo then...I wonder how well the titanium holds up under that heat on the turbine side. Do you have any info on compressor and turbine wheel life span?
Old Dec 18, 2005 | 04:44 PM
  #89
mistaboosta
i've used innovative turbos on my ex-cars. The one i used in my WRX was GTS66 (good up to 600hp) , and we used a GT76 on my friend's Supra (good up to 950 hp).
I've run around 1000 C degrees of EGT with my WRX as my internals were letting me to do so and boosted 28 psi with pump and to 34 psi with race gas. Used the car for 8000 miles till i bought the 350Z and parted out the WRX. Now we are installing this GTS66 turbo to a friends STI, it looks to be in perfect condition after 8000 miles.
PS: Let me clarify myself, the ti wheel is only on the comp side, on the exh side there is a billet aluminium wheel which is still very light. It is 03:44 AM here and i think i need some sleep. sorry for the wrong statement above.
Old Dec 18, 2005 | 04:47 PM
  #90
MIAPLAYA's Avatar
MIAPLAYA
Thats kinda what I thought you were saying..makes more sense now...
  #91
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Do you think the last intake manifold can be used with the stock strut bar?
Old Dec 18, 2005 | 04:55 PM
  #92
mistaboosta
when its late my fingers and my head just dont work together
LOL, you can use the rear strut bar if you really want to
Old Dec 18, 2005 | 07:38 PM
  #93
350Zteve's Avatar
350Zteve
That's one stout motor. If its running 6.4 in the quarter mile, its making 2000hp, not 1200.
Old Dec 19, 2005 | 02:13 PM
  #94
1G-350Z's Avatar
1G-350Z
+1 Perfomance Motorsports is my shop were I take my car, the car is around 1800hp.... And it normally runs Air Werks Turbos (BW). The photo had to be from SEMA. I think the shinny turbos were for the show, that's it...
Old Dec 19, 2005 | 04:14 PM
  #95
TurboTim's Avatar
TurboTim
If you want to keep the drive by wire and run a piggyback of some sort with the stock ECU then you must run twin stock TB's at a minimum.If you want to scrap the stock ECU and wire up a full stand alone along with running a single TB and throttle cable then that can be done too.There are no turbos that run titanium or aluminum turbine wheels.They will melt.The turbine wheels are probably inconel
Old Dec 19, 2005 | 06:00 PM
  #96
smoaky396's Avatar
smoaky396
OK OK OK..IMO looks are about number 10 on the list!...!st what are the numbers on it?...2nd When can I buy it...3rd were...4th When will a price be release. If I need to morgage my house i need to get the paperwork in order!!
Old Dec 19, 2005 | 06:40 PM
  #97
Julian@MRC's Avatar
Julian@MRC
We will be offering SFR products as they release them.we are authorized SFR dealers and installers on the east coast
Old Dec 19, 2005 | 06:50 PM
  #98
smoaky396's Avatar
smoaky396
sweet!!
Old Dec 19, 2005 | 07:39 PM
  #99
AmyCroft's Avatar
AmyCroft
Smile Authorized Speef Force Racing Dealer
Er Typo - in Sig
Cheers Amy -
6.4 Quarter Mile on a VQ is something that should be documented.. Somewhere?
Old Dec 19, 2005 | 09:00 PM
  #100
plumpzz's Avatar
plumpzz
its on their website..w/ a video
i think its theexperience.com..
