SFR twin plenum intake manifold
Old Dec 20, 2005 | 07:13 AM
  #101
QuadCam's Avatar
QuadCam
what the weight of that vehicle? I bet it is really light!!!!
....and 1800 HP sound high to me.
I don't think the turbocharged Small block V8s that run in the Pro Mustang classes make much more power than 2000HP, but they have minimum weight restrictions for those classes.
Old Dec 20, 2005 | 07:42 AM
  #102
mistaboosta's Avatar
mistaboosta
Originally Posted by TurboTim
If you want to keep the drive by wire and run a piggyback of some sort with the stock ECU then you must run twin stock TB's at a minimum.If you want to scrap the stock ECU and wire up a full stand alone along with running a single TB and throttle cable then that can be done too.There are no turbos that run titanium or aluminum turbine wheels.They will melt.The turbine wheels are probably inconel
u r telling that aluminium is gonna melt?
so then how come the forged pistons made of aluminium dont melt working under much more heat and pressure than the turbine wheel?
Old Dec 20, 2005 | 07:54 AM
  #103
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
Aluminum has a melting point right around 1275F.Titaniums melting point is below 1200F.The reason aluiminum pistons dont typically melt (because they will melt under the right, or shall I say wrong conditions)is because of the fact that fuel acts as a cooling agent.Not enough fuel and bam, your aluminum pistons will melt away Since EGTS of most turbocharged cars will exceed 1400F...... using aluminum on the turbine side of the turbo is
not going to happen.
Old Dec 20, 2005 | 11:52 AM
  #104
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Its a good question. You are correct in that AL melts at roughly 1200 degrees. However, becuase of the thermal properties of AL, it will not melt in a combustion chamber, even with 1600 degree+ EGT's.
The reason for this revolves around the concept of specific heat: specific heat is the amount of heat per unit mass required to raise the temperature of a substance by one degree. In simple terms, AL has a very high specific heat, which means it takes a lot heat/energy to raise the temperature of AL. So even with 1600 degree EGT's, and the piston doing its job...of pulling heat away from the crown, and down through the skirt, it will never melt. The surface temp of the piston is likely much less than 1000 degrees. Also note that combustion occurs in pulses, and all that heat from the piston and cylinder is constantly being transfered to the block, and through the cooling system. And with the fuel, air, and oil acting as a cooling agent between power strokes, your engine is running very safe.
This is the reason AL doesnt melt, even with very high combustion chamber temps.
Old Dec 29, 2005 | 09:20 AM
  #105
halitosis's Avatar
halitosis
//Bump//
for NA dyno numbers. Any new developments, Tim?
Old Dec 29, 2005 | 10:10 AM
  #106
TurboTim's Avatar
TurboTim
We need to get the results from the flow-bench before we put it on my car and dyno it.So it looks like sometime in early January is when we will have some results.We will still need to test it on an N/A car though.
Old Jan 6, 2006 | 01:31 AM
  #107
ether's Avatar
ether
any update?
Old Jan 6, 2006 | 03:17 PM
  #108
YBLegal's Avatar
YBLegal
how much??
Old Jan 6, 2006 | 05:01 PM
  #109
TurboTim's Avatar
TurboTim
Ok Fellas.We have been doing some flow bench work with this intake manifold and we got it to flow pretty good with a diverter plate.However, one bank is very turbulent so we sat there wondering what we could do about it and we came up with this idea. Scrap it! Yes we are scraping this design for a true dual plenum set-up. There will be two plenums now.One over each valve cover.They will be set-up for twin TBs or we can set it up for a single TB.The design s crazy and it is looking awesome.I will post some pictures in the next day or so.
Old Jan 6, 2006 | 06:03 PM
  #110
350zzzzzz's Avatar
350zzzzzz
sounds sweet finally someone is doing this.
Old Jan 7, 2006 | 05:19 AM
  #111
roncfpz's Avatar
roncfpz
Now that sounds very interesting.
Old Jan 7, 2006 | 02:46 PM
  #112
booger's Avatar
booger
With the twin TB's . Are you going to be able to retain the drive by wire ? or will you have to go to a cable throttle ?
Old Jan 7, 2006 | 03:09 PM
  #113
Fairlady_z33's Avatar
Fairlady_z33
Good question????????
Old Jan 7, 2006 | 03:10 PM
  #114
mazx6's Avatar
mazx6
My guess is it would have to go to cable throttle.
I wish we could have something like this.... even though it would probably never happen. Even with 2 TB if not individual.
Old Jan 7, 2006 | 03:37 PM
  #115
Fairlady_z33
That is a nice set up thats a 300zx correct?
I still dont even know if to wait or get either the motordyne 5/16 plenum spacer or the new crawford
Old Jan 7, 2006 | 03:58 PM
  #116
mazx6's Avatar
mazx6
Yup 300zx set-up. I'm in the same boat i don't know if i want to wait.
Old Jan 7, 2006 | 04:04 PM
  #117
Fairlady_z33
if product is going to be out soon then ill give it a wait but if it is going to take some while ill just buy the spacer and then do the upgrade.
Old Jan 7, 2006 | 04:10 PM
  #118
thawk408's Avatar
thawk408
New crawford as in cast plenum?
Old Jan 7, 2006 | 04:29 PM
  #119
Fairlady_z33
i guess yea the black one in their website
Old Jan 7, 2006 | 06:54 PM
  #120
shaun_walsh's Avatar
shaun_walsh
I look forward tothe numbers and the price
