440 Injectors/Turbonetics w/out Return Fuel System
Old Dec 14, 2005 | 08:02 PM
JETPILOT's Avatar
JETPILOT
Default 440 Injectors/Turbonetics w/out Return Fuel System
If I add 440 cc injectors to the stock TN kit without going with a return fuel system would the stock system with the TN mods allow power in the 420-440rwhp range?
Are their gains to be made by just adding the 440cc injectors?
Respect
JET
Old Dec 14, 2005 | 08:57 PM
Julian@MRC's Avatar
Julian@MRC
I doubt you will see any gains from simply adding a larger injector, you may run richer throughout the RPM range.Depending how rich you may actually loos HP or foul plugs..
Old Dec 14, 2005 | 09:09 PM
k3silk's Avatar
k3silk
alot of people belive that if you run rich = your safe. just because you run rich does not mean your are not doing harm.
Old Dec 14, 2005 | 11:45 PM
JETPILOT's Avatar
JETPILOT
I should have clarified... 440 injectors a tune and increased boost. Maybe I shouldn't have thought that was obviuos. My bad. Soooo there is a lot to be gained from a larger injector if the fuel system is up to the task. The question is weather the fuel system is up to the task.
Respect
JET
Old Dec 15, 2005 | 05:42 AM
CpraceZ's Avatar
CpraceZ
I think with a good tune with that setup you could see some pretty decent gains, the fuel system would give you more to work with of course, but with the bigger injectors it gives you more room to play with and by remembering your dyno graph before you put the exhaust on I think the tune would make a big difference depending on how much the exhaust changed the a/fs
Old Dec 15, 2005 | 08:27 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Doable, but the tuning becomes trickier. Becuase your fuel pressure will essentially be dropping at the injector nozzle (due to the manifold pressure pushing back on the nozzle), without a rising rate FPR and return system, you will have to add excessive injector pulse width to compensate.
It's doable, for sure, but not ideal. I guess that is the best way to describe it.
Old Dec 15, 2005 | 08:49 AM
HoldThisForMe's Avatar
HoldThisForMe
can you add a rising rate to the stock system? sorry if thats a dumb question
Old Dec 15, 2005 | 09:10 AM
MIAPLAYA's Avatar
MIAPLAYA
Yes this is absolutely possible. It would basically be like tuning a Greddy TT kit without a fuel return. And sure they are definitely gains there.
Old Dec 15, 2005 | 10:04 AM
Sharif@Forged
Forged Performance
No, not without a return setup.
