SGP Valve Body Upgrade
Old Dec 17, 2005 | 08:45 PM
CESAROTORRES's Avatar
CESAROTORRES
Default SGP Valve Body Upgrade
To all the owners of the SGP VB.
I am about to send my VB to SGP, but first I like to make sure that the SGP VB upgrade really take care the REV LIMITER problem with out reflash to bump the rev limiter. All advices will be higly appreciated.
Thank you
Cesar
Old Dec 18, 2005 | 05:07 AM
booger's Avatar
booger
Getting mine back Monday . Sorry I cany help , Ive already bumped the rev limit to 7200rpm .
Old Dec 18, 2005 | 07:06 AM
Jokestrap's Avatar
Jokestrap
I live in Houston so I get all my work done at SGP. If they say they can do it, it's because they can...
Old Dec 18, 2005 | 07:47 AM
SungNamZ's Avatar
SungNamZ
I would check with SGP. Like "booger", mine has already been increased to 7200. However, I think their VB upgrade is improving the shift delay within the AT and not the REV LIMIT within the ECU. You are probably looking at pulling your ECU and sending it to TS and getting the "L" Flash. Perhaps SGP has the capability to perform ECU Flash.
Old Dec 18, 2005 | 09:23 AM
nexstage350's Avatar
nexstage350
best bet to give them a call. they can do no problem
Old Dec 18, 2005 | 11:11 PM
1G''s Avatar
1G'
it's not going to do that because thats not what it's ment to do. you have to raise your revlimiter and it still will do it from time to time. so you really have to just switch to manual mode when you plan to drive hard! trust me you will want to anyway. simply because you can stay in the gear as long as you want that way.
just my .2
Old Dec 19, 2005 | 05:46 AM
KShep's Avatar
KShep
Subscribing...what's the estimated turnaound time for this mod/
Old Dec 19, 2005 | 07:36 AM
SungNamZ's Avatar
SungNamZ
Good question! It is that "turn around time" that is holding up my decision. I believe in another post to a previous thread I saw 5 days. Then throw in shipping and you are somewhere in the 7-9 day timeframe. If your car is your daily driver, do you borrow, rent or go on vacation? Perhaps they will eventually get to a point where they can offer a Core Program.
Old Dec 19, 2005 | 08:29 AM
KShep's Avatar
KShep
From the info posted on the SGP website it looks like 10 days. Also looks like they recommend the SGP torque converter and tranny cooler upgrades with this mod due to higher temps.
Old Dec 19, 2005 | 11:26 AM
booger's Avatar
booger
Well they had my VB for 5 weeks . Thier web site says 4 to 10 days . He may have put others in front of my VB because he had my block at the same time and knew I didnt need it till the block was done
Old Dec 19, 2005 | 12:12 PM
1G''s Avatar
1G'
took about 2 weeks. you really want to run a tranny cooler. but this mod is GREAT!!!! very much a must do for boosted 5AT's
Old Dec 19, 2005 | 12:28 PM
KShep's Avatar
KShep
Did you add a tranny coooler or TC upgrade?
1G where did you install the tranny fluid cooler?
Old Dec 19, 2005 | 03:37 PM
1G''s Avatar
1G'
down buy the IC
Old Dec 19, 2005 | 05:56 PM
KShep's Avatar
KShep
Originally Posted by 1G'
down buy the IC
Thanks...I might be able to get one in horizontally...vertical install impossible as far as I can tell.
Apologies for the hijack.
Rev_Night
Nov 7, 2020 06:00 PM
