Jim Wolf Turbo Kit
Old Dec 29, 2005 | 07:34 PM
  #161
WA2GOOD's Avatar
WA2GOOD
Originally Posted by trebien
What I like about the JWT kit is what VRT keeps alluding to... the first rule of efficient FI is using turbos that are just big enough for your goals, but not bigger. Many other twin turbo kits use bigger turbos, and have the ability (overhead) to run 800 hp...
But unless you really want to eventually get 800 hp, there is no use. You'll just be carting around bigger turbos with overhead that you don't need. That bigger turbo will spin up slower and cause lag. The power will shift to the upper ends of the RPM band, with more lag down below. The power comes on so fast, it's difficult to manage.
Truth is, 800+ hp is mostly going to go to waste in a G35/350z without massive, super sticky tires and AWD.
I'm not looking for a 1/4 mile monster... wrong car, for one thing. I want a very streetable and trackable setup with even delivery of power (therefore predictable and manageable).
Sure, there are all kinds of street cars with 800+ hp... but you won't see them making good time around a track. For instance, Hennessey Motorsports got a lot of attention when they brought out their 1000+ hp TT Viper... but any time they were part of a comparo in C&D or Motor Trend, or One Lap of America, they weren't taking that package to the tracks. They were using lesser HP cars with nice torque curves. Wonder why?
VRT - what's your experience as to the weaknesses/limits of the drivetrain? Especially the rear end and 6MT tranny? Aftermarket solutions? Torque tends to make things "snap".
We, surprisingly, have found the only week spot in the entire stock drivetrain is the factory clutch, and only on FI cars. The 6MT tranny and axle shafts seem to hold up real well for our purposes, and have had no problems to date.
Scott at VRT
Old Dec 29, 2005 | 08:15 PM
  #162
xziteme's Avatar
xziteme
VRT- Since you guys track your cars alot, do you guys have any problems with oil temps and/or taken any steps to reduce the oil temps?
  #163
SinCity350Z's Avatar
SinCity350Z
Track Whore
^^^Stillen oil cooler.
Old Dec 29, 2005 | 08:56 PM
  #164
xziteme's Avatar
xziteme
Few questions about the Stillen oil cooler w/ the JWT TT...
1) I know it doesn't have a thermostat. Is it installed to work w/ the stock oil cooler?
2) Where is a good location to install it? Front of left wheel well?
Old Dec 29, 2005 | 09:01 PM
  #165
G3po's Avatar
G3po
Scott at VRT
But if you ever drag race with DRs or Slicks (above 500rwhp) the OEM half shafts can snap, seen it happen at Infineon Wed night drags. Otherwise OEMs are fine. Upgraded half shafts can be gotten from the Driveshaft shop (thru ForgedInternals.com).
Old Dec 30, 2005 | 06:04 AM
  #166
WA2GOOD's Avatar
WA2GOOD
1) yes
2) yes, or on the upper side in front of the radiator.
Scott at VRT
Old Dec 30, 2005 | 06:12 AM
  #167
WA2GOOD's Avatar
WA2GOOD
I agree. In most cases the stock half shafts are fine, but for any heavy load launching with boost, I do, and have recommended that you upgrade to these stronger ones. Most people know this, but good point anyway, thanks.
Scott at VRT
http://www.violentracing.com/
Old Dec 30, 2005 | 06:16 AM
  #168
Mike Wazowski's Avatar
Mike Wazowski
Scott at VRT
We will be putting mine to the test in the near future... I am going to let Alberto the 1/4 mile GOD ****** some low azz 11's for me.
Old Dec 30, 2005 | 06:28 AM
  #169
WA2GOOD's Avatar
WA2GOOD
Sounds good John, let me know how it turns out.
Old Dec 30, 2005 | 09:05 AM
  #170
350Z4JAG's Avatar
350Z4JAG
Get some Video of that Torque beast of yours running the 1/4. I for one would like to see that thing launch with boost! Are you going to get some drag radials to try this with or regular street tires??
Old Dec 30, 2005 | 09:12 AM
  #171
Mike Wazowski
He said he has some DR's. I have to set up the logistics of how we are going to do this and everything. He is up north soemwhere. I need to get in contact with him.
  #172
Mike Wazowski
I will see if he has a video camera. I don't have one hahaha
Old Dec 30, 2005 | 12:44 PM
  #173
vision619's Avatar
vision619
Originally Posted by mraturbo
You go Mike - vision619.
Want to square off at Willow and Laguna Seca...
M
Let's do it! I'm not racing your built G though. You better get in a non-built car like mine
Old Dec 30, 2005 | 12:47 PM
  #174
vision619's Avatar
vision619
1) yes
Scott at VRT
My stock oil cooler was removed because of some sort of interference with the Stillen Cooler. ?? I'll try and find out why. I know it's not NESSISARY, but just done to improve performance.
Old Dec 30, 2005 | 08:57 PM
  #175
mraturbo's Avatar
mraturbo
Dude,
Your car is lighter, has better suspension, and a locked rear end. Learn to drive that man and it will be a great match up regardless. Just think about my Z at low boost passing DB's Black G at Willow Springs on turn nine. Both on slicks. Pucker up....
No excuses.
JY, still wish you were here man. I need your motor.....
M
Old Dec 30, 2005 | 09:49 PM
  #176
AmyCroft's Avatar
AmyCroft
Unhappy Are you drunk or just being a POST *****
Dude,
No excuses.
M
Old Dec 31, 2005 | 04:12 AM
  #177
Never Mind's Avatar
Never Mind
so the JWT TT kit can be installed on a stock block.. what is the highest boost that you can run and being in the safe side?
Old Dec 31, 2005 | 05:02 AM
  #178
booger's Avatar
booger
VRT...Its more than likely been mentioned , but what engine managment system does the JWT kit use ? And can you purchase the kit from you and have a local shop install it ?
Old Dec 31, 2005 | 08:35 AM
  #179
mraturbo's Avatar
mraturbo
Wow,
FIRST - Amy Croft, didn't know it was a crime to post on more than one Thread. Maybe a Lil Tipsy at 11:30 PM - rare for me...Just have limited time on the computer to view, post, reply, or whatever. Excuse ME for being busy running a few companies and consistently making kick-*** VRT cars.
BTW, are you a Girl or Boy? Not making a stab - just confused and like to know who publicly thrashes me for NO REASON when they really have NO IDEA WHO I AM.
Warmly,
Michael call me (The Post *****) if you want...
http://www.ViolentRacing.com
Old Dec 31, 2005 | 08:36 AM
  #180
mraturbo's Avatar
mraturbo
Sorry Booger,
Your Question: We use Split Second and so does JWT.
www.Splitsec.com
Laptop programmable and allows us reasonable control over A / F, Timing, and Voltage that we can monitor from our FMU and Boost controlled set-ups. The User-Interface needs improvement for sure, yet it is very functional.
As for the JWT Kit, please PM or register at my site
We can discuss prices. Not at liberty to sell you a kit to install in your hometown though.
Please PM if you have any questions.
Thanks
Michael
