Engine Rebuild for Greddy TT
Old Dec 19, 2005 | 07:11 PM
BamBam's Avatar
BamBam
Talking Engine Rebuild for Greddy TT
Alright,
I have started the long laborious process of building a new engine for my ride.
Parts have been ordered and the block is getting cleaned, redecked and all that other jazz.
I thought I might throw my build details out there for you guys, if anyone is interested:
JE Pistons w/ wrist pin upgrade
Pauter Rods
ARP Main & Head Studs
Cometic Head Gasket
Darton MID Sleves
Ferrea Valve train
JWT Cams
1000cc Injectors
Upgraded Fuel system
F-Con Pro EMS
The engine will be sent off for cryo treating and then key parts will be sent off to be heat treated. Dave is documenting the process now.
This setup in conjunction with the new exhaust and EMS should give me plenty of power and hopefully a relatively decent lifespan on the boosted engine. We are thinking to upgrade the turbos if we see that they are pushing their upper limits around 15 -20psi
Hopefully by March I should be rocking a whole new ride and then it will be time for a new LSD and axle.....
Old Dec 19, 2005 | 07:27 PM
marks350Z's Avatar
marks350Z
Good luck on your adventure! My motor is being built as we speak. I saw it today with the 18 G turbo's mounted... it looks so awesome... I don't know how bigger turbo's would fit... the 18 G is so close the the engine mount!
Old Dec 19, 2005 | 08:16 PM
Royal_T's Avatar
Royal_T
Man......Lucky......
Where did you get your 1000cc injectors from?
Good luck with the build
Old Dec 20, 2005 | 03:57 AM
ImportPartsPro's Avatar
ImportPartsPro
Vendor - Former Vendor
RC Engineering makes 1000cc Injectors for the 350z/G35
Old Dec 20, 2005 | 08:18 AM
BamBam's Avatar
BamBam
Kyle is right, those are the ones I have.
As for the turbos, the first step I believe, would be just to change the wheels /compression ratios.
Old Dec 20, 2005 | 08:26 AM
roncfpz's Avatar
roncfpz
Thanks for posting your info and good luck with the build. Very impressive!
Did you pull your existing engine or buy another block for the build?
Ron
Old Dec 20, 2005 | 08:33 AM
BamBam's Avatar
BamBam
Basically doing a core swap when this is complete. We are using the shops engine to build my new one, and they will take my current engine when we are done.
Old Dec 20, 2005 | 08:43 PM
chuquison's Avatar
chuquison
how much would it be for a block no pistons just bare bone block?
Old Dec 21, 2005 | 05:26 AM
Royal_T's Avatar
Royal_T
Thanks for the info. Do you know how much they usually run for?
Old Dec 21, 2005 | 07:02 AM
BamBam's Avatar
BamBam
RoyalT: I paid over 1,000 for mine.
chuquison: Short or long block..? I would say it could very between $2,000 - 3,000 but as I am not buying the blocks just swapping, I am not sure.
I would suggest contacting one of the many sellers/installers on here like AAM, CPRacing, Forged Internals, SGP or Performance depending on your location.
I am sure they will all do you right on pricing.
--B
Old Dec 21, 2005 | 08:11 AM
ImportPartsPro
Just a bare block w/o the crank NEW from Nissan is ~$1300
Then a brand New crank = ~$550
ImportPartsPro
Check your PM's
Old Dec 21, 2005 | 03:40 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Originally Posted by BamBam
Alright,
Pauter Rods
Cometic Head Gasket
Darton MID Sleves
Ferrea Valve train
JWT Cams
1000cc Injectors
F-Con Pro EMS
Nice setup. Those 1000cc RC low impedence injectors will work nicely with the FCON.
Old Dec 21, 2005 | 03:52 PM
BamBam's Avatar
BamBam
Thanks Sharif,
Been planning this for some time now. Started small and has been growing... Need to join a modders anonymous club or something...
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
Fixxxercask
Nov 9, 2015 11:10 AM
