Just started my Turbonetics Install !!
Old Dec 28, 2005 | 05:48 PM
MIAPLAYA's Avatar
MIAPLAYA
Got you covered buddy check your PMs..
Old Dec 28, 2005 | 05:51 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Thanks again MIA for your help. Guys MIA is the man, he called me a few minutes ago with a solution to my problem, great person/resource to have on these boards, I cant thank you enough man....
Old Dec 28, 2005 | 05:53 PM
blk180sx's Avatar
blk180sx
Originally Posted by Alberto
Quick Q MIA-do you know if TN is flashing ECU's this week? I sent mine in Monday to them, I would imagine they were closed, they would get it Wednesday at the latest and I would have it by Friday. I called Reggie today because I was missing my BOV horn I forgot to include the letter in the ecu box stating I needed it shipped back with the flash. I called him but I never got a call back, I guess he was busy. Just curious if you knew if they were operational this week or not.
Sorry I didnt get back to you. I made sure that your ecu went out with the horn. If you have any further questions please feel free to call me at 805-581-6710.
MIAPLAYA's Avatar
MIAPLAYA
No worries...shot you back some alternate sources in case my guy doesn't have it. Luckily his dealership parts dept links to about 7 others in the Socal area so even if its not at his shop he can get it and send it. Should have some news for you tomorrow around 0800 PST.
Old Dec 28, 2005 | 05:54 PM
craigo'sznprgrs's Avatar
craigo'sznprgrs
Hey Reggie, can Fedex deliver before 10 on Saturday, if so they may be able to get to my car?
Old Dec 28, 2005 | 05:55 PM
MIAPLAYA's Avatar
MIAPLAYA
LOL I vote for a new screenname for you... Reliable Reggie...LMAO... thanks for taking care of the guys on the board. You don't hear thank you enough and you should...
Alberto's Avatar
Alberto
Cranky FI Owner
No problem at all man, thanks for letting me know. So my ECU shipped back out?
Old Dec 28, 2005 | 05:59 PM
MIAPLAYA's Avatar
MIAPLAYA
Sounds like it did...
Old Dec 28, 2005 | 06:08 PM
kcobean's Avatar
kcobean
+1. You rock Reggie.
Old Dec 28, 2005 | 06:20 PM
Vadian's Avatar
Vadian
Default Pics!
Take some pics of the install!
Old Dec 28, 2005 | 06:39 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Ask and you shall receive
First pic is the fuel pump assembly out of the car and a shot of the Walbro pump sitting inside the assembly.
Second pic is the fuel pump assembly with the 2 3/8" holes you need to drill
Third pic is the fuel regulator orifice after being drilled out to 7/64"
All these steps were simple....
Attached Thumbnails Just started my Turbonetics Install !!-donefpa-large-.jpg   Just started my Turbonetics Install !!-holes-large-.jpg   Just started my Turbonetics Install !!-img_2711-medium-.jpg
Old Dec 28, 2005 | 06:42 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Thumbs up
Some more pics-
Close up of lower plenum, an under hood shot with no plenums on before taking fuel rails out, and a shot of the stock injectors (black) and TN injectors before moving the bottom o-rings around and adding the injector spacer to the top of the TN injectors....
Attached Thumbnails Just started my Turbonetics Install !!-img_2722-large-.jpg   Just started my Turbonetics Install !!-plenumsoff-large-.jpg   Just started my Turbonetics Install !!-readytomodinj-large-.jpg
Old Dec 28, 2005 | 07:01 PM
tig488's Avatar
tig488
what are the two holes drilled in the fuel pump assembly for?
Old Dec 28, 2005 | 07:08 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Not sure but it tells you to do that. Maybe when the fuel gets low the holes will allow the pump to pick up gas easier?
Old Dec 28, 2005 | 07:09 PM
tig488's Avatar
tig488
hmm, i just looked thru the instructions i downloaded a while back and it isnt in there, it must be something new.
Old Dec 28, 2005 | 07:17 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Check out these instructions---> http://members.***.net/turbonetics35...icsinstman.pdf
Page 15, step K, figure 21 on that same page.
Old Dec 28, 2005 | 07:35 PM
ZON's Avatar
ZON
Good luck with it Alberto. Can't wait to watch your next vid's from the track.
Old Dec 28, 2005 | 07:54 PM
  #38
Alberto's Avatar
Alberto
Cranky FI Owner
Thanks, Im looking forward to it...
  #39
vitaminZ's Avatar
vitaminZ
Alberto, good luck with the rest of the install. there are few PITAs left but in the end it will all be worth it!!
+1 on the comments about Reggie and MIA. During my install, MIA helped me and my friend Dan out with some questions we had. also, I had a v-band clamp that i apparently over-torqued (snapped @15 minutes after the fact) and Reggie sent one out to me right away, no questions asked. between MIA, Reggie and Dan my install was possible with the least amount of head aches!! after working out some quirks (my fault) i drove my Z for @900 miles before getting deployed with no issues.
my install pics: http://gallery.thevboard.com/index.p...0INSTALLATION%
Be sure to:
*Make sure to use teflon paste instead of tape.
*Use metal zip ties to secure the heat wrap. i purchased mine at www.summitracing.com.com
*Make sure all the clamps over the sillicone couplers coincide with the grooves.
*Be sure to put thread lock on the O2 sensor plugs.
Old Dec 28, 2005 | 07:58 PM
  #40
Alberto's Avatar
Alberto
Cranky FI Owner
Be sure to:
Thanks for the heads up. I already have teflon NPT thread tape, and metal zip ties from Summit to go along with my DEI exhaust wrap. I havent even opened the box with the clamps but Ill be sure to mate them with their couplers well. I shouldnt get to the piping until Friday, tomorrow Im just finishing the fuel pump assembly and hopefully the injector swap and put the plenums back on.
