Guess on my hp
Old Jan 10, 2006 | 12:11 PM
MoodDude's Avatar
MoodDude
Default Guess on my hp
Here is what I have today:
APS TT, Stillen exhaust, Test pipes, 440 whp
Here is what I am planning (in order) over the next couple of months:
-5/16" plenum spacer
-RPS Flywheel and clutch
-Water Injection and raising boost to 11psi
-tune
I am estimating 515whp - any other guesses.
I will dyno in late March and post the results.
Old Jan 10, 2006 | 12:20 PM
zrausch's Avatar
zrausch
Your going to run over 500rwhp without a built engine?
Old Jan 10, 2006 | 12:24 PM
MoodDude's Avatar
MoodDude
Yes - I am not the first - many others have pushed up 500+rwhp on a stock engine.
Old Jan 10, 2006 | 12:29 PM
Jaki's Avatar
Jaki
Are you just guessing that you're at 440rwhp or did you tune it to 440rwhp? What boost are you running?
JETPILOT's Avatar
JETPILOT
Many? Like who? I know of one.
Respect
JET
Old Jan 10, 2006 | 12:31 PM
MoodDude's Avatar
MoodDude
440rwhp was dynoed with the current mods, only running 9psi.
Just thought it would be fun to guess.
Old Jan 10, 2006 | 12:46 PM
roncfpz's Avatar
roncfpz
Okay, I'll be the first.......490whp. Bigbri has similar setup and puts down 550whp at 15psi with custom grind cams. Good luck man!
Ron
Old Jan 10, 2006 | 01:02 PM
dirtroad's Avatar
dirtroad
Ron
I'll bid $1, Bob.
Old Jan 10, 2006 | 01:09 PM
Zilvia's Avatar
Zilvia
Zippy car runs like 560whp on the stocker
BigBri-550whp
i know there are more but most of them have built up now
Old Jan 10, 2006 | 02:10 PM
failsafe306's Avatar
failsafe306
More like 460whp on a BUILT motor
Old Jan 10, 2006 | 02:20 PM
barthelb's Avatar
barthelb
Master
Mine was at 488 til it got retuned to 462whp. I kept getting boost spikes to 11psi so i had it retuned and they put it on the dyno without touching anything and it was making 488.
When my motor is built and waiting for install Im gonna get the 3.5"APS DownPipe/test pipes, plenum and retune for 10.5/11psi and see what happens. Hopefully just another 500whp stocker. Some motors can do it. Some seem to have an issue making power and still sounding or reading like they will hold together.
Old Jan 10, 2006 | 02:25 PM
bigbri's Avatar
bigbri
BigBri-550whp
Nobody has 560whp on a stock block....I know I am the first to have over 520whp on a stock block so far...
Old Jan 10, 2006 | 04:10 PM
Jaki's Avatar
Jaki
My guess would be a little shy of 500rwhp, may be a little above... really depends on the tune. Are you going to run 100 octane as well?
Old Jan 10, 2006 | 04:30 PM
overZealous1's Avatar
overZealous1
well you can tune it to whatever you want. but will it hold? big bri has a factory freak i think. the only other guy i know over 500rwhp on stock block blew his motor up.
Old Jan 10, 2006 | 04:53 PM
D350Z10's Avatar
D350Z10
Very true many people have ran 500+ on a stock block.. It can handle it but you need a DAMN good Tuner!!! I predict you will be around 520-540 range
Old Jan 10, 2006 | 05:22 PM
Zilvia's Avatar
Zilvia
woops............okay so Bigbri is the only one........
Old Jan 11, 2006 | 02:31 PM
failsafe306
Don't forget Zero2prove, he's a little over 500whp.
Old Jan 11, 2006 | 02:37 PM
ZON's Avatar
ZON
Bigbri has water alcohol injection and a great tuner. This is the main reason. Well, that and he has a huge set of *****.
Old Jan 12, 2006 | 04:32 AM
MoodDude's Avatar
MoodDude
Just to let you all know-
I will be using a Water/Methanol mixture to control detonation.
I have a boost controller and most of the time I run low boost when I am driving, I just turn it up on special occasions (race).
I will not be running Race fuel (that is what the water injection is for).
My main goals are to get a AFR of 12 and run 9psi and a big gain (this will cause a spike over 9psi for a short period). I will probably just run the higher hp for the dyno and not after since it is pretty rediculous power and I don't plan on getting biger than 275 on the rear.
416blueZ
Jun 11, 2024 10:56 AM
350z82
Oct 1, 2015 06:25 PM
416blueZ
Sep 24, 2015 02:11 PM
