Greddy or Turbonetics.. I knew this would happen..
Old Jan 12, 2006 | 08:46 AM
  #61
BlackZero6's Avatar
BlackZero6
ok, im ready to get yelled at by you guys but im not looking for anything over 400hp and i want to keep my z a daily driver
im in cali and im worried about passing smog and i have two options, i can wait till aps gets carb cert or pay off some guys.
i am also really interested in the tnst.....what should i do?
Old Jan 12, 2006 | 09:25 AM
  #62
MIAPLAYA's Avatar
MIAPLAYA
Exactly..if you are keeping the car mostly stock for now and want between 365-380 RWHP Turbonetics will do that for you. When Turbonetics releases Stage II there will be a low cost upgrade kit for those with Stage I to do that will get them a T66 turbo, bigger wastegate, bigger BOV, bigger injectors, and a tuneable EMS. The turbo in Stage II will be set up for 550 RWHP out of box at 15 PSI but the turbo kit upgrade itself will good into the 700s.
Old Jan 12, 2006 | 09:28 AM
  #63
Zilvia's Avatar
Zilvia
well you could got for the TN with a cat
wait for :
GREDDY, APS, & JWT to put out their CARB kits
Old Jan 12, 2006 | 09:31 AM
  #64
MIAPLAYA's Avatar
MIAPLAYA
True...with the cat on the downpipe it looks like the Turbonetics kit will actually pass the sniffer just not visual. Of course its easy to find someone to look the other way as long as it passes the sniffer...
Old Jan 12, 2006 | 09:40 AM
  #65
buho62's Avatar
buho62
Around how much is the installation of Turbonetics?
Old Jan 12, 2006 | 09:45 AM
  #66
MIAPLAYA's Avatar
MIAPLAYA
Shops locally in Socal are charging between $750-$1100 depending on what you install with it...
Old Jan 12, 2006 | 09:59 AM
  #67
BlackZero6's Avatar
BlackZero6
woud i install a high flow cat after the downpipe?
Old Jan 12, 2006 | 10:05 AM
  #68
MIAPLAYA's Avatar
MIAPLAYA
Turbonetics actually has a downpipe with a cat welded on already..
Old Jan 12, 2006 | 10:11 AM
  #69
BlackZero6's Avatar
BlackZero6
now which exhaust would be ideal for this kit or do i have to stay stock...in other words which exhaust should i pick now in the event i put the kit on later
Old Jan 12, 2006 | 10:14 AM
  #70
Zilvia's Avatar
Zilvia
has anyone tried the APS Single Turbo Exhaust with the TN............or the JIC 3" single
Old Jan 12, 2006 | 10:15 AM
  #71
MIAPLAYA's Avatar
MIAPLAYA
A y pipe back that isn't straight open. The following exhausts are the ones that have had issues:
Greddy modified
RSR
Topspeed Pro-1
The following have not had any issues at all
Apexi N1
Apexi Ws2
Tanabe (all of them)
Modified Borla true dual
Fujitsobo
Custom Apexi N1
Stock
Amuse R1 Titan
  #72
zman1910's Avatar
zman1910
Originally Posted by veilside350zTT
so wats up with this APS single turbo kit.. can you get everything for under 5K?? and does it do a ecu reflash like the TN kit??? does it come with FMIC??
The APS kit does not use a reflash, it uses the Unichip which is much better and it is a tuneable EMS...so you don't have to worry about adding mods (exhausts and so forth). It is also very safe out of the box even if a tuner is not near you...
Old Jan 12, 2006 | 10:17 AM
  #73
Alberto's Avatar
Alberto
Cranky FI Owner
I have the JIC full Ti slightly larger than 3" 80mm (3" is 76mm) single on my car with the TN. I havent had much driving time with the kit, but for the little time I did I can tell you. Its loud as $hit, and I get 9psi peak boost-NO OVERBOOST WITH THIS EXHAUST. I love the exhaust, and it weighs less than 10lbs....
Old Jan 12, 2006 | 10:19 AM
  #74
Zilvia's Avatar
Zilvia
yeah APS is def in the beeter showing of out of box........and whit a APS ST, st exhause, with tune youll be good........since the fix of the checkvalave ps has no problems
Old Jan 12, 2006 | 10:26 AM
  #75
MIAPLAYA's Avatar
MIAPLAYA
Noice...I've been looking at getting that exhaust myself...
Old Jan 12, 2006 | 11:03 AM
  #76
BobbyRitz's Avatar
BobbyRitz
Is this necessary? Mossy sells a kit without the catalytic converter. What are the pros/cons of the having/not having the converter?
I'm strongly considering this kit. Since I have UTEC on already, I think all I need is the tuner kit ($4,045 through Mossy).
I'm in MD, so I'll probably have AAM install their fuel return system.
Is this generally all that I'm going to need?
Oh, here are my current mods:
AAM polished plenum
AAM plenum spacer
AAM y-pipe
AAM 2.5" test pipes (currently off)
AAM 3" single stainless angled exhaust
AAM ECU flash
UTEC with Tuner Reg Pro
Injen RD CAI
ACT clutch w/ 6 puck Race Disc
Fidanza flywheel
Old Jan 12, 2006 | 11:16 AM
  #77
35ounces's Avatar
35ounces
03 CS Track 6MT
Not sure if the Tuner kit comes with injectors ? If not then you will need injectors also. If your buying the fuel system and have the UTEC you might as well get bigger injectors too (440cc or 510's).
-David
Old Jan 12, 2006 | 11:21 AM
  #78
MIAPLAYA's Avatar
MIAPLAYA
-David
+1 Dave,
The tuner kit is the same as the base kit minus injectors, pump, and reflash. Since you already have the Utec installed you would get the tuner kit, Some injectors (440s, 510s, etc) and a Walbro pump. Total cost for injectors and pump ~$600... Tuner kit is $~4000...Total cost $4600 and you have a BAD@SS setup tuned via Utec..
Old Jan 12, 2006 | 11:41 AM
  #79
BobbyRitz's Avatar
BobbyRitz
I'm really feeling this setup. I spoke with Greg at Mossy to get a little more info.
Thanks for your input Mia and 35!
Old Jan 12, 2006 | 12:18 PM
  #80
MIAPLAYA's Avatar
MIAPLAYA
Glad I could help out...
