CJ Motorsports or AAM Return Fuel System
Old Jan 11, 2006 | 11:45 PM
JETPILOT's Avatar
JETPILOT
Default CJ Motorsports or AAM Return Fuel System
Any thoughts on the better fuel system? CJM Stage I or II, or AAM. I'm looking for 400 rwhp.
CJ Motorsports: http://www.cj-motorsports.com/prod350fuel1.htm
AAM: http://www.alteredatmosphere.com/350z/350z_2.asp
Respect
JET
Old Jan 11, 2006 | 11:54 PM
phunk's Avatar
phunk
CJ Motorsports
two great companies... two great fuel systems. flip a coin
Old Jan 12, 2006 | 12:26 AM
XBS's Avatar
XBS
Veteran
JET
From your post you seem like you do your research, I would look at both kits, their quality, the R&D put into them, and what componets you get. After you look at both kits you will know which one is better. And if you want my opinion....
the site to order it from is www.cj-motorsports.com
Good luck with your research!
Old Jan 12, 2006 | 04:50 AM
Fairlady_z33's Avatar
Fairlady_z33
will a fuel return system be needed if your going for 400rwhp no more the 400
Old Jan 12, 2006 | 04:59 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
CJ's all the way
Old Jan 12, 2006 | 05:19 AM
mcderns's Avatar
mcderns
And another for the cj motorsports.
Old Jan 12, 2006 | 07:43 AM
G3po's Avatar
G3po
I have the CJ stage 1 , I prefer the use of rubber coated SS lines as opposed to exposed SS which can abraid neighboring lines/hoses if not carefully tied down. I also prefer the look of the CJ fuel rails.
Old Jan 12, 2006 | 07:50 AM
captj3's Avatar
captj3
NO
Old Jan 12, 2006 | 08:33 AM
Zilvia's Avatar
Zilvia
i say cjmotorsports...............might be running their Stage 1 kit after i install my turbos
Old Jan 12, 2006 | 08:37 AM
sentry65's Avatar
sentry65
the burninator
the CJ motorsports fuel system is more heavy duty than the AAM one. The AAM one might look slightly more bling with some of the SS lines showing, but the CJM system is that plus a few more layers of kevlar (or was it something else?) covering the SS lines. So the lines don't look as pretty, but it'll be more likely not not burst or leak should a disaster happen. The rails look awesomet though
Old Jan 12, 2006 | 08:39 AM
sentry65's Avatar
sentry65
the burninator
no but it'll make the car safer with the tune etc. It can only help
Old Jan 12, 2006 | 09:11 AM
JETPILOT's Avatar
JETPILOT
Originally Posted by captj3
NO
In my case YES. I am @ 100% duty cycle on my 380 injectors @ 7psi of boost. Going to a 440 injector will mandate the use of a return fuel system if you want to do it right.
Thanks for your responses.
Respect
JET
Old Jan 12, 2006 | 09:20 AM
Fairlady_z33
the thing is that im going to do a tune to 7 pound with a 3 inch custom dual exhaust and the crawfor plenum but dont have the money right now for the fuel system. Thanks guys
Old Jan 12, 2006 | 09:22 AM
sentry65's Avatar
sentry65
the burninator
don't need a 3 inch dual exhaust with only 7 lbs of boost, but you probably already know that
Old Jan 12, 2006 | 09:23 AM
Zilvia's Avatar
Zilvia
no but it helps to acheive more power with a free flow...........
Old Jan 12, 2006 | 09:24 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
+1 for CJM
The two systems are almost identical so you really can't go wrong with either one.
Old Jan 12, 2006 | 09:30 AM
MIAPLAYA's Avatar
MIAPLAYA
I agree both systems will more then take care of your needs but I am personally going with CJM with the hopes that it will still be easily upgradeable to a twin pump setup. I'm going to need two pumps in the next year or so..
Old Jan 12, 2006 | 09:32 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
BTW, if you prefer the stainless lines, just let Charles know when you order and he can provide them that way to you.
Old Jan 12, 2006 | 09:36 AM
LOU's Avatar
LOU
+1 for CJM
Old Jan 12, 2006 | 10:42 AM
5thgenluder's Avatar
5thgenluder
+1 for cjs kit I've got it and love it......
