APS Injectors on TN kit?
Old Jan 17, 2006 | 10:29 PM
DBZ33's Avatar
DBZ33
Default APS Injectors on TN kit?
I just purchased 6 APS injectors for a really good price. I have been waiting for my UTEC to finally arrive and wanted to be ready for my UTEC, Fuel return, and Injector install. My goal is to be around 410-430RWHP safely. Do you guys think that the APS injectors will be good enough for the power I want?
Old Jan 17, 2006 | 10:42 PM
MIAPLAYA's Avatar
MIAPLAYA
They would be but you have to run at least 58-59 psi of fuel pressure them to work well. APS rates them at 500cc but only at that higher pressure so an adjustable fpr and return system is a must..
Old Jan 17, 2006 | 11:01 PM
DBZ33's Avatar
DBZ33
I will have a return fuel system installed at the same time. I just wanted to make sure for mid 400's RWHP they would be fine. Thanks Mia.
Old Jan 17, 2006 | 11:08 PM
MIAPLAYA's Avatar
MIAPLAYA
No worries man...glad to help out..just make sure when they install the fpr its set to 58-59 psi and you'll be good to go...
Old Jan 18, 2006 | 06:33 AM
Zivman's Avatar
Zivman
even at 3.5 bar, they are considered 440 injectors. The APS kit runs at 52 psi with 1:1 rising pressure.
Those injectors should easily handle your power, just like Jason stated, make sure you have the wiring loom (though I am sure you have it)
Old Jan 18, 2006 | 08:19 AM
DBZ33's Avatar
DBZ33
I forgot about the wiring loom. Do I need that? Where can I get that from?
Old Jan 18, 2006 | 09:02 AM
bsp's Avatar
bsp
Brainstorm Performance
Unfortunately we don't have any extras around here, but you can try some of the other APS Dealers.
Old Jan 18, 2006 | 09:11 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I'm sure GRD has an extra APS injector wiring harness. Give them a call.
Old Jan 18, 2006 | 09:32 AM
DBZ33's Avatar
DBZ33
I hope so. GRD is the one that is doing the install. I just need my UTEC to get there. I have been waiting forever. Thanks guys.
