UTEC questions
Old Jan 25, 2006 | 02:24 PM
rs350z's Avatar
rs350z
Default UTEC questions
I have a question about the UTEC. The tuner that comes with it is that really needed. I was planning on skipping over this part. It is just used to tune right? I plan on using a diffrent device for my A/F. I guess that Im just making sure that if i dont get this to work with the UTEC specifically ( will I be missing out on any functions) I wont be kicking myslef later for it....
any input would be great!
Thanks
Roger
Old Jan 25, 2006 | 03:09 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Thanks
Roger
The Tuner isnt required, but highly recommended, since it allows you, or the tuner to datalog wideband AF across the various load sites. It is particularlly usefull during road tuning. Someone else can chime in, but I have yet to determine if the UTEC can easily accept another standard wideband 0-5V input, for instance, from an Innovate or AEM wideband gauge.
Old Jan 25, 2006 | 03:30 PM
Julian@MRC's Avatar
Julian@MRC
The tuner is not needed but comes in useful if you want to datalog or do road tunning.We are currently running a package on the UTEC system and have a large quanity available for immidiate shipment..
https://my350z.com/forum/showthread.php?t=167160
Old Jan 25, 2006 | 04:11 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
Roger:
The tuner unit is really only useful if you are going to do some tuning yourself on the road by allowing you to log the a/f. The PRO allows knock sensor and I think you can also log injector PW and other things too. Might be helpful to your tuner but most of the people I talked to didnt seem to care.
Old Jan 25, 2006 | 04:18 PM
D350Z10's Avatar
D350Z10
Yes there really is no point if you are having a tuner tune your car... dyno's read A/D and log it too... its really made for road tuning for people who dont have dyno's and want to tune. Just get a boost solonoid and the map switch and sensor with the unit and your set.
Old Jan 25, 2006 | 04:25 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
speaking of map switch, you were gonna post pics of where they installed yours.
Any of you vendors heard from TurboXS about getting a map selector switch that fits in our cars (next to the VDC button)? They said it was coming...
Old Jan 25, 2006 | 05:21 PM
rs350z's Avatar
rs350z
I guess that is what Im ultimatley wondering..If anyone know that would be great.
Old Jan 25, 2006 | 05:22 PM
D350Z10's Avatar
D350Z10
35 This Friday I Promise!!!!!!!
Old Jan 25, 2006 | 05:23 PM
rs350z's Avatar
rs350z
Originally Posted by 35ounces
Roger:
If you used a diffrent device like the plx r 500 could you use that log with the UTEC?
Old Jan 25, 2006 | 05:45 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
My understanding: If you don't have the tuner unit then Mr. Tuner will use their own wideband and a logmapping tool to tune your car. The UTEC doesnt actually use the log. However if you have the tuner unit installed you can get it to track the A/F with the other values it logs which can be a great aid to tuning. You can probably see how much it will help if you read this from the UTEC manual (speed density mode):
In UTEC Data Logger 1 you have access to multiple bits of information that will allow you to tune your car properly such as; RPM, MAP PSI, MAF (v), TPS, Load Site, Knock Count, Injector #1 mS, Ignition #1 Degree, Ignition #1 duty, Mod Ignition Degree, Mod Fuel%, Mod Maf V. When you use one of our Tuner Wide Band Air Fuel Ratio meters you will also get AFR in Data Logger 1. This data gives you the information you need to properly tune your vehicle.
You can see how having the a/f right there in a column with the RPM, ignition and injector values would be helpful. But of course any shop will log the a/f and rpm and can match it to the UTEC log so....
So yeah if I could get the UTEC to log my a/f from my AEM that would be really cool and save me the cost of the Tuner unit. But I doubt TurboXS will give us that answer even if it does work. Maybe the Suby guys know. ???
Hope that helps,
Old Jan 25, 2006 | 05:57 PM
rs350z's Avatar
rs350z
Yes that is exactly what i was trying to say dave thanks. I guess someone will have to find out the anwser and post it up. So if anyone out there know is an non txs A/F could be used along with the UTEC like the tuner unit would be able to
Old Jan 25, 2006 | 06:16 PM
Julian@MRC's Avatar
Julian@MRC
I will ask Jermaine tommorow and have an answer on that for you..
But 35ounses was correct, the addition of the TX Tuner helps speed up the tuning process by letting the UTEC interface with it and datalogging the A/F ratio in the last column.This makes tuning more accurate to see that at 4530rpms when your in the 50% load site column and making 8.7psi of boost, with 22.5 degrees of timing your A/F ratio is at 11.45...Here is an example of how it looks.. this is an actual datalog on the road.
RPM MAP TPS Site Inj#1 Ign#1 Inj#1 Ign Fuel MAF AFR
psia % mS deg duty deg % V
5393 +16.6 103 80 16.00 +17.0 72.4 +14.5 -13.0 4.3 12.42
5482 +16.6 103 80 16.08 +17.1 74.0 +14.5 -13.0 4.3 12.37
5564 +16.5 103 80 16.13 +16.8 75.4 +14.7 -13.0 4.3 12.27
5649 +16.5 103 80 16.13 +15.9 75.9 +14.8 -13.0 4.3 12.21
5747 +16.6 103 80 16.12 +16.8 78.6 +15.0 -13.0 4.3 12.14
5868 +16.6 104 80 16.02 +17.9 78.4 +15.0 -13.0 4.3 12.09
5931 +16.6 104 80 15.93 +17.8 79.0 +15.0 -13.0 4.3 12.05
5984 +16.6 103 80 15.86 +17.8 79.7 +15.0 -13.0 4.3 12.00
6105 +16.8 103 80 15.75 +18.6 80.3 +15.0 -13.0 4.3 11.98
6184 +17.0 103 80 15.75 +18.8 81.2 +15.0 -13.0 4.3 11.98
6230 +17.1 103 80 15.72 +19.3 82.1 +15.0 -13.0 4.3 12.00
6361 +17.1 103 90 15.31 +19.3 81.1 +15.0 -13.0 4.3 12.00
6435 +17.2 103 90 15.10 +20.7 80.4 +15.0 -13.0 4.3 12.00
Old Jan 25, 2006 | 06:23 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
Hey Julian if you remember, ask him about that map switch too.
Old Jan 25, 2006 | 06:25 PM
rs350z's Avatar
rs350z
Much appreaciated!
Old Jan 25, 2006 | 06:30 PM
2slo2bfurious's Avatar
2slo2bfurious
Hey guys, can somebody start a sticky thread with UTEC maps and etc info for everyone?? I'm sure there's a couple tuned UTEC's on here. But you know, like on the WRX forums. Maybe it can help people looking for EMS's and what not.
Old Jan 25, 2006 | 06:35 PM
Julian@MRC's Avatar
Julian@MRC
The problem with that is that the 350Z's that are F/I have so many different set ups that the variables in the mapping differs so much.You could see on my datalogs that I am nearing 90% duty cycle on my 650cc injectors at 530 whp where as some members have achived much higher HP numbers using smaller injectors and more fuel pressure..So what works on one car might not be close on the next, and each F/I Z has to be custom tuned.
Old Jan 25, 2006 | 06:43 PM
rs350z's Avatar
rs350z
If you went to tune your car at MRC for example...Then you could just plug your pro tuner in with it? Could it work like that....
Old Jan 25, 2006 | 06:51 PM
Julian@MRC's Avatar
Julian@MRC
Correct, when tunning a UTEC we interface a TUNER-PRO with knock feedback and do the tune..The Tuner Reg is just a really cool datalogger A/F device..
35ounces's Avatar
35ounces
03 CS Track 6MT
yes except it has a wideband sensor connected to it (and power etc) so its not like your going to be popping it in and out ...I presume anyway.
Will it fit in the Nav cubby?
-David (is considering adding the Tuner)
Old Jan 25, 2006 | 06:53 PM
Julian@MRC's Avatar
Julian@MRC
It should, But I have Nav in my Nav cubby...Can I take exact measurements for you and you see if it fits?
