My Stillen Stage 4 Supercharger Mods Review :)
Old Jan 28, 2006 | 04:36 AM
mzack's Avatar
mzack
Is anyone selling the Stage 4 setup? I went to the Stillen site and there is nothing. Is this a self made Stage 4? I was considereing going to Stage 3 this summer since I have had the Stage 2 for a year and now I can just blow off the warranty because I do not see the engine blowing under this setup.
What was your total build up of just the Stage 4 parts?
Old Jan 28, 2006 | 07:35 AM
MMC Racing's Avatar
MMC Racing
Port the Stillen blower. Every roots type blower I have ever heard of responded well include the ones on Cobra's, Lightnings, T-brids, and Grand Prix's. The biggest benefit is usually on the top end.
-Mark
Old Jan 28, 2006 | 07:50 AM
ShadyJC's Avatar
ShadyJC
Originally Posted by Hydrazine
BTW I turned in my notice at Boeing because Motordyne is now doing well enough to be self sustaining
Congratulations Tony!
And congratulations Tony on the Stage 4!
Old Jan 30, 2006 | 01:42 AM
slatezluj's Avatar
slatezluj
if you dont mind me asking, how much did it cost you ?
Old Jan 30, 2006 | 11:29 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
Stillen's stage 4 is a upgrade kit that Stillen sells.
The kit includes the walbro 255 pump, RC 750cc injector, new fuel timing controller box, and new pulley for more boost.
PM me for more info
The kit is about an $800 upgrade.
Old Jan 30, 2006 | 01:22 PM
350Zum's Avatar
350Zum
This is the mod that I am saving for-
Old Jan 30, 2006 | 01:59 PM
superchargedg's Avatar
superchargedg
Damn Noobs
-Mark
has anybody heard of this and where in the hell would you port the blower,info please.
Old Jan 30, 2006 | 03:09 PM
Tony@Performance
I'm not sure who can port the blower properly, I too have heard of that. But I'm unsure of which shops exactly can perform this service. Also, more tuning would be needed, since you will be pushing essentially more air, the fuel injector controller box will need to be tuned differently, and you should consider upgrading the fuel components at that time. The original 7th injector is very tiny when compared to the upgraded RC injector.
Old Jan 30, 2006 | 04:52 PM
Z ELIMINATOR's Avatar
Z ELIMINATOR
Default Blower Porting
I am sending my M 62 to Stiegemeir to get ported and blue printed. Current rwhp is 307 ( 5AT) 8.5lb of boost 94 octane. ( 19 inch wheels) Running stage 2 setup with 8 lb custom made pulley.
Have not changed stillen control box, 7th injecter or fuel pump. Car runs lean on 94 octane but on 100 octane it is much quicker.
Fuel pump runs out of preasure at 5900 rpm and HP curve is flat up to 6800. First change will be the fuel pump as we expect it should make at least 10 more hp bringing it up to 317 on 94 octane. My Z is 2003 and my ecu has run rich from the first day i had the car, this is the only reason that we can run the high boost with out hurting the moter.
The SC should gain 25 HP from the porting and i expect the intake temp to drop do to the ported blower. Target is 342 rwhp. Will dyno car after every modification and post results. After the SC is ported we will change the 7th injecter to add more fuel to the engine. If required we will then change the contol box to see if the new box makes more power or it is possible that the engine may run rich.
My car also has headers on it. We estimate that the loss due to them is 8 hp. Dynoed the car with Random cats and it lost 6 HP. Base car was 217 to 219 stock.
Stage 3 made 290 with headers. Stage 2 was 272 with headers. 266 with RT cats.
Car run 13.0 on street tires with 2.009, 60 ft times with 307 rwhp. The problem is that in 4th gear the ecu subtracts lots of timing from the moter and it hurts the top end HP. The timing was bumped by 2 degrees and it made a huge differnce in 2nd and 3rd gear up to 6500 rpm. Hope to have the Utec on the car by late summer and have the timing ajusted in 4 th and 5th gear to make more power.
Also have the Stillen VB and the car in MM shifts hard. It hangs from 3rd to 4th but much better than stock. Will post results in 5 to 6 weeks.
Old Jan 30, 2006 | 10:40 PM
350z_this's Avatar
350z_this
waiting to hear your report.... so you really lost a lot of hp due to the headers and hf cats..... sad to hear that.... just take them out then....
Old Jan 30, 2006 | 10:51 PM
VN_350z's Avatar
VN_350z
Tony,
How much for stage 2 stillen supercharge with installation?
Old Jan 31, 2006 | 03:56 AM
thezedsled's Avatar
thezedsled
The stillen setups are pretty nice. I can't wait to see a dyno for a stage 4...
Old Feb 14, 2006 | 09:45 AM
nateg35's Avatar
nateg35
PM me for more info
Hi Tony,
Have you dynoed your stage 4 yet ?....Please keep us posted on your result...thanx
Old Feb 14, 2006 | 02:14 PM
Dr.G's Avatar
Dr.G
we usually keep at least one set of the belts here in stock, just incase
But so far, on my car, no squeal, no bad belts.... My techs keep a good eye out on the car too when they work on it
i agree , i have now the stage 4 (it has been 2 weeks almost), i drove stage 3 for about a year. the belts are fine exept the small blower belt that was changed once after 10k (very easy to do), but all other belts are still fine.stage 4 pulls hard all the way. still no dynos mee too, but the car is really fast now and feels ready to explode at any speed. i f you did not get the stillen flywheel yet, get it it makes a big difference too. i am kicking all the STI and evos *** big time
Old Feb 14, 2006 | 02:23 PM
Dr.G's Avatar
Dr.G
you have to ask for it from stillen, it is not yet advertised
Old Feb 14, 2006 | 02:44 PM
350z_this's Avatar
350z_this
did you just get the stillen flywheeel or did you do a flywheel/clutch combo? is the flywheel enough? and why just the flywheel w/o the clutch upgrade????
Old Feb 14, 2006 | 05:32 PM
Tony@Performance
We sell the stage 4 online on our site here:
http://performancenissanparts.com/ca...oducts_id=6469
and yes, a light flywheel with this SC does in fact help. That and running a KJR pulley:
http://performancenissanparts.com/ca...p?keywords=kjr
This pulley works perfectly for this setup, i love it.
the car drives much better with stage 4, and much faster
Also, on a side note, when my car comes back from the body and stereo shops, i'll be upgrading my intercooling system to see if little things can really make a big difference. I'll be upgrading the size of the core, start running water wetter, and a cusotmer intercooler Nitrous sprayer... So the next few months should be good, and getting ready for the hot cali summer!
Old Feb 14, 2006 | 06:10 PM
  #38
cersoft's Avatar
cersoft
As soon as I get my parts sent from Tony I will be installing and dynoing, maybe end of next week if they can fit me in ....
Also installing an innovate LC1/XD1 a/f gauge and nexus boost and oil pressue gauges ...
Yeah, can't wait ....
Old Feb 14, 2006 | 07:23 PM
  #39
MMC Racing's Avatar
MMC Racing
Originally Posted by Z ELIMINATOR
I am sending my M 62 to Stiegemeir to get ported and blue printed. .
Stiegemeier is about 10 minutes from me. They did my Lightning M112 and they have over 600 ported blowers under the belts the last 4 years. It is too bad that Stillen couldn't make a M90 work, but it is probably too large physically.
-Mark
Old Feb 15, 2006 | 12:56 AM
  #40
g35twinturbo's Avatar
g35twinturbo
Tony.
What do u feel about the risk of running a stage 4, as a daily driver. I am worried that i will be giving up one of the best thing the stillen sc has going for it, and thats its reliablity.
I was told that the stage 3 sometimes shows sign of detonation in hot canyon runs, and on hot days. How do u feel this is compared to the stage 3?
