Numbers are VERY lackluster. I am actually a bit bummed they are so low. I made 311 hp and 356 tq. I was really hoping for 350 out of the car. I will have the dynp up in a bit. The guys printer broke today, so he is emailing it to me when they shut down. It was a Dyno Dynamics dyno.
Wow thats not right... What was AFR? Peak boost pressure? Correction factor on the dyno? 311 is VERY low... any boost leaks?
SAE corrected, 8lb's of boost and the a/f got fatter and fatter as it approached 10.6 at full boost
10.6 is a bit rich. Sub 11s isn't bad. 10.6 is ok I guess. Those numbers are VERY low though. What other mods on the car? Plenum or spacer installed? Dyno Dynamics are usually lower then Dynojet but thats very low. I wonder what correction if any they applied to the numbers.
Not 100% sure, but i am seeing 8lb on the guage. The car is bone stock with a KJR pully.
The thing is a boost leak may not always result in lower peak pressure or even bad vacuum readings. For instance a G35 locally was hitting 8.3 PSI of boost, vacuum on his gauge was dead on, his AFR was in the 10s but he only made like 289 RWHP. The car was troubleshot and after replacing the leaking aftermarket plenum with a stock one the car made 360+ One way to tell for sure is to pressurize the intake tract and see if there are any leaks...
Yes the car made 233.8 HP w/ a pop charger. I will get the chart up ASAP. I'll get a before and after. They did 4th gear pulls originally, and the car made 301! So i asked them to do a 5th gear pull as someone said it's closer to a 1:1 ratio and got 311 hp.
Theres definitely something wrong with this picture.. Need to see those charts...any chance theres a Dynojet local? Just for comparison. Tq looks ok albeit a bit low...
The guy that installed it all used a "smoke" machine, and found no leaks.
The problem with a boost leak at the plenum is it may never show up until you put it under boost . Mine didnt . I had to preasurize the whole system with an air compressor to find it . I added two gaskets to the plenum to get it to seal under boost
