Why does my car backfire at WOT near redline?
Old Feb 9, 2006 | 03:14 PM
failsafe306's Avatar
failsafe306
Question Why does my car backfire at WOT near redline?
At least it sounds like a backfire..... Is it something I should be concerned about?
Old Feb 9, 2006 | 03:17 PM
blasian's Avatar
blasian
Mine does too. From what I've heard, its a Nissan thing.
Old Feb 9, 2006 | 03:19 PM
disturbed2483's Avatar
disturbed2483
i hope its not bad, but its sound pretty bad **** especially when you get some flames.
Old Feb 9, 2006 | 03:27 PM
97supratt's Avatar
97supratt
No its normal, if your vehicle is running rich or you have a blow off valve that vents into the atmosphere its normal.
Old Feb 9, 2006 | 03:33 PM
failsafe306
Well, it is rich. But it does it while still on the gas, so I'm not so sure it's the BOV.
Old Feb 9, 2006 | 03:41 PM
sq40's Avatar
sq40
When I souped up my Turbo Volvo I had that issue, Turned out to be a fouled plug.
Old Feb 9, 2006 | 03:48 PM
97supratt's Avatar
97supratt
If your vehicle backfires while your on the gas then you have a spark issue. I would suggest checking your plugs and if your FI then go with 1 or 2 step colder and regap so you dont have spark blow by. Good luck
Old Feb 9, 2006 | 03:50 PM
failsafe306
Thanks, I'll check the plugs tonight. Wouldn't surprise me if they're fouled.
Old Feb 9, 2006 | 04:33 PM
tig488's Avatar
tig488
mine backfires all the time now when i get on it a little bit and let off, probably about 1/3 throttle or so.
Old Feb 9, 2006 | 06:31 PM
plumpzz's Avatar
plumpzz
backfire is pretty bad for your car. the explosion happens inside your exhaust pipe and it goes toward the rear pipes and also toward your exhaust valves. u could damage the exhaust valves if the backfire is bad enuf
Old Feb 9, 2006 | 08:21 PM
Zexy's Avatar
Zexy
Is it really that severe? I see it most of the time on highly modded/boosted cars.
Seems to be a normal on highly tuned Supras/Skylines.
Old Feb 9, 2006 | 08:28 PM
bigbri's Avatar
bigbri
Mine does the same thing.....I'm checking my plugs and I know my car is rich.....It's fine as long as it doesn't happen all the time...
Old Feb 9, 2006 | 08:48 PM
Z350Lover's Avatar
Z350Lover
yup.... plumpzz is correct..... if the backfire goes to the exhaust valves and it also happens that your valve springs are not strong enough to hold the pulse... your valves will be forced to open and possible bend themselves by touching the pistons (when pistons are on their way up).... It happened to me when I bent my exhaust valve...
cheers,
richie
Old Feb 10, 2006 | 08:01 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
A little backfire on decel at higher RPM is nothing to worry about. Backfire while at WOT, regardless of RPM, is something to worry about. As mentioned, check the plugs, coil packs, etc. Most backfires result from a sudden lean condition, such as letting off the throttle after a WOT run. Do you have a wideband that you can monitor while the backfire is occuring?
Old Feb 10, 2006 | 02:11 PM
failsafe306
I do, but when I'm running wide open on the street, it's hard to look over and see what the A/F is doing; if anything, I'm glancing down at the tach so I don't hit the rev limiter since it gets up there so fast
That, plus the fact that it doesn't do it ALL the time...
Old Feb 10, 2006 | 05:00 PM
backagain's Avatar
backagain
here is a video of me racing a modded mach 1 stang, car was tuned by cpracing a while back. 400 hp and 342 tq, the TA i raced 2nd was HIGHLY TUNED , i beat him on the 2nd run but never get to pass him in the first race, you can see me backfiring in the first race i believe.
www.panhandlez.com/videos/thursracing.wmv
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
Ace2347
Sep 22, 2015 03:12 AM
pdexta
Sep 14, 2015 11:27 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
Bigsyke
Sep 11, 2015 06:19 PM
