Strange Problem w/ APS TT
Old Feb 14, 2006 | 09:43 PM
zman1910's Avatar
zman1910
I remember someone else in the same sort of situation and had the RPS package as well. It was someone on the boards but I cannot recall who it was...Hopefully they can chime in if they see this...GL
Old Feb 15, 2006 | 04:21 AM
Madelinot's Avatar
Madelinot
Originally Posted by ht4
Thanks for the idea- We considered that might be the issue so we totaly disabled the VDC system but the problem remianed...
The guys who did my install tell me that because of the splines in the steering shaft hook-up, it is pretty hard to mess up so that also tells me that is likely not the problem... In any case, assuming it is the issue, do you know how to reset the VDC system?
For the VDC light, just one rib off on the steering shaft and it can cause problems (been through this before). You can't mess it up completely, but it's actually easy to get it slightly wrong. Check it out.
Old Feb 15, 2006 | 04:30 AM
ht4's Avatar
ht4
What sort of symptoms did you have?
Mine works fine under all conditions except WOT (or close to it) and whenever it hits around 6psi. It will redline with no problems even under about 85%... It's only under full power- that is why I am leaning towards a MAF voltage issue.
Old Feb 15, 2006 | 07:23 AM
Madelinot's Avatar
Madelinot
That's the thing, I can't tell you the symptoms other than the lights were on because I suspected that it was related to that and fixed it immediatly before driving it hard. When I first installed my APS TT, I fired it up and drove it without any hickups whatsoever. Second time around, the steering shaft was off by one rib and it caused the brake and VDC lights to come on.
Best of luck and let us know...
Old Feb 18, 2006 | 02:30 PM
ht4's Avatar
ht4
Update:
Swapped out the wiring harness with no effect
unichip X1 driver was adjusted with no effect
Swapped out the unichip X1 driver with no effect
Called RPS who confirmed that they have NO COMPLAINTS from my batch of flywheels with regard to CAS issues (and since they are made in large batchs where are all are cut from the same piece of metal, if one had an issue, 40 would likely have the same issue)
VDC was TOTALLY disabled without effect
We are running out of ideas!!! Your help would be highly appreciated.
Old Mar 7, 2006 | 05:28 AM
NISMOFO's Avatar
NISMOFO
Did you ever get this fixed?
DBZ33
Jan 6, 2006 03:40 PM
tonio
Nov 22, 2005 04:45 AM
Orlando333
Oct 22, 2005 04:59 PM
zman1910
Jul 26, 2005 09:57 AM
gsxfury
Jan 18, 2005 09:15 PM
