Upgrades to support 700 whp
Old Feb 16, 2006 | 08:11 PM
mrtomcat's Avatar
mrtomcat
Default Upgrades to support 700 whp
Other than a build engine I would like to get a list of items needed in order to get up to 700whp safely and reliably.
I know there are lots of threads dealing with some of those but I'd like it all on one thread....many we can sticky it?
Here are the things I can think of right now:
ATS Clutch and LSD
Race Logic Traction Control
Stillen Camber Kit
Tein Coilovers
Upgraded Fuel Pump and Injectors
What other suspension items are needed?
What else am I missing?
Old Feb 16, 2006 | 09:04 PM
350Zteve's Avatar
350Zteve
Here is what I would add to your list
ECM (HKS Vpro, UTEC, or similar)
Beefed up rear axles.
1000cc injectors
Cams
Ported heads (maybe)
ARP studs.
3" exhaust and downpipes
I think your biggest problem will be the APS turbos. The intergral waste gates are not adequate at all to flow that kind of cfm. This is not a knock against the APS kit, because its awesome, just not intended for 700+rwhp.
Also, having owned a 700+rwhp car before, safe and reliable are hard to come by, especially if you drag race.
Old Feb 16, 2006 | 09:08 PM
mrtomcat's Avatar
mrtomcat
I already have Stage II upgraded Axles, but will probably go to Stage III.
My goal is more around 600whp but I want to be able for it to handle up to 700...
I did forget to add the upgraded wastegates for the APS kit to up the boost
and of course the ECM
I have a good idea on the Build engine already but want to make sure I have all the other components covered as well
Old Feb 16, 2006 | 09:24 PM
AmyCroft's Avatar
AmyCroft
Smile Tomcat - did you find a good Core engine yet?
May I suggest you contact GurgenPB... PM him.. He is very much into Instrumentation and very methodical in his approch. His current build runs like a top.. The builder is in the bay area (SF) and did a first class job... A Russian/Armenian/English Speaking Engineer. He might have a bit of Alimain.
Cheers Amy -
Of course Wld350Z (Tony) may be of assistance.
Old Feb 16, 2006 | 09:30 PM
ZON's Avatar
ZON
1000cc injectors
Cams
ARP studs.
I dunno about that, their is an 800whp APS'd TT 350Z I know well of. Maybe his waste gates were modded but whatever. Same builder who did this one also did the one AmyCroft speaks of.
edit:
Oh yeah, and that 800whp Z run's low 9's,
Old Feb 16, 2006 | 09:41 PM
Fairlady_z33's Avatar
Fairlady_z33
do you have pics or vids of this car i have to see this.
edit:
Old Feb 16, 2006 | 09:45 PM
mrtomcat's Avatar
mrtomcat
Cheers Amy -
I was going to go with an SGP engine but am talking to Performance Motorsport right now since they have undoubtably shown that they know what they are doing...
let me add real quick that my ultimate goal is to be in the low 10's in california...I believe that should be do-able with in that range
Old Feb 16, 2006 | 10:13 PM
350z-900whp's Avatar
350z-900whp
don't you need to sleeve your block and head gaskit.
Old Feb 16, 2006 | 10:32 PM
mrtomcat's Avatar
mrtomcat
again, engine is taken care off, I need to know what else other than the engine...and yes it will be sleeved..
Old Feb 17, 2006 | 10:02 AM
350Zteve's Avatar
350Zteve
If you want to get into the 10's really easy, get the adapter plate and run a built GM transmission like a turbo 400 or a 4L80E. With just the tranny and no other mods, you will drop close to a second off your quarter mile time. Even more as you add more horse power.
When I made the same change in my Supra, I went from running 11.80's stick to 10.80's auto with no other changes.
Old Feb 17, 2006 | 10:12 AM
meatbag's Avatar
meatbag
Youll want to look into the needed drivetrain upgrades as well. If you go with the turbo400 you should be good but youll still want to do something with the rear end. Otherwise if you have a MT youll need to look at clutches and maybe cryo treating the syncros in the transmission or something. Then youll have to do something with the half-shafts like driveshaft shops axles.
If you do the turbo400 it would be cool to look into a 4-link style read end setup with a solid axle or something too.
Old Feb 17, 2006 | 10:57 AM
UnderPressure's Avatar
UnderPressure
Dear Meatbag,
Please put down the crack pipe.
The rear diff has held up over 1k hp in testing and practice. If you read any of the previous posts you would have seen that tomcat has upgraded axles and clutch. At no point did he state he was going to switch over to t400 trans. The previous poster suggested this route since he did this w/ his Supra. If you have read any other posts by tomcat you will know he is not looking for an all out drag car. He likes to shift.
The idea of a 4-link in a daily driven street Z is just wrong in so many ways....
Old Feb 17, 2006 | 11:03 AM
chimmike's Avatar
chimmike
If anything, see about getting non-internal gate turbine housings and swapping over to external gates with higher spring pressures....that way higher boost settings via the controller will be more steady, instead of doing more than double the spring setting.
it's not so much about the actuators, but the actual flow of the turbine housing made for internal gate...at that kind of power, turbulence in there caused by the internal gate stuff could be dangerous.
Old Feb 17, 2006 | 02:36 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
In addition to a sleeved block, you have a good list there.
With ATS, you will want their triple disc carbon clutch with 1350kg pressure plate.
You will also need a stage II fuel system, as the single walbro poops out at about 550whp or so.
Other than that, its just the basics that you have already purchased, or covered. And of course...solid tune...preferably with a UTEC or other standalone with knock feedback.
Old Feb 17, 2006 | 03:39 PM
JETPILOT's Avatar
JETPILOT
Did it occur to anyone to aks WTF r u going to d owith 700whp?
Respect
JET
Old Feb 17, 2006 | 06:34 PM
mrtomcat's Avatar
mrtomcat
Originally Posted by UnderPressure
Dear Meatbag,
well spoken, thank you
Old Feb 17, 2006 | 06:35 PM
mrtomcat's Avatar
mrtomcat
Thanks Sharif, who makes a decent Stage II Fuel System?
Old Feb 17, 2006 | 06:39 PM
mrtomcat's Avatar
mrtomcat
Respect
JET
you're kidding right?
Have you read any posts in this forum alone, there are quite a few people who have many a plan on what to do with 700whp.
In my case, I compete at IDRC and NHRA and want to work myself up in to some better classes...eventually the car will be track only but not in the immediate future.
Conway_160
Drag
Sep 29, 2015 08:07 AM
