Whats the next logical step
Old Feb 20, 2006 | 05:58 PM
turismo's Avatar
turismo
Default Whats the next logical step
After installing the PE turbo kit and running it for around 4 months, I'm kind of board with the power now. For those who are interested I made 418rwhp and 430lbtq at 8psi of boost. My car has the following upgrades:
(External wastegate setup coming in 2 weeks)
Hks Ti exhaust
stillen cat delete
koyo radiator
D2 coilovers
cusco f and r sway bars
Greddy emanage
Rps clutch and flywheel
I know I need to upgrade the injectors for additional hp since PE only comes with 380cc, but after that, what would you recommend me doing next? Should I start by purchasing parts for the bottom end or upgrade to an eman. ultimate and tune for 650 injectors. My goal for right now is 450rwhp. I would rather not touch the bottom end as of right now, since my funds are kind of limited. Do you think it would be ok to tune for 450rwhp and worry about the block later? Or should I be safe and start the rebuild. Are there any additional parts that I can benefit from such as spacer,intake manifold,etc...before upping the boost any to achieve 450rwhp.
Old Feb 20, 2006 | 06:04 PM
D350Z10's Avatar
D350Z10
Your best bet for 550whp safely.... built short block, pistons brands which I would go with Wiesco, Arias, Cp, Rods Crower, Pauter, Arp main studs and bearings, cleaned balenced honed all that ****. then RC550cc Injectors or 650cc, AAM fuel return, Nismo thermostat, Crawford plenum or wait for the new one from phunk, solid tune, get rid of the EMANAGE= crap for highend, get a Turbo XS UTEC, Or a HKS F-Con pro, and should be good
Estimated cost pry with labor and all close to $10,000
GO to SGP there in your neck of the woods!! they have packages.
Old Feb 20, 2006 | 06:13 PM
turismo's Avatar
turismo
Well I already have the rods(eagle) but the thing is I really can't be without the car for that long. Yes SGP is a very reputable shop, but they can take for ever to complete a project. I really want to hit 450 or more before I start tearing into the motor if it is possible. If something happens, hell that just gives me more reason to build it.
Old Feb 20, 2006 | 06:15 PM
D350Z10's Avatar
D350Z10
well if you only want 450whp get a Soild EMS, a intake manifold and should be able to hit 450 with a good tune on a stock block many people are doing it, and no problems.
Old Feb 20, 2006 | 06:25 PM
roncfpz's Avatar
roncfpz
I'd say add AAM 3" downpipes, AAM 3" true dual exhaust or SVR 3" true dual with UTEC and re-tune.
turismo's Avatar
turismo
I've done a search on the intake maniolds, but for some reason it is down. I know that there is the Crawford,Kinitex(sp) and the one you where refering to. Out of those two(don't know how long until he finishes his) who has the best gains and a nicer design.
Old Feb 20, 2006 | 06:27 PM
D350Z10's Avatar
D350Z10
From looking at the phunks prototype their intake manifold seems that it will put out the best gains because the vents are ported out more and bigger. But you might have to wait, send him a pm. Or if you want to do it now go with the crawford I am using it great mod good gains.
Old Feb 20, 2006 | 06:29 PM
turismo's Avatar
turismo
I would really hate to sell my Hks ex since I just purchased it. Do you think my stillen cat delete and Hks ex. are that much of a restriction at these power levels?
Old Feb 20, 2006 | 06:31 PM
D350Z10's Avatar
D350Z10
nooo not at all, the hks is a i believe 2.5 pipe it wont do much, that exhaust is one of the best out there.
Old Feb 20, 2006 | 06:40 PM
JeffesonM's Avatar
JeffesonM
As you mentioned, you should up the injectors and also consider a return style fuel system... both of these will be useful both now and if you decide to build the block later on. A spacer isn't a bad idea... I'd hold off on the whole manifold though until we get some more data around both SFR's and phunk's new products.
Old Feb 20, 2006 | 06:43 PM
Gman2004's Avatar
Gman2004
Whether you are going to build it or not take it to SGP. You can't go wrong with them. I just picked up my car on Saturday from them and I have been happily swinging from their nuts ever since.
Old Feb 20, 2006 | 07:44 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
To take boost to the next level on your stock block, the next step must be a complete return fuel system, larger injectors (550cc so you wont need to upgrade again later with the built motor).
I agree that the basic eManage blue is less than ideal platform for tuning higher boost cars. I would switch to the UTEC, and retune to about 450whp, since you seen OK with building up your motor if something breaks. Best of luck, and let me know if I can help you.
Your HKS exhuast is about 2.4 inch inner diameter, so you should be OK for 400-450whp, but there will be more power to be had, by switching to a 3inch true dual setup. Those HKS exhuasts are getting top dollar in the aftermarket, if you decide to sell it.
35reilly
Sep 28, 2015 07:42 AM
samansharif
Sep 25, 2015 12:31 PM
