lifting heads
Old Mar 1, 2006 | 10:34 AM
  #61
bigbri's Avatar
bigbri
Originally Posted by barthelb
Bri, I had the problem you experienced. Blowing coolant all over the engine bay. Everyone at Zcargarage was wondering if i was blowing my headgasket or lifting the heads. I noticed problems with my cooling system at the same time. Noteably, stalling, ruff Idle when cold and the pressurizing of my cooling system. After my Nismo thermostat started sticking, causing my engine temp to rise, we switched back to the stock thermostat, flushed and got all air out of the system, and its been fine since. No coolant blowing all over, nothing. So, maybe your just getting a thermostat problem. Keep an eye on that temp guage.
Thanks bro...I'll look out for that....my temp never goes above the middle...But I'll keep an eye on it...
Old Mar 1, 2006 | 12:32 PM
  #62
Gman2004's Avatar
Gman2004
How many lbs are you boosting? This head lift issue has me scared chitless. Even though I am getting the HKS FCON, I am going to keep the boost down to no more than 11psi. If my car breaks down 1 more time my wife is going to throw me out of the house.
Old Mar 1, 2006 | 12:42 PM
  #63
overZealous1's Avatar
overZealous1
man i know you have had a ton of problems. what motor are you on, 3-4 or something like that.
Old Mar 1, 2006 | 01:01 PM
  #64
Gman2004's Avatar
Gman2004
#3, but who's counting other than my wife.
Old Mar 1, 2006 | 02:14 PM
  #65
barthelb's Avatar
barthelb
Master
i'm boosting around 13-14psi per the guage, however im tuned for 9.5psi.
Old Mar 1, 2006 | 05:23 PM
  #66
t32gzz's Avatar
t32gzz
barthelb - when you had your problems did you notice any carbon flakes in your coolant? Specifically in the overflow resevoir?
Old Mar 1, 2006 | 07:20 PM
  #67
accordfreak's Avatar
accordfreak
just wondering, i don't know if this was asked but were the heads and the block checked or milled flat before installing? thanks
Old Mar 1, 2006 | 08:16 PM
  #68
overZealous1
mine were not. but it was a fairily low mile motor too. now that my motor is seasoned i will do it. the process i am looking at doing will require it also though.
Old Mar 2, 2006 | 06:15 AM
  #69
Quamen's Avatar
Quamen
Are you looking at making a sort of block gaurd for the engine?
Old Mar 2, 2006 | 07:05 AM
  #70
overZealous1
i'm hoping it will be kind of an end all to strengthen the open deck and and make sure the heads will stay sealed.
Old Mar 2, 2006 | 08:33 AM
  #71
ARLETOS 350Z's Avatar
ARLETOS 350Z
Let the Greeks do what they want Many HPss and Many wifes...
Old Mar 2, 2006 | 08:55 AM
  #72
barthelb's Avatar
barthelb
Master
No, there was none found. Although with the APS reservoir its kinda hard to see in there but a general look didn't find anything.
Old Mar 2, 2006 | 11:29 AM
  #73
booger's Avatar
booger
A guy I know was showing me a Supra block he was building . He showed me how he poured in this type of cement around the cyl. walls to straigthen them . The cement expanded at the same rate as the metal . Is that doable with our blocks ?
Old Mar 2, 2006 | 05:18 PM
  #74
overZealous1
not for driving on the street. you kill the ability for the water to absorb the heat. this is a trick used by drag racers for years. but ONLY should be done on a all out strip car and never on the street.
Pleask
Dec 21, 2021 03:17 PM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
350Z_Al
Oct 29, 2020 07:44 PM
